Now Playing Only For 5 Minutes
Postby ytechie » Thu Jan 05, 2012 5:38 am
I know that this has been posted about before, but I couldn't find any of the posts. And yes, I searched for them :D
Here is how to remove a now playing entry after 5 minutes:
Locate and begin editing right.jsp. It can be found in the subsonic/jetty/[whateverYourBuildNumberIs]/webapp/WEB-INF/jsp.
Now, before I go any further, I want you to think. How does subsonic start showing the "minutes ago" text under an entry?
Well, there is a variable called minutesAgo and it says "if minutesAgo is more than 4, display 'minutes ago'"
It is this variable that we are going to hijack!
This is what the section of the file we are going to modify looks like unedited:
function getNowPlayingCallback(nowPlaying) {
            var html = nowPlaying.length == 0 ? "" : "<h2><fmt:message key="main.nowplaying"/></h2><table>";
            for (var i = 0; i < nowPlaying.length; i++) {
                html += "<tr><td colspan='2' class='detail' style='padding-top:1em;white-space:nowrap'>";
                if (nowPlaying[i].avatarUrl != null) {
                    html += "<img src='" + nowPlaying[i].avatarUrl + "' style='padding-right:5pt'>";
                html += "<b>" + nowPlaying[i].username + "</b></td></tr>"
                html += "<tr><td class='detail' style='padding-right:1em'>" +
                        "<a title='" + nowPlaying[i].tooltip + "' target='main' href='" + nowPlaying[i].albumUrl + "'><em>" +
                        nowPlaying[i].artist + "</em><br/>" + nowPlaying[i].title + "</a><br/>" +
                        "<span class='forward'><a href='" + nowPlaying[i].lyricsUrl + "' onclick=\"return popupSize(this, 'lyrics', 430, 550)\">" +
                        "<fmt:message key="main.lyrics"/>" + "</a></span></td><td style='padding-top:1em'>";
                if (nowPlaying[i].coverArtUrl != null) {
                    html += "<a title='" + nowPlaying[i].tooltip + "' rel='zoom' href='" + nowPlaying[i].coverArtZoomUrl + "'>" +
                            "<img src='" + nowPlaying[i].coverArtUrl + "' width='48' height='48'></a>";
                html += "</td></tr>";
                var minutesAgo = nowPlaying[i].minutesAgo;
                if (minutesAgo > 4) {
                    html += "<tr><td class='detail' colspan='2'>" + minutesAgo + " <fmt:message key="main.minutesago"/></td></tr>";
            html += "</table>";
            $('nowPlaying').innerHTML = html;
            prepZooms();
All we are going to do is put these lines:
if (minutesAgo < 5) {
right after these lines:
and a '}' right before this line:
html += "</table>";
So the result should look like:
            html += "</table>";
            prepZooms();
Enjoy!
ytechie
