APE transcoder
Postby delcypher » Sun Jul 11, 2010 11:27 pm
Hmm I'm using Subsonic 4.0.1 (stand-alone) on Arch linux using
FFmpeg version SVN-r23619
ffmpeg -version
Lame 3.98.4
lame --version
And upon testing it appears to work fine with me no web player (flash plug-in 10.1 r53 running in chromium) freezes at all using an mpc test file.
Although I didn't have any Monkey's Audio files to begin with so I had to do
MP3 -> WAV -> MPC
first using mac (Monkey's audio encoder) & ffmpeg but I don't expect it made a difference.
I also had to add mpc to the list of file extensions in Settings > General which I didn't figure out for quite a while.
If someone is willing to upload a test MPC file I can try that too.
For those who are running linux try running
tail -f /var/subsonic/subsonic.log
and trying to play an mpc file and watching the log output.
Seeing as I can get it working I'm thinking that there could be several possible causes
1.You may be using an old ffmpeg version
2. You may be using an old lame version
3. There may be a difference between the prebuilt subsonic 4.0.1 and stand-alone.
4. I may be using a different version of flash player than you are.
On a separate note it appears tagging is broken for mpc files (doesn't affect web player playback)
[2010-07-12 00:20:11,524] WARN JaudiotaggerParser - Failed to find cover art tag in /home/dan/music/mpc/01-mx-band.mpc
org.jaudiotagger.audio.exceptions.CannotReadException: No Reader associated to this extension: mpc
   at org.jaudiotagger.audio.AudioFileIO.readFile(AudioFileIO.java:281)
   at org.jaudiotagger.audio.AudioFileIO.read(AudioFileIO.java:148)
   at net.sourceforge.subsonic.service.metadata.JaudiotaggerParser.getArtwork(JaudiotaggerParser.java:274)
   at net.sourceforge.subsonic.service.metadata.JaudiotaggerParser.isImageAvailable(JaudiotaggerParser.java:251)
   at net.sourceforge.subsonic.service.MusicFileService.getBestCoverArt(MusicFileService.java:203)
   at net.sourceforge.subsonic.service.MusicFileService.listCoverArtRecursively(MusicFileService.java:183)
   at net.sourceforge.subsonic.service.MusicFileService.getCoverArt(MusicFileService.java:112)
   at net.sourceforge.subsonic.ajax.NowPlayingService.convert(NowPlayingService.java:94)
   at net.sourceforge.subsonic.ajax.NowPlayingService.getNowPlaying(NowPlayingService.java:73)
   at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:616)
   at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34)
   at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428)
   at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431)
   at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283)
   at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52)
   at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101)
   at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
delcypher
Postby Stab » Tue Jul 13, 2010 9:37 am
Up !
Something weird happened, I tried to access my subsonic server via IE8 with the latest flash player version, and I can play my mpc files !
