Change the titles below the cover art
Postby fanSte » Sat Nov 26, 2011 11:20 pm
I'm running the latest Subsonic and I want to change the title below the cover art.
For example in the screen below I want to change "26-11-11 maal gemodificeerd Sanctuary S04E08" to "Sanctuary S04E08" (just by removing the date and the modified text)
How can I do this?
Thank you,
fanSte.
fanSte
Re: Change the titles below the cover art
Postby MadEvil » Mon Nov 28, 2011 2:10 am
to do so you have many options:
1) tag your Files right
2) Rename simple your Source Files -> http://www.bulkrenameutility.co.uk/Screenshots.php
3) change it via Code enhancement (truncate Name) -> Change .\webapp\WEB-INF\jsp\coverArt.jsp
Example: Truncate [*] Year from Foldername
i hope that help you :D
Madsonic Developer
MadEvil
Postby BKKKPewsey » Mon Nov 28, 2011 3:41 am
That will not help the OP as he is showing the recently added tab which by default shows the creation date.
Its that which he wants to remove from the display (I think)
Changing filename or title tag will not help.
Postby califrag » Mon Nov 28, 2011 5:07 am
BKKKPewsey wrote:That will not help the OP as he is showing the recently added tab which by default shows the creation date.
yep BKK's right,
to answer the OP's question, open /WEB-INF/jsp/home.jsp
find lines 104-107 and remove them
104                               <c:if test="${not empty album.created}">
105                                   <fmt:formatDate value="${album.created}" dateStyle="short" var="creationDate"/>
106                                   <fmt:message key="home.created"><fmt:param value="${creationDate}"/></fmt:message>
107                               </c:if>
should remove the creation date from 'recently added'
califrag
Postby fanSte » Fri Dec 09, 2011 12:47 pm
califrag wrote:to answer the OP's question, open /WEB-INF/jsp/home.jsp
107                               </c:if>
Tnx man! It's solved. I've also managed to center the text, made the thumbs bigger and the title larger.
fanSte
Postby BKKKPewsey » Fri Dec 09, 2011 10:22 pm
Nice and your post let me know that Sanctuary Season 4 was available 8)
