Using JW FLV player, but playlists don't work
Postby volcs0 » Wed Nov 12, 2008 4:13 pm
I got the JW_FLV media player to work, and it is terrific - I like being able to seek through songs.
The problem? Playlists don't work. It only plays the first song and then stops.
When I switch back to the original player, the playlists work.
Maybe there is something wrong with the way the playlist is generated. I've checked out the XSPF specs, and I don't see anything wrong with it.
Any other ideas?
Thanks.
volcs0
Postby volcs0 » Thu Nov 13, 2008 2:55 am
Well, it seems to be the player. I can advance through the playlist, so I think it is OK. The first song autostarts. But it will never advance from one song to the next.
Ideas?
volcs0
Postby volcs0 » Thu Nov 13, 2008 3:10 am
OK. got it. Maybe this will help someone.
1. Download the FLV player here:
http://www.jeroenwijering.com/?item=JW_FLV_Player
I used 4.2
Place player.swf and swfobject.js in this folder:
/var/subsonic/jetty/webapp/flash
2. Open and edit:
/var/subsonic/jetty/webapp/WEB-INF/jsp/webPlayer.jsp
Add this to the <script> section (or something like it):
<script type="text/javascript">
   var so = new SWFObject('/embed/player.swf','mpl','470','470','9');
   so.addParam('allowscriptaccess','always');
   so.addParam('allowfullscreen','false');
   so.addParam('flashvars','&playlist=bottom');
   so.write('player');
</script>
3. Take out this line:
<c:url var="playerUrl" value="/flash/xspf_player.swf?playlist_url=${playlistUrl}&autoplay=true&autoload=true"/>
and replace it with:
<c:url var="playerUrl" value="/flash/player.swf?playlist_url=${playlistUrl}&autostart=true"/>
Note that you are mainly just changing the name of your flash player to the new FLV one.
4. Replace the <embed> tag with this:
    <embed src="${playerUrl}" quality="high" bgcolor="#E6E6E6" name="xspf_player" allowscriptaccess="sameDomain"
           type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"
           align="middle" height="${height}" width="${width}" flashvars="file=${playlistUrl}&repeat=list&autostart=true&playlist=none&searchbar=false&autoscroll=false&displaywidth=130&overstretch=true&thumbsinplaylist=false&showicons=false&fullscreen=false"></embed>
The "repeat=list" was the variable that was need to enable the playlist to go from one item to the next. Without it, it just plays one song.
5. Save and close.
6. Open and edit
/var/subsonic/jetty/webapp/WEB-INF/jsp/xspfPlaylist.jsp
Change the <track> section to:
<track>
<location>${streamUrl}</location>
<image>${coverArtUrl}</image>
<title>${song.musicFile.metaData.artist} - ${song.musicFile.title}</title>
<meta rel="type">mp3</meta>
</track>
7. Reload your Subsonic page. Note that you do not need to stop and restart your Subsonic instance.
8. Enjoy your new player .
I know a lot of what I did is probably redundant/superfluous, but I'm just happy to get it working finally, and I don't want to play with every last variable. Feel free to post here or email or PM me with questions about this. Also, I read somewhere that the FLV player will be auditioned in 3.6, so this may all be moot in a few weeks.
volcs0
Postby Kaniass » Mon Nov 17, 2008 12:58 am
You can see this topic: http://forum.subsonic.org/forum/viewtopic.php?t=1265
It seems to work for them but I did their procedure and doesn't work anymore :cry:
Please try and let us know.
Kaniass
Kaniass
Postby volcs0 » Mon Nov 17, 2008 2:37 am
Kaniass wrote:You can see this topic: http://forum.subsonic.org/forum/viewtopic.php?t=1265
Kaniass
Yup. That was my starting point for this adventure. The settings in that thread do not work. The modifications I've made above do work. Perhaps the code in that thread was specific for earlier versions of either JF FLV media player (eg. version 2) or an earlier version of Subsonic. In any case, that I have outlined above should work.
volcs0
Postby Kaniass » Mon Nov 17, 2008 11:41 pm
Yep but unfortunately not working for me :(
The player is displayed but..... empty.
An idea?
Kaniass
Postby volcs0 » Tue Nov 18, 2008 12:11 am
Kaniass wrote:Yep but unfortunately not working for me :(
An idea?
Did you follow my steps exactly as outlined above in my post? The directions in that linked thread will not work for the software versions I posted. I also had a blank player for a long time - until I got the flash vars just right - and I put the correct javascript in the top of my file. Go back and make sure you did everything according to my instructions. If that doesn't work, let me know.
Also, I read somewhere in these forums that this player will be included as an option in the next version of Subsonic, so it might be worth waiting for that.
volcs0
Rhaaaa !!!