But with firefox 3.6.6 with the latest flash player version, it's always the same issue : the song stops playing after 1 second :shock:
Here's the logs :
With IE8 :
[2010-07-13 09:32:55,399] INFO PlaylistInputStream - popol listening to "Le Tigre - Le Tigre/01 - Deceptacon.mpc"
[2010-07-13 09:32:55,408] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc] [-f] [wav] [-]
[2010-07-13 09:32:55,444] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [-] [-]
[2010-07-13 09:32:56,131] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
[2010-07-13 09:32:56,132] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-swscale --enable-postproc --enable-avfilter --enable-avfilter-lavf --enable-pthreads --enable-memalign-hack --cc=cc --extra-cflags=-I/usr/local/include/vorbis -I/usr/local/include --extra-ldflags=-L/usr/local/lib  --extra-libs=-pthread --disable-debug --disable-sse --disable-mmx --disable-libamr-nb --disable-libamr-wb --disable-libdirac --disable-libfaac --enable-libfaad --enable-libfaadbin --disable-libgsm --disable-vhook --enable-ipv6 --disable-libmp3lame --disable-libopenjpeg --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --enable-libvorbis --disable-x11grab --enable-libx264 --enable-libxvid
[2010-07-13 09:32:56,133] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil     49.15. 0 / 49.15. 0
[2010-07-13 09:32:56,134] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec    52.20. 0 / 52.20. 0
[2010-07-13 09:32:56,135] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat   52.31. 0 / 52.31. 0
[2010-07-13 09:32:56,135] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice   52. 1. 0 / 52. 1. 0
[2010-07-13 09:32:56,135] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter    0. 4. 0 /  0. 4. 0
[2010-07-13 09:32:56,136] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale     0. 7. 1 /  0. 7. 1
[2010-07-13 09:32:56,136] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc   51. 2. 0 / 51. 2. 0
[2010-07-13 09:32:56,137] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Mar  7 2010 00:34:41, gcc: 4.2.1 20070719  [FreeBSD]
[2010-07-13 09:32:56,162] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mpc, from '/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc':
[2010-07-13 09:32:56,163] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:03:04.55, start: 0.000000, bitrate: N/A
[2010-07-13 09:32:56,164] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mpc7, 44100 Hz, stereo, s16
[2010-07-13 09:32:56,166] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[2010-07-13 09:32:56,168] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[2010-07-13 09:32:56,168] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2010-07-13 09:32:56,168] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2010-07-13 09:32:56,170] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop encoding
[2010-07-13 09:32:56,188] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME: Can't get "TERM" environment string.
[2010-07-13 09:32:56,188] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME 3.97 32bits (http://www.mp3dev.org/)
[2010-07-13 09:32:56,189] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) CPU features: MMX (ASM used), 3DNow! (ASM used), SSE
[2010-07-13 09:32:56,189] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
[2010-07-13 09:32:56,189] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding <stdin> to <stdout>
[2010-07-13 09:32:56,189] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
[2010-07-13 09:32:56,675] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=     738kB time=4.28 bitrate=1411.3kbits/s
[2010-07-13 09:32:57,175] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    1121kB time=6.50 bitrate=1411.3kbits/s
[2010-07-13 09:32:57,706] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    1508kB time=8.75 bitrate=1411.2kbits/s
[2010-07-13 09:32:58,212] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    1890kB time=10.97 bitrate=1411.2kbits/s
[2010-07-13 09:32:58,716] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    2273kB time=13.19 bitrate=1411.2kbits/s
[2010-07-13 09:32:59,233] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    2786kB time=16.17 bitrate=1411.2kbits/s
[2010-07-13 09:32:59,767] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    3236kB time=18.78 bitrate=1411.2kbits/s
[2010-07-13 09:33:00,278] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    3618kB time=21.00 bitrate=1411.2kbits/s
[2010-07-13 09:33:00,797] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    4032kB time=23.41 bitrate=1411.2kbits/s
[2010-07-13 09:33:01,319] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    4451kB time=25.84 bitrate=1411.2kbits/s
[2010-07-13 09:33:01,830] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    4865kB time=28.24 bitrate=1411.2kbits/s
[2010-07-13 09:33:02,350] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    5252kB time=30.48 bitrate=1411.2kbits/s
[2010-07-13 09:33:02,877] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    5666kB time=32.89 bitrate=1411.2kbits/s
[2010-07-13 09:33:03,377] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    6107kB time=35.45 bitrate=1411.2kbits/s
