Better video quality when sharing
Postby GreenTentacle » Wed Aug 17, 2011 8:59 pm
Replace externalPlayer.jsp in /var/subsonic/jetty/<some numbers>/webapp/WEB-INF/jsp/ with this one : http://www.mediafire.com/?u56u58yc5m4f6qx (updated 12/13/2011)
The default bitrate is 1000Kbps, if it doesn't suit your needs (or server bandwidth), find line "var maxBitRate = 1000;" and change it with the value of your choice.
Update :
added the repeat option (See here for possible configurations) thanks to Fenny
Last edited by GreenTentacle on Tue Dec 13, 2011 12:37 pm, edited 6 times in total.
GreenTentacle
Re: Better video quality when sharing
Postby rvandaalen » Sun Sep 18, 2011 2:07 am
Do you also have a solution for using correct video width and height? when a video file is shared? Thanks for the new player :wink:
rvandaalen
Postby G_A » Sun Sep 18, 2011 5:49 am
Could you detail what specifically differs between the two players?
G_A
Postby GreenTentacle » Mon Sep 26, 2011 2:12 pm
rvandaalen wrote:Do you also have a solution for using correct video width and height? when a video file is shared? Thanks for the new player :wink:
I updated externalplayer.jsp, removed "stretching: "fill"" in the player attributes, now the aspect ratio should be correct.
G_A wrote:Could you detail what specifically differs between the two players?
Just a higher bitrate settings (it was absent in the original file and the player set it very low by default) and now the video isn't streched anymore.
GreenTentacle
Postby fventura03 » Mon Sep 26, 2011 5:58 pm
does this change anything for video that's not shared, like normal user viewing?
I noticed I can change my maxbitrate in this file and it changes it for users watching video.
fventura03
Postby GreenTentacle » Tue Sep 27, 2011 10:27 am
fventura03 wrote:does this change anything for video that's not shared, like normal user viewing?
Nope, normal user viewing is done by videoPlayer.jsp which already has bitrate settings.
GreenTentacle
Postby fventura03 » Wed Sep 28, 2011 3:45 pm
I was wondering because when I watch a video locally, I can get 2500kbps from any file, but my friends on their home computers can only get 1000, I want to set it for them to get 2500kbps also.
they have a capable connection of getting those speeds, yes.
EDIT: I think I got it.
changed it to:
var maxBitRate = 2500;
in videoplayer.jsp
fventura03
Postby darkuni » Thu Oct 06, 2011 3:00 pm
Is there any reason that the SHARING player cannot have the bitrate and time jump options like the standard viewer? I'd really like to see that implemented.
darkuni
Postby Fenny » Wed Oct 12, 2011 4:10 pm
Adding the following line to the "var flashvars" entry will allow the playlist to auto advance until completed.
repeat:"list"
Fenny
Postby Castius » Sun Oct 16, 2011 6:28 pm
Nice, thanks.
Castius
