SS Theme - Darkness
SS Theme - Darkness
Postby Hellscream » Wed Jul 27, 2011 5:05 pm
Check Out my theme
Image]
Hellscream
Postby kramttocs » Wed Jul 27, 2011 5:12 pm
Can you double check your image links? Looking forward to checking this theme out.
kramttocs
Postby Hellscream » Wed Jul 27, 2011 6:06 pm
Hellscream
links
Postby trickydick » Fri Jul 29, 2011 2:37 am
I don't think your site is allowing direct links without login, including the images
Tricky
trickydick
Postby Hellscream » Fri Jul 29, 2011 4:13 am
Its a temporary try now
Hellscream
Postby bytethdgroove » Fri Jul 29, 2011 5:03 pm
wondering if you could please tell me what I would have to remove from sspack to take out the accordian.....love everything you have in the pack, and the accordian is real nice, but me personally I like the tree view better as I can see a bunch of artists at once...
thanks for your mod/theme
peace
byte
"I'm as honest as the day is long, the longer the daylight the less I do wrong!"
bytethdgroove
Postby Hellscream » Fri Jul 29, 2011 5:18 pm
Use this link to customize widget
http://jqueryui.com/home
Hellscream
Postby bytethdgroove » Fri Jul 29, 2011 5:38 pm
i thinki may not stated my question correctly..
I want to use all your mods except the accordian...I would like to remove it from your download and install everything else
thanks
byte
also I tried your theme all look goof except help icon was missing even though its in the folder... i did notice it is looking for a 30x62 size help icon and the one in the folder is 32x32...but shouldnt matter?
thanks again!
bytethdgroove
Postby bytethdgroove » Fri Jul 29, 2011 5:41 pm
duh...i could just remove what u told me is just the accordian...so it stil answered my question
thanks
byte
bytethdgroove
Postby Hellscream » Fri Jul 29, 2011 5:42 pm
Than simply remove those files i posted in previous reply
Hellscream
Postby bytethdgroove » Fri Jul 29, 2011 9:25 pm
someboy edit you fist reply, so now I dont remembe which files to remove for the accordian, can u please repost
thanks
byte
I stepped out before I could make the changes
bytethdgroove
Postby Hellscream » Fri Jul 29, 2011 9:29 pm
Remove those files:
Hellscream
Postby Hellscream » Sun Jul 31, 2011 7:42 pm
Few modification of my theme.
Thanks to the people who developed and shared their work on this forum.
Hellscream
Postby fussel01 » Tue Aug 02, 2011 9:30 am
I am a New Subsonic User and your Theme looks very good. Can you explane me how to install it ? I have copied the Files on the correct Places in my Subsonic Folder, but there is np Change in my Theme ??? What i do wrong ?
BR
Fussel01
fussel01
fussel01
Postby Hellscream » Tue Aug 02, 2011 9:42 am
did u also copy themes.txt file i jst check pack working fine.
Try del jsp cache and browser temp files restart SS it should bee fine
Hellscream