[2010-07-13 09:33:03,878] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    6579kB time=38.19 bitrate=1411.2kbits/s
[2010-07-13 09:33:05,949] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    6881kB time=39.94 bitrate=1411.2kbits/s
[2010-07-13 09:33:06,464] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    7299kB time=42.37 bitrate=1411.2kbits/s
[2010-07-13 09:33:06,972] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    7776kB time=45.14 bitrate=1411.2kbits/s
[2010-07-13 09:33:07,494] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    8258kB time=47.93 bitrate=1411.2kbits/s
[2010-07-13 09:33:08,019] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    8739kB time=50.73 bitrate=1411.2kbits/s
[2010-07-13 09:33:08,551] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    9185kB time=53.32 bitrate=1411.2kbits/s
[2010-07-13 09:33:09,087] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    9666kB time=56.11 bitrate=1411.2kbits/s
[2010-07-13 09:33:10,468] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   10305kB time=59.82 bitrate=1411.2kbits/s
[2010-07-13 09:33:10,995] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   10755kB time=62.43 bitrate=1411.2kbits/s
[2010-07-13 09:33:11,495] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   10985kB time=63.76 bitrate=1411.2kbits/s
[2010-07-13 09:33:12,016] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   11201kB time=65.02 bitrate=1411.2kbits/s
[2010-07-13 09:33:12,519] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   11651kB time=67.63 bitrate=1411.2kbits/s
[2010-07-13 09:33:13,023] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   12195kB time=70.79 bitrate=1411.2kbits/s
[2010-07-13 09:33:13,546] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   12609kB time=73.20 bitrate=1411.2kbits/s
[2010-07-13 09:33:15,078] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   12960kB time=75.23 bitrate=1411.2kbits/s
[2010-07-13 09:33:15,623] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   13410kB time=77.84 bitrate=1411.2kbits/s
[2010-07-13 09:33:16,123] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   13860kB time=80.46 bitrate=1411.2kbits/s
[2010-07-13 09:33:16,639] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   14211kB time=82.49 bitrate=1411.2kbits/s
[2010-07-13 09:33:17,165] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   14657kB time=85.08 bitrate=1411.2kbits/s
[2010-07-13 09:33:17,671] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   15044kB time=87.33 bitrate=1411.2kbits/s
[2010-07-13 09:33:18,172] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   15345kB time=89.08 bitrate=1411.2kbits/s
[2010-07-13 09:33:18,678] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   15746kB time=91.40 bitrate=1411.2kbits/s
[2010-07-13 09:33:19,209] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   16227kB time=94.20 bitrate=1411.2kbits/s
[2010-07-13 09:33:19,728] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   16484kB time=95.69 bitrate=1411.2kbits/s
[2010-07-13 09:33:20,245] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   16898kB time=98.09 bitrate=1411.2kbits/s
[2010-07-13 09:33:20,780] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   17280kB time=100.31 bitrate=1411.2kbits/s
[2010-07-13 09:33:21,299] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   17537kB time=101.80 bitrate=1411.2kbits/s
[2010-07-13 09:33:21,836] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   17924kB time=104.05 bitrate=1411.2kbits/s
[2010-07-13 09:33:22,354] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   18306kB time=106.27 bitrate=1411.2kbits/s
[2010-07-13 09:33:22,873] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   18531kB time=107.57 bitrate=1411.2kbits/s
[2010-07-13 09:33:23,387] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   19008kB time=110.34 bitrate=1411.2kbits/s
[2010-07-13 09:33:23,896] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   19427kB time=112.77 bitrate=1411.2kbits/s
[2010-07-13 09:33:24,417] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   19872kB time=115.36 bitrate=1411.2kbits/s
[2010-07-13 09:33:24,918] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   20291kB time=117.79 bitrate=1411.2kbits/s
[2010-07-13 09:33:25,642] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   20705kB time=120.19 bitrate=1411.2kbits/s
[2010-07-13 09:33:26,152] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   21155kB time=122.80 bitrate=1411.2kbits/s
[2010-07-13 09:33:26,660] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   21569kB time=125.20 bitrate=1411.2kbits/s
[2010-07-13 09:33:27,186] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   22145kB time=128.55 bitrate=1411.2kbits/s
[2010-07-13 09:33:27,707] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   22752kB time=132.08 bitrate=1411.2kbits/s
[2010-07-13 09:33:28,239] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   23234kB time=134.87 bitrate=1411.2kbits/s
[2010-07-13 09:33:28,768] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   23652kB time=137.30 bitrate=1411.2kbits/s
