HTTP ERROR: 503
HTTP ERROR: 503
Postby utbluesman » Tue Sep 23, 2008 11:00 pm
First, have to say, great application.
Have been using 3.5beta1 and it's really quite good. Well done.
The server has been running 3.5beta1 for a week or more now without issue.
Suddenly, today, I get.
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
I'm running Subsonic on Windows XP Pro on an older 1.3GHz Pentium with 512Mb or RAM.
I've restarted the PC, uninstalled, reinstalled Subsonic, uninstalled the 3.5beta1 and reinstalled with 3.4.
Whether I try to access across the network, or even localhost, I still get the HTTP ERROR: 503.
I hope this isn't some boneheaded thing I've done.
Looking forwarded to any help.
Thanks again, great app.
utbluesman
Postby sindre_mehus » Fri Sep 26, 2008 7:06 am
Sorry, I don't know what this is, but you can try to stop Subsonic, remove c:\subsonic (NOTE: You will loose all settings), and start it again.
Thanks Sindre
Postby utbluesman » Fri Sep 26, 2008 12:16 pm
Just as a heads up, I ended up uninstalling the Beta, then crawling through the registry deleting all references to Subsonic, then deleting c:\subsonic as well.
After a reboot, I reinstalled the Beta and all works well.
Not the prettiest solution, but it's up and running.
Thanks for the quick response.
Again, very cool application.
utbluesman
Same problem here, some details
Postby djiest » Sat Feb 14, 2009 7:33 am
Hi, I have the same problem as utbluesman. I've looked into the log files and event viewer. Below are the details. Maybe with that information you can find a solution, without me having the deinstall everything.
In c:\subsonic\subsonic.log:
[2009-02-14 08:18:36,020] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token: [null]
I can send the detailed log file if you wish.
Regards
Joost
djiest
Postby sindre_mehus » Sun Feb 15, 2009 8:18 am
Sounds like a corrupt database. Yes, please send me the log file if you still have it.
Postby sindre_mehus » Tue Mar 17, 2009 8:13 am
Sorry, I forgot about this.
The log file didn't reveal anything more. Can't think of any other work-around than resetting the database:
o Stop Subsonic.
o Remove c:\subsonic\db
o Start Subsonic.
You will of course loose your settings.
Postby djiest » Tue Mar 17, 2009 1:39 pm
Thanks Sindre,
That indeed did the trick. I'm glad that I did not have to dive into the registry :shock:
Joost
djiest
Postby mapes » Wed May 20, 2009 11:48 pm
Just ran into this on the standalone 3.7 beta1. I'm running on linux debian. I'll delete and try from scratch. Just a heads up
mapes
Postby denney » Tue Jun 02, 2009 6:37 pm
I just experienced this problem with 3.7 beta 1 on Ubuntu 9.04. I'd say it was due to an unclean reboot of the computer which caused the database to become corrupt. :cry:
Deleting the "db" folder and running Subsonic again fixed the problem. I've taken a backup of the "db" folder after setting all the settings again to safeguard against this next time. :oops:
denney
not working for me!
Postby yoaj » Thu Nov 19, 2009 7:32 pm
same problem: HTTP ERROR: 503
deleted db, rerun subsonic.sh and same error.
completely deleted all subsonic files and reinstalled.. same error.
:shock: !?
yoaj
HTTP ERROR: 503 SERVICE_UNAVAILABLE RequestURI=/index.view
Postby triumph » Thu Dec 24, 2009 6:54 pm
I am having the same error on FreeBSD 7.2 tomcat6.
It ran after the install but would not play music in the web interface although the log files showed the song had started.
I would click the play icon and nothing would happen (tried different browsers/computers).
After a reboot I then started getting this error.
triumph
update
Postby triumph » Thu Dec 24, 2009 8:39 pm
Moved subsonic.war file back to subsonic root and restarted tomcat, apache and subsonic and it all works including the play button.
I will be donating shortly.
triumph
Postby mchyde » Thu Feb 04, 2010 6:16 am
Having the same problem on a Windows Vista machine. I can't locate the DB to delete it. Any clues?
mchyde
Postby Randrage » Mon Apr 19, 2010 8:44 pm
mchyde wrote:Having the same problem on a Windows Vista machine. I can't locate the DB to delete it. Any clues?
I use Win7 x64 and the db folder by default was located at: C:\subsonic\db
I use 3.9 (build 1335) – February 9, 2010
I, too, had this 503 error after about a week of use and had to delete the db files to fix the problem. Hopefully this isn't a recurring issue because wiping settings every week or so to fix it would kinda suck.
Randrage
Postby donjulien » Thu Mar 03, 2011 10:44 pm
I had a similar issue (Windows 7, 32 bit, Subsonic 4.4), and yes: deleting the directory made the trick. The failure came after a sudden reboot, so it's easy to see that Subsonic's db got damaged at that moment.
Seeing that this issue has happened to many, I'm thinking it might be a good idea to keep some sort of auto-backup of the db which would kick in should the dreaded error 503 happen. I know: the db regenerates automatically, but still, a) it takes time, and b) you also lose your configs.
What do you think, Sindre?
donjulien