Postby Kaniass » Tue Nov 18, 2008 12:48 am
:cry: I redo it again => Still the same :cry:
My webPlayer.jsp:
<%@ page language="java" contentType="text/html; charset=utf-8" pageEncoding="iso-8859-1" %>
<html>
<head>
<%@ include file="head.jsp" %>
<title>Subsonic</title>
<c:set var="width" value="600"/>
<c:set var="height" value="155"/>
<script type="text/javascript" src="<c:url value="/script/scripts.js"/>"></script>
<script type="text/javascript" language="javascript">
function detach() {
popupSize("webPlayer.view?detached=", 'player', ${width + 20}, ${height + 60});
location.href = "playlist.view?";
</script>
<%-- For JW FLV Web Player --%>
so.write('player');
</script>
<%-- End For JW FLV Web Player --%>
</head>
<body class="bgcolor2" <c:if test="${model.detached}">onload="window.focus();window.moveTo(300, 200);"</c:if>>
<c:if test="${not model.detached and not model.default}">
<table><tr>
<td style="padding-right:2em"><div class="back"><a href="playlist.view?"><fmt:message key="webplayer.back"/></a></div></td>
<td style="padding-right:2em"><div class="forward"><a href="javascript:detach()"><fmt:message key="webplayer.detach"/></a></div></td>
</tr></table>
</c:if>
<c:url var="playlistUrl" value="/xspfPlaylist.view">
<%-- Hack to force Flash player to reload playlist. --%>
<c:param name="dummy" value="${model.dummy}"/>
</c:url>
<%-- End JW FLV the Web Player --%>
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
codebase="http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=7,0,0,0"
width="${width}" height="${height}">
<param name="allowScriptAccess" value="sameDomain"/>
<param name="movie" value="${playerUrl}"/>
<param name="quality" value="high"/>
<param name="bgcolor" value="#E6E6E6"/>
</object>
<p style="text-align:center;margin-top:1em">
<a href="javascript:self.close()">[<fmt:message key="common.close"/>]</a>
</p>
</c:if>
</body>
</html>
My xspfPlaylist.jsp
<?xml version="1.0" encoding="utf-8"?>
<%@ include file="include.jsp" %>
<%@ page language="java" contentType="text/xml; charset=utf-8" pageEncoding="iso-8859-1" %>
<playlist version="0" xmlns="http://xspf.org/ns/0/">
<trackList>
<c:forEach var="song" items="${model.songs}">
<sub:url value="/stream" var="streamUrl">
<sub:param name="path" value="${song.musicFile.path}"/>
</sub:url>
<sub:url value="coverArt.view" var="coverArtUrl">
<sub:param name="size" value="200"/>
<c:if test="${not empty song.coverArtFile}">
<sub:param name="path" value="${song.coverArtFile.path}"/>
</c:if>
</sub:url>
<track>
</track>
</c:forEach>
</trackList>
</playlist>
I am desperate but never mind I will wait the next version !
Kaniass
Kaniass
Postby volcs0 » Tue Nov 18, 2008 12:50 am
If you want to PM me your email address, I'd be happy to send you my modified files.
volcs0
Postby volcs0 » Wed Nov 19, 2008 1:25 pm
volcs0 wrote:If you want to PM me your email address, I'd be happy to send you my modified files.
I tried sending you the files, but I got this error:
XXXXXX@XXXXX.XXX.XXX (your email address here)
No space left on device:
error while writing to tmp/1227100833.28955.XXXX.XXXX.XX:
retry timeout exceeded
Here are my files below, just as I have them.
webPlayer.jsp
<html>
<head>
        function detach() {
    </script>
   <script type="text/javascript" src="/embed/swfobject.js"></script>
   </script>
</head>
    <table><tr>
    </tr></table>
</c:if>
</c:url>
           align="middle" height="${height}" width="${width}" flashvars="file=${playlistUrl}&repeat=list&playlist=none&autostart=true&searchbar=false&autoscroll=false&displaywidth=130&overstretch=true&thumbsinplaylist=false&showicons=false&fullscreen=false"></embed>
</object>
    </p>
</c:if>
</body>
</html>
xspfPlaylist.jsp
<playlist version="1" xmlns="http://xspf.org/ns/0/">
<trackList>
</sub:url>
</c:if>
</sub:url>
<track>
</track>
</c:forEach>
</trackList>
</playlist>
volcs0
Postby Kaniass » Wed Nov 19, 2008 11:23 pm
Thank you for your help but it doesn't work anymore.
I dont know, maybe, its because I am on Vista.
I give up :(
Kaniass
Postby aphuey » Wed Nov 19, 2008 11:52 pm
Would anyone be open to me seeing their implementation of the FLV Player on their site? My interest is piqued but I'd like to see it before I take the time to implement it (not even sure that I'm capable of implementing, but I might give it a shot). Even just a screenshot would be great!
Ben
aphuey
Postby gillespam » Mon Nov 24, 2008 10:32 am
aphuey wrote:Would anyone be open to me seeing their implementation of the FLV Player on their site? My interest is piqued but I'd like to see it before I take the time to implement it (not even sure that I'm capable of implementing, but I might give it a shot). Even just a screenshot would be great!
Ben
There you go :
- The track being played is the first one - with the grey background.
- The track with the white background is selected (mouse pointer on it, only the cursor doesn't appear).
Neat features :
- You can scroll throught the playlist loaded in the player with your mouse wheel.
- Clicking the artwork in the player will pause/resume playing.
I followed those instructions (server = linux) and it worked like a charm - I kept the custom colors as they matched the theme I choosed.
gillespam
JW flash player
Postby koboabe » Wed Nov 26, 2008 6:46 am
I was able to get the player embedded, but I cannot view playlists
when i hit pause the player shows album art, but otherwise it is just an empty black screen
how do I enable the file list and album art like the screenshot above
my xspfplaylist is below
    <trackList>
    </sub:url>
        </c:if>
    </sub:url>
        <track>
</track>
</c:forEach>
    </trackList>
</playlist>
koboabe
its working with 3.16
Postby koboabe » Thu Nov 27, 2008 12:47 am
so I got it sorted out
this does not work with JW FLV Player 4.2, but it is working great with 3.16
koboabe