[2010-07-13 09:33:29,268] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   24354kB time=141.37 bitrate=1411.2kbits/s
[2010-07-13 09:33:29,770] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   24993kB time=145.08 bitrate=1411.2kbits/s
[2010-07-13 09:33:30,288] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   25412kB time=147.51 bitrate=1411.2kbits/s
[2010-07-13 09:33:30,810] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   25794kB time=149.73 bitrate=1411.2kbits/s
[2010-07-13 09:33:31,344] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   26208kB time=152.14 bitrate=1411.2kbits/s
[2010-07-13 09:33:31,846] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   26627kB time=154.57 bitrate=1411.2kbits/s
[2010-07-13 09:33:32,373] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   27041kB time=156.97 bitrate=1411.2kbits/s
[2010-07-13 09:33:32,896] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   27554kB time=159.95 bitrate=1411.2kbits/s
[2010-07-13 09:33:33,417] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   27972kB time=162.38 bitrate=1411.2kbits/s
[2010-07-13 09:33:33,942] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   28386kB time=164.78 bitrate=1411.2kbits/s
[2010-07-13 09:33:34,448] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   28800kB time=167.18 bitrate=1411.2kbits/s
[2010-07-13 09:33:34,985] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   29250kB time=169.80 bitrate=1411.2kbits/s
[2010-07-13 09:33:35,496] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   29664kB time=172.20 bitrate=1411.2kbits/s
[2010-07-13 09:33:36,021] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   30276kB time=175.75 bitrate=1411.2kbits/s
[2010-07-13 09:33:36,588] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   30659kB time=177.97 bitrate=1411.2kbits/s
[2010-07-13 09:33:37,095] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   31073kB time=180.38 bitrate=1411.2kbits/s
[2010-07-13 09:33:37,603] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   31667kB time=183.82 bitrate=1411.2kbits/s
[2010-07-13 09:33:37,687] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=   31793kB time=184.56 bitrate=1411.2kbits/s
[2010-07-13 09:33:37,687] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) video:0kB audio:31792kB global headers:0kB muxing overhead 0.000135%
With firefox 3.6.6 :
[2010-07-13 09:35:13,399] INFO PlaylistInputStream - popol listening to "Le Tigre - Le Tigre/01 - Deceptacon.mpc"
[2010-07-13 09:35:13,410] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc] [-f] [wav] [-]
[2010-07-13 09:35:14,031] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [-] [-]
[2010-07-13 09:35:14,663] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
[2010-07-13 09:35:14,663] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-swscale --enable-postproc --enable-avfilter --enable-avfilter-lavf --enable-pthreads --enable-memalign-hack --cc=cc --extra-cflags=-I/usr/local/include/vorbis -I/usr/local/include --extra-ldflags=-L/usr/local/lib  --extra-libs=-pthread --disable-debug --disable-sse --disable-mmx --disable-libamr-nb --disable-libamr-wb --disable-libdirac --disable-libfaac --enable-libfaad --enable-libfaadbin --disable-libgsm --disable-vhook --enable-ipv6 --disable-libmp3lame --disable-libopenjpeg --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --enable-libvorbis --disable-x11grab --enable-libx264 --enable-libxvid
[2010-07-13 09:35:14,663] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil     49.15. 0 / 49.15. 0
[2010-07-13 09:35:14,663] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec    52.20. 0 / 52.20. 0
[2010-07-13 09:35:14,664] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat   52.31. 0 / 52.31. 0
[2010-07-13 09:35:14,664] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice   52. 1. 0 / 52. 1. 0
[2010-07-13 09:35:14,664] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter    0. 4. 0 /  0. 4. 0
[2010-07-13 09:35:14,664] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale     0. 7. 1 /  0. 7. 1
[2010-07-13 09:35:14,664] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc   51. 2. 0 / 51. 2. 0
[2010-07-13 09:35:14,664] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Mar  7 2010 00:34:41, gcc: 4.2.1 20070719  [FreeBSD]
[2010-07-13 09:35:14,721] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, mpc, from '/mnt/music2/L/Le Tigre/Le Tigre - Le Tigre/01 - Deceptacon.mpc':
[2010-07-13 09:35:14,722] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:03:04.55, start: 0.000000, bitrate: N/A
[2010-07-13 09:35:14,723] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: mpc7, 44100 Hz, stereo, s16
[2010-07-13 09:35:14,724] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[2010-07-13 09:35:14,725] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[2010-07-13 09:35:14,725] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2010-07-13 09:35:14,725] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Stream #0.0 -> #0.0
[2010-07-13 09:35:14,726] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop encoding
[2010-07-13 09:35:14,742] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME: Can't get "TERM" environment string.
