The Facebook UI Theme !!Now Available!!
Re: The Facebook UI Theme !!Now Available!!
Postby MadEvil » Tue Dec 20, 2011 9:01 am
thx!
i forgot the jetty cache, now it works :D
Madsonic Developer
MadEvil
Postby boognish43 » Thu Dec 22, 2011 12:20 am
wow! I love this theme! Ive got everything working great except this:
I turned off accordion menu and it looks like this info was static but interferes with the left menu
any ideas?
thanks!
edit: 1 more question to bug you with :)
I applied this mod viewtopic.php?f=8&t=5951 and while it works it makes the top menu disappear. do you know what I could do to make the home windows show the recently added in this skin?
boognish43
Postby sigel » Thu Dec 22, 2011 1:49 am
not having any luck.. mine looks like this.
any ideas? tried v1 and v2 ... both look the same.
sigel
Postby boognish43 » Thu Dec 22, 2011 1:53 am
sigel wrote:not having any luck.. mine looks like this.
mine looked like that until i deleted my subsonic/jetty/###/jsp folder and cleared internet cache
stop the service-delete the jsp folder-restart service-clear internet cache-refresh should work
boognish43
Postby boognish43 » Thu Dec 22, 2011 1:56 am
another quick tip - go into head.jsp in the WEB-INF\jsp folder and change Tricky's Subsonic to whatever you want :)
boognish43
Postby trickydick » Thu Dec 22, 2011 3:14 am
my bad about the header....I meant to take that out.
For the users with no accordion, u can comment out or remove the .musicdetail {....} in the facebookui.css
And yes be sure to clear ur cache or else it won't work properly
Tricky
trickydick
Postby trickydick » Thu Dec 22, 2011 3:26 am
Boognish43 - if ur applying the changes to the index.jsp file, don't apply the full change as my index.jsp for the mod is different, instead change the only the href part; nowplaying.view... to the code home.view?... code.
Tricky
trickydick
Postby sigel » Thu Dec 22, 2011 5:09 am
ah delete the /jsp folder ok... does anyone elses player looking like this?
I was able to get the accordion going after downloading jquery and jquery-ui.
sigel
Postby trickydick » Thu Dec 22, 2011 5:35 am
U need thevdddropdownmenu.HS for the player to work properly. Did that not come with the zip? Damn statingto forget a lot, u can get it from the outlook themes, just place it in the script folder
Tricky
trickydick
Postby sigel » Thu Dec 22, 2011 4:12 pm
ah so it's not just me.. yes, lots of files missing... you may want to re-upload the zip.. i've downloaded most of the missing js, accordian-facebookui.css is also missing so I changed it to one of the other ones in default.css .. you are also @importing niceform-default2.css but the file in the folder is actually niceform2-default.css .. (or reversed, forgot) so i had to manually fix that as well.
hope to get a new .zip soon, love the theme, thanks for your hard work.
sigel
Postby NuttySocrates » Mon Feb 06, 2012 11:04 pm
Thanks for the UI I love it ! One quick question though, I could not find the tricky's subsonic part in the head.jsp file. I am using the V2 of your UI. Any help editing that would be awesome !
Thanks !
NuttySocrates
Postby bondfreak » Mon Feb 20, 2012 2:24 pm
i also like this theme very much, but it looks a bit buggy since some of the scripts are missing and links are wrong. I would like to see a repack of the .zip file with all required files.
Great work Tricky! :)
NuttySocrates wrote:Thanks for the UI I love it ! One quick question though, I could not find the tricky's subsonic part in the head.jsp file. I am using the V2 of your UI. Any help editing that would be awesome !
Thanks !
It is in that file - last line ;)
bondfreak
Postby zuurkool » Fri Feb 24, 2012 9:19 am
This theme looks like some I want :-)
About the missing files being reported - can anyone confirm the zip has been repacked with *all* the missing files?
zuurkool
Postby bondfreak » Fri Feb 24, 2012 12:22 pm
zuurkool wrote:This theme looks like some I want :-)
It has not been repacked yet. you can find a bit of information about the missing things somewhere in this thread. Some minor changes to config files and jquery from the outlook theme. Does nevertheless not look like on the screenshots yet :(
Would be nice to know which addons i need to make it look like on the screens :)
bondfreak
Postby deejay2302 » Thu Mar 15, 2012 10:16 am
Thanks for your nice work....but...Can you upload files as zip-file to another filehoster with english or german language please? Your Download site does not work for me, and i can not read russian language. :(
My favorit is www.zippyshare.com :mrgreen:
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
