Made a new theme
Postby sindre_mehus » Thu Apr 29, 2010 6:31 am
thomasbruce wrote:one last theme added to the theme pack. hope you guys will enjoy them.
Thanks! Maybe it's just me (or my monitor), but I find the high contrast between the red text and the blue background a bit hard to look at.
Postby thomasbruce » Thu Apr 29, 2010 1:44 pm
fixed the colours in the last theme i added... (see screenshot)
thomasbruce
Postby sindre_mehus » Fri Apr 30, 2010 1:01 pm
Thanks! Added them all to Subsonic 4.
Postby Caleb » Sat May 15, 2010 2:28 pm
I'm using the Groove theme, and the font color on the lyrics popup (with the results) is black, just like the background, so it's not visible.
Caleb
Postby thomasbruce » Sun May 23, 2010 5:44 pm
Caleb wrote:I'm using the Groove theme, and the font color on the lyrics popup (with the results) is black, just like the background, so it's not visible.
hi, I've fixed that in all the themes,also some other minor fixes. The theme pack link is updated with the new ones.
I noticed that in the newest subsonic release the code for the scrollbars have been removed from the themes because there was a problem with the quick links in artist frame. if anyone know how to make the quick links work with the scrollbars. please let me know. it would be great to be able to have the themes fully functional without the default scrollbars that look horrible and are all over the place. the code for the scrollbars I've used is this:
body {
position: absolute;
top: 0;
left: 0;
bottom: 0;
right: 10px;
overflow-y: auto;
overflow-x: hidden;
html {
overflow-y: auto;
background-color: transparent;
::-webkit-scrollbar {
width: 10px;
height: 10px;
::-webkit-scrollbar-button:start:decrement,
::-webkit-scrollbar-button:end:increment {
height: 30px;
display: block;
::-webkit-scrollbar-track-piece {
background-color: #3b3b3b;
-webkit-border-radius: 6px;
::-webkit-scrollbar-thumb:vertical {
height: 50px;
background-color: #666;
border: 1px solid #eee;
thomasbruce
Re: Made a new theme
Postby VaSh » Thu Sep 01, 2011 2:43 pm
Hey! You're really cool in what u're doning. Keep going!
Few quastions
1) Is that the real font and icons size on the screens, you've attached? Cause mine is a bit bigger after activating theme. And it's not looks so charmy like on your screens (:
2) oh, that ugly scrolls!... where should u i put in css code, u've provided? i didnt get any config on windows machine for this. list of subsonic program files
$ pwd && ls | sed 's/ /\n/g'
/cygdrive/c/Program Files/Subsonic
Getting
Started.html
LICENSE.TXT
README.TXT
build_number.txt
log
subsonic-agent.exe
subsonic-agent.exe.vmoptions
subsonic-booter-jar-with-dependencies.jar
subsonic-service.exe
subsonic-service.exe.vmoptions
subsonic.url
subsonic.war
uninstall.exe
version.txt
3.14@314-PC /cygdrive/c/Program Files/Subsonic
VaSh
Postby BKKKPewsey » Thu Sep 01, 2011 6:01 pm
Should be in the root subsonic directory eg. c:\subsonic\jetty\xxxx\webapp\style\
Postby thomasbruce » Thu Sep 01, 2011 6:36 pm
BKKKPewsey wrote:Should be in the root subsonic directory eg. c:\subsonic\jetty\xxxx\webapp\style\
then find the theme folder and add the code to the CSS file in the theme you want to use it with
thomasbruce
Postby VaSh » Thu Sep 01, 2011 6:46 pm
oh crap (: missed this. thanks a lot guys.
giving it a push right away.
VaSh
Postby bebopblues » Tue Aug 14, 2012 8:37 pm
Stupid question, but how do I install this theme?
nevermind, realized it came with install text.
bebopblues
Previous
