Madsonic - Mashup Mod (old Support Thread)
Postby MadEvil » Wed Mar 14, 2012 2:50 am
Navigation
: MAIN | INFO | CHANGELOG | DOWNLOAD | ANNOUNCEMENTS
Madsonic has moved ...
THIS IS THE OLD SUPPORT THRED --> goto to new --> viewtopic.php?f=15&t=10445#p47048
best regards :D
Madsonic Developer
MadEvil
Re: Preview: Subsonic Mashup Mod
Postby jboy71 » Fri Mar 16, 2012 5:55 am
Looks like all the coders have approved. I would like to try this out, I really like they way you designed the site. When can we have access to this developement? Thanks! :D
jboy71
Postby compcentral » Fri Mar 16, 2012 6:32 pm
Yes. Looks good. Where is the download link? :)
compcentral
Postby JesterEE » Sun Mar 18, 2012 4:12 pm
Very nicely done! I hope some of your additions get pushed to the master branch!
-JesterEE
JesterEE
Postby Aktarus » Thu Apr 12, 2012 12:51 pm
It's look verry good .. The question is.. when can we expect to try this nice mod ???
Thank you :)
Aktarus
Postby Gonzo » Thu Apr 19, 2012 11:04 am
I'm looking forward for your mod.
I visit this thread several times a day to see if you updated your post :)
Gonzo
Postby MadEvil » Thu Apr 19, 2012 1:41 pm
Gonzo wrote:I'm looking forward for your mod.
wow .. several times a day ... respect :)
So .. try the Test-Release in the first Post!
best regards
Madsonic Developer
MadEvil
Re: Test: Subsonic Mashup Mod
Postby Gonzo » Thu Apr 19, 2012 1:45 pm
       ________           ________
     /  ______  \       /  ______  \
Gonzo
Postby Gonzo » Thu Apr 19, 2012 3:05 pm
I downloaded it, installed it on my windows computer, then uploaded the jetty directory and both war files to my linux machine and started it (using my old 4.6 database / settings / config)
I am aware that my setup is much different from yours, so please don't see my post as "flaming, uh, it's not working" but as a little bug report :)
some issues:
- the upload mod has a path hardcoded with "\", on linux "/" would be right
- (other issues resolved by turning on the cache in my firefox...)
Questions:
- Where can I find the logfile (on the website)
- Where is the extended DB Viewer?
suggestion:
- I would love the "new albums" view as default view (i patch it myself since several subsonic versions)
Edit: Found it in the personal settings, but I would like to define the global default
Feel free to contact me via PM if you need more information or want to have a look at my installation,
Gonzo
Gonzo
Postby MadEvil » Thu Apr 19, 2012 7:11 pm
Gonzo wrote:some issues:
Gonzo
*) i will fix this in the next build
Gonzo wrote:Questions:
Gonzo
*) The About and the Log-View can be found when you click on the logo in the left corner
*) also the DB-Viewer can be found on this Page (visible only if your user is admin) or with http://localhost/db.view
Gonzo wrote:suggestion:
Gonzo
*) yes the default view is random. I'll try to fix it.
best regards
Madsonic Developer
MadEvil
Postby jboy71 » Fri Apr 20, 2012 5:17 am
I am loving this alot!! Great work!!. I have been having an issue with the cover art staying put on the screen. I see them for a second, then they dissappear? I am using IE9 and I know it works when you switch to compatabiltiy mode but in compatability mode, the more link shows the playlist stretched across the screen. This issue (cover art dissappearing) was also in 4.6 and I have not found a sound solution to it. Compatablity mode does not seem to be an option as it is creating other issues with the more link. Any help with this is greatly appreciated.
jboy71
Postby MadEvil » Fri Apr 20, 2012 7:11 am
jboy71 wrote:I am loving this alot!! Great work!!. I have been having an issue with the cover art staying put on the screen. I see them for a second, then they dissappear? I am using IE9 and I know it works when you switch to compatabiltiy mode but in compatability mode, the more link shows the playlist stretched across the screen. This issue (cover art dissappearing) was also in 4.6 and I have not found a sound solution to it. Compatablity mode does not seem to be an option as it is creating other issues with the more link. Any help with this is greatly appreciated.
i'll fix this in the next build. then you don't need the IE9 compatability mode.
best regards
Madsonic Developer
MadEvil
Postby MadEvil » Fri Apr 20, 2012 1:49 pm
new Build
Changelog
FIX: Windows & Linux compatiblity in UploadPath
FIX: IE9 dont need compatiblity mode to view correct Coverart
NEW FEATURE: You can set in GenerallSettings the default listType Value for new Users
Madsonic Developer
MadEvil
Postby Gonzo » Fri Apr 20, 2012 3:35 pm
Fast Download and 'warfile only' - <3
uploadpath fix is working
thanks for the default listtype setting
Gonzo
Postby Gonzo » Fri Apr 20, 2012 3:41 pm
Question: according to your screenshots, the player itself should look different, more buttons. I still have the "plain old player" I used to have from stock-subsonic.
The Player loaded is 5.9: swfobject.embedSWF("/subsonic/flash/jw-player-5.9.swf", "placeholder", "340", "24", "9.0.0", false, flashvars, params, attributes);
Does this depend on the used theme? Or anything else I could look into?
Greetings,
Gonzo
Gonzo
Return to Madsonic
