How to change art on Login Screen?
Postby rodan1967 » Tue Nov 22, 2011 4:55 am
Is there a easy way to change the login artwork and logo easily on the Subsonic login page? Would like to just replace it with something of my own but not really sure where to start.
rodan1967
Re: How to change art on Login Screen?
Postby Drefsab » Tue Nov 22, 2011 10:34 am
I guess how you would do this depends on the changes you want to make. Possibly one of the simplest ways would be to edit login.jsp which on a linux system would be located in /var/subsonic/jetty/2567/webapp/WEB-INF/jsp/ that file basically is what is displayed when you try to login.
Drefsab
Postby kleverbear » Tue Nov 22, 2011 9:10 pm
IF this page is modified, will it be over written when upgrading?
Ubuntu 10.04 LTS
Atom @ 1.60GHz, 4 cores 2Gb ram
6 Users
SubSonic 4.6 (build 2585)
2,575 artist
2,053 albums
16,090 songs
288.69GB (~4,484 hours)
kleverbear
Postby Drefsab » Wed Nov 23, 2011 6:36 pm
Yup almost certainly, so if you upgrade you would need to remod the page.
Drefsab
Postby kermit22 » Tue Nov 29, 2011 3:33 pm
If all you want to do is change the pictures on the login screen, go to C:\subsonic\jetty\####\webapp\icons and replace subsonic_white.png and subsonic_black.png with the pictures of your choosing.
End Result is this:
-My Subsonic Server-
OS: Windows Server 2016
Processor: Intel Xeon E5630
Memory: 8GB
2,098 artists
4,266 albums
39,450 songs
2,606 hours
kermit22
Postby degan6 » Sat Nov 23, 2013 9:09 am
In my experience it will not overwrite the new image.
degan6
