Subsonic don't play any playlists and chrashes
Postby christer.oberg » Mon Feb 24, 2014 4:05 pm
Error
Message PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
Java version Oracle Corporation 1.7.0_51
Server jetty-6.1.x
Memory Used 56 of 87 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:138)
at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:128)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:154)
at net.sourceforge.subsonic.controller.MainController.getMediaFiles(MainController.java:148)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:64)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
... 62 more
christer.oberg
Re: Subsonic don't play any playlists and chrashes
Postby alphawave7 » Mon Feb 24, 2014 10:19 pm
Corrupt database. Stop service, delete subsonic/settings/subsonic.data, restart service to rebuild database. If no joy, repeat above but delete entire db directory. You will need to re-enter your user data, however. :(
Postby christer.oberg » Tue Feb 25, 2014 10:33 am
I succeded to solve the problem by reinstalling Java and reboot the file server, puuh :)
christer.oberg
Postby alphawave7 » Wed Feb 26, 2014 5:03 am
christer.oberg wrote:I succeded to solve the problem by reinstalling Java and reboot the file server, puuh :)
So this saved all your settings? That's great news! 8)
Users browsing this forum: No registered users and 50 guests
