Arcane wrote:This is great news!! I love it. But the player doesn't seem to want to play using Firefox on Linux. IE on windows seems to work just fine...
Arcane wrote:it seems to just be the Linux version of the flash player. Flash 10 was used in all tests. Strange though that the player works fine on the longtail video site in all browsers.
msobecki wrote:Noticed on the new webplayer that you now only have the ability to Stop and Pause tracks in the Playlist. In 3.5 you also had buttons to move backwards / forwards in the Playlist which I found very useful.
Is there a way I can enable these button in the longtailvideo plugin or is this something you would need to include in the next release.
sindre_mehus wrote:Arcane wrote:it seems to just be the Linux version of the flash player. Flash 10 was used in all tests. Strange though that the player works fine on the longtail video site in all browsers.
Hm, maybe it's a Javascript error. Can you please check if these examples work in Linux: http://www.longtailvideo.com/support/tu ... I-Examples (in particular "Combining External control and Listener feedback")
sindre_mehus wrote:For technical reasons, this is not as straight-forward, unfortunately. The Flash player's internal playlist always contains just the currently playing song (the actual playlist is handled by Javascript). The Flash player automatically hides the forwards/backwards buttons in this case.
Looks like it behaves the same way on the examples. The player works.. but the links below the player does not work. I see the same 'Player is undefined' error .
kdid wrote:However: When you play WMA files that is encoded with a lower bitrate than the bitrate you are transcoding to, then the player will believe that the song is shorter than what it really is.
