Simple start/stop shell-script
Tutorials, tips and tricks.
Postby wintermute » Thu Feb 05, 2009 6:54 am
Nothing fancy but maybe useful for someone.
#!/bin/bash
PID=""
function get_pid {
   PID=`ps ax |grep java |grep subsonic |cut -d " " -f 1`
function stop {
   get_pid
   if [ -z $PID ]; then
      echo "Subsonic is not running."
      exit 1
   else
      echo -n "Stopping Subsonic.."
      kill $PID
      sleep 1
      echo ".. Done."
   fi
function start {
   get_pid
      echo  "Starting Subsonic.."
      /var/subsonic/subsonic.sh
      get_pid
      echo "Done. PID=$PID"
   else
      echo "Subsonic is already running, PID=$PID"
   fi
function restart {
   echo  "Restarting Subsonic.."
   get_pid
      start
   else
      stop
      start
   fi
function status {
   get_pid
      exit 1
   else
      echo "Subsonic is running, PID=$PID"
   fi
case "$1" in
   start)
      start
   stop)
      stop
   restart)
      restart
   status)
      status
      echo "Usage: $0 {start|stop|restart|status}"
esac
wintermute
Postby drewkeller » Sat Jun 13, 2009 4:32 am
Here's one that can start/stop/restart/status without using terminal commands. Requires the zenity package, which I think is fairly common.
I haven't figured out a good way to get a sudo prompt if needed, although another script could ask for sudo password and then pass it to this script as described at http://techrepublic.com.com/5208-12853- ... ID=2541628
#!/bin/bash
PID=""
function get_pid {
function stop {
      echo "# Stopping Subsonic..."
      get_pid
      until [ -z $PID ]; do
         kill $PID; sleep 1
         get_pid
      done
      echo "# Subsonic stopped."; sleep 1
   zenity --progress --pulsate
function start {
      echo "# Starting Subsonic..."
      get_pid
      /var/subsonic/standalone/subsonic.sh | $ZENITY
      echo "# " $ZENITY
      while [ -z $PID ]; do
         get_pid; sleep 1
      done
      get_pid;
      echo "# Subsonic started. PID = " $PID
get_pid
   ans=$(zenity --list \
      --text "Subsonic is not running. What do you want to do?" \
      --radiolist \
      --column "" --column "Action" \
      TRUE "Start Subsonic")
   case $ans in
      "Start Subsonic")
         start
   esac
else
      --text "Subsonic is running with PID=$PID. What do you want to do?" \
      --radiolist \
      TRUE "Restart Subsonic" \
      FALSE "Stop Subsonic")
   case $ans in
      "Restart Subsonic")
         stop
         start
      "Stop Subsonic")
         stop
   esac
fi
exit 0
drewkeller
Postby wintermute » Sat Jun 13, 2009 5:17 am
How about gksu / gksudo?
I updated my script recently (using the PID file now and fixed some other quirks), I'll post it soon.
5.257 artists
5.902 albums
69.903 songs
458.50 GB (~ 7.122 hours)
wintermute
Postby WannaBeGeekster » Sat May 29, 2010 4:45 pm
I would still be curious to see the changes you have made? Did you just re-edit your last post and I didn't notice?
WannaBeGeekster
Re: Simple start/stop shell-script
Postby Linkz57 » Mon Jan 16, 2012 12:50 am
To future Googlers, I found this form looking for a simple way to manually start and stop the Subsonic service on Linux. The easiest way I found to do that is:
sudo service subsonic restart
sudo service subsonic start
sudo service subsonic stop
sudo service subsonic status
This works like a charm on my 32-bit Ubuntu 11.10, hope it helps.
Linkz57
Postby ytechie » Mon Jan 16, 2012 1:14 am
Yup. That is how I run my subsonic services.
ytechie
Postby ebasta » Sat Aug 16, 2014 7:57 pm
Linkz57 wrote:To future Googlers, I found this form looking for a simple way to manually start and stop the Subsonic service on Linux. The easiest way I found to do that is:
This future Googler thanks you in the past!
ebasta
Return to Tutorials
