MiniSub - Subsonic HTML5 Web App (Archive)
Jamstash is an HTML5 Mini Player for the Subsonic streaming server
Re: Subsonic HTML5 MiniPlayer
Postby tsquillario » Tue Sep 06, 2011 2:21 pm
I've been using my HP Touchpad for the last week or so and I love it! I'd like to make MiniSub more tablet optimized for a touch style interface.
I'm thinking of adding another option to the Preferences where you can choose what kind of display you are using. Tablet or Desktop. Not 100% sure how I'm going to implement it yet.
Developing an App for every mobile OS is a LOT of work. Make a good website and you only need to make one! Granted you loose some functionality but not very much imo.
Jamstash Developer
Chrome App - https://chrome.google.com/webstore/detail/jccdpflnecheidefpofmlblgebobbloc
Beta Site - http://beta.jamstash.com
GitHub Project - https://github.com/tsquillario/Jamstash
tsquillario
Postby iGor » Sun Sep 11, 2011 8:16 am
Wouav! Works fine, easy to install...
Could it be working with the sharing option?
And what about a disconnect button?
But still, fine work, thanks!
iGor
Postby agr1277 » Mon Sep 12, 2011 10:03 pm
I'm having an issue as well. I copied a MiniSub folder to the Subsonic directory. The folder contains the folders: images, js, and style. The MiniSub folder also has the 2 files: Index, readme.
After copying the folder into the subsonic directory I went to the following address: http://localhost:4040/MiniSub
I get the error:
HTTP ERROR: 404
NOT_FOUND
RequestURI=/Minisub/
Powered by Jetty://
If I'm not installing and running this correctly can you post instructions? I don't have any issues connecting to Subsonic using the normal interface.
Thanks for the work. I look forward to the development of this program.
agr1277
Postby BKKKPewsey » Tue Sep 13, 2011 1:51 am
Hi
I thought I would have a look at this but I seem to have one major issue - NO MUSIC LISTED :(
My Artist folder is empty.
I seem to be able to log in ok (I presume so as it shows the music library tab empty)
I have stopped and Restarted SS and cleared jetty cache but still nothing shows :?
Yep it certainly a clean interface especially with no album art or artist names cluttering it up :D
I am using a subsonic context path so I am accessing via server:port/subsonic/MiniSub
If anyone has any ideas what the problem may be please share
ps I did rename the directory to MiniSub as "tsquillario-MiniSub-65769fd" seemed to be a bit hard to remember :roll:
Postby Baggypants » Tue Sep 13, 2011 3:36 pm
tsquillario wrote:I've been using my HP Touchpad for the last week or so and I love it! I'd like to make MiniSub more tablet optimized for a touch style interface.
Lovely on my desktop, flat out dosn't work on iOS 4.2.1 though, which is odd because going to http://kolber.github.com/audiojs/ works fine
Baggypants
Postby tsquillario » Sat Sep 17, 2011 3:12 pm
BKKKPewsey wrote:Hi
It looks like your trial license has expired. When it is all API functions will but cut off however the main SubSonic website will continue to work.
Jamstash Developer
tsquillario
Postby tsquillario » Sat Sep 17, 2011 3:14 pm
Are you using an iPhone or iPad? I don't have either on hand to test. I will see if I can test on another persons. I just released an update today, try that out.
Jamstash Developer
tsquillario
Postby BKKKPewsey » Sat Sep 17, 2011 5:03 pm
Fully paid up and works with ISub and *.subsonic.org :?
Will try the new version :roll:
Postby prepsel » Sun Sep 18, 2011 1:08 pm
For some reason only in Safari I get this message, if I use IE9 or Google Chrome it's not an issue playing music.
Error loading: "http://My.MusicServer.com:3232/rest/stream.view?v=1.5.0&c=subweb&f=json&id=473a5c4b65246861202d20416e696d616c5c4b65246861202d20416e696d616c202d203031202d20596f7572204c6f7665204973204d7920447275672e6d7033"
Would you know what is causing this...I haven't tested on my iPad yet.
Thanks...
-Frank
prepsel
Postby Concept211 » Tue Sep 20, 2011 1:31 pm
Wow, I really love that clean interface! Kinda similar to the new Google Music UI (music.google.com). It would be awesome if Sindre incorporated this new setup as the default for all future builds. But all of the existing features, options, etc would need to be implemented into it. Great job!
Concept211
Postby boognish43 » Wed Sep 21, 2011 11:36 pm
agr1277 wrote:I'm having an issue as well. I copied a MiniSub folder to the Subsonic directory. The folder contains the folders: images, js, and style. The MiniSub folder also has the 2 files: Index, readme.
I get the error:
HTTP ERROR: 404
NOT_FOUND
Powered by Jetty://
I am still having this issue as well.. Never did get it working
any ideas?
boognish43
Postby Nyr » Sat Sep 24, 2011 10:07 pm
For users getting 404 trying to set up it, I solved it on my Windows Server by zipping it inside subsonic.war (it's a compressed file) and restarting subsonic. I suspect that maybe on other platforms, the web server contents are unzipped and because of this, the author's instructions don't work on Windows ;)
Nyr
Postby agr1277 » Sun Sep 25, 2011 5:17 am
I stumbled across this in another forum. Save the folder you download into the directory on you computer that subsonic is installed: Jetty/xxxx/webapp
I renamed the folder from the zip file to MiniSub.
For me my directory path is as follows: C:\subsonic\jetty\2385\webapp\MiniSub
agr1277
Postby boognish43 » Sun Sep 25, 2011 5:37 am
agr1277 wrote:I stumbled across this in another forum. Save the folder you download into the directory on you computer that subsonic is installed: Jetty/xxxx/webapp
Thank you! That worked perfectly!
Thanks again for this awesome mod!
boognish43
Postby Brian962 » Wed Sep 28, 2011 11:18 pm
Thanks for working on this. I got the player installed and can access it, but no music shows up. Any ideas? I'm not on a trial license. Thanks!
Brian962
Return to Jamstash (formerly MiniSub)
cron