[2010-07-13 09:35:14,742] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) LAME 3.97 32bits (http://www.mp3dev.org/)
[2010-07-13 09:35:14,742] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) CPU features: MMX (ASM used), 3DNow! (ASM used), SSE
[2010-07-13 09:35:14,743] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
[2010-07-13 09:35:14,743] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding <stdin> to <stdout>
[2010-07-13 09:35:14,743] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
[2010-07-13 09:35:15,254] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=     675kB time=3.92 bitrate=1411.3kbits/s
[2010-07-13 09:35:15,800] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size=    1089kB time=6.32 bitrate=1411.3kbits/s
Any ideas ?
Stab
Ugly fix
Postby delcypher » Wed Jul 14, 2010 10:17 pm
Okay I have a temporary fix for this which I've tested which appears to work but may break other things. You have been warned!
These are the instructions for the stand-alone install, don't ask me how to do it with your install because I'm not using it so figure it out yourself.
Okay I have an ugly fix for this problem with the web player using firefox. It doesn't entirely fix it because the song length continuously changes and the seekbar goes crazy but the song does play (I used a MPC - Monkey's Audio file to test this).
This ugly fix involves replacing the web player (JW 5.0.753) with a newer version JW 5.2.1151 (see http://developer.longtailvideo.com/trac/wiki/Player5ReleaseNotes)
1. Launch the subsonic server
2. Download the newer version of the JW player. It can be found at http://www.longtailvideo.com/jw/upload/mediaplayer.zip
3. Navigate to the folder /var/subsonic/jetty/1524/webapp/flash (it might not be exactly called that. Try the command
find /var/subsonic -name '*.swf'
if you can't find the directory containing the .swf file)
4. Rename jw-player-5.0.swf to jw-player-5.0.swf.old
5. Copy player.swf from the zip archive containing JW player to the directory and rename it jw-player-5.0.swf
6. Launch firefox (if you haven't already) and MAKE SURE YOU CLEAR THE CACHE!
7. Login to the subsonic web interface and right click the web player. You should see a menu appear. One menu option should be "About JW Player 5.2.1151". If so you've successfully installed the new JW player.
If you see "About JW Player 5.0.753" either you haven't deleted firefox's cache or you haven't overwritten the jw-player-5.0.swf file properly.
I'm not sure how permanent this fix is but I'm able to stream MPC files to the web player in firefox now. Although it misbehaves a little.
I hope this helps.
EDIT:
This ugly fix appears to break the seekbar and current time in songs when playing back transcoded mp3s.
delcypher
Postby mgrant » Thu Jul 15, 2010 7:30 pm
Thanks delcypher! This worked for me on .mpc, .ape & .m4b transcodes.
-mg
mgrant
Postby oeh » Mon Feb 07, 2011 5:45 pm
Regards
OEH ;-}
oeh
