Google Analytics
Google Analytics
Postby kissiesteve » Tue Sep 04, 2012 7:38 pm
Hey guys, new to the forum. I want to add google analytics to my subsonic page so i can keep track of page hits and ip addresses
I know almost nothing about java but i am ok with html. can someone give me instructions on where i can add the google code?
kissiesteve
Re: Google Analytics
Postby MadEvil » Tue Sep 04, 2012 9:03 pm
hi,
Just edit your \subsonic\jetty\<####>\webapp\script\scripts.js and ad this code
replace the UA-00000000-0 with your account id
that's all, this should work. mine does :wink:
/// Google
  var _gaq = _gaq || [];
  _gaq.push(['_setAccount', 'UA-00000000-0']);
  _gaq.push(['_trackPageview']);
  (function() {
    var ga = document.createElement('script');
    ga.type = 'text/javascript';
    ga.async = true;
    ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
    var s = document.getElementsByTagName('script')[0];
    s.parentNode.insertBefore(ga, s);
best regards
Madsonic Developer
MadEvil
Postby kissiesteve » Wed Sep 05, 2012 4:10 pm
Thank you so much, worked like a charm. i pasted that right at the top. Thanks for your time
kissiesteve
Postby MadEvil » Wed Sep 05, 2012 7:25 pm
kissiesteve wrote:Thank you so much, worked like a charm. i pasted that right at the top. Thanks for your time
no problem :wink:
Madsonic Developer
MadEvil
Users browsing this forum: No registered users and 41 guests
