My Settings for Transcoding in Ubuntu 8.10 (Intrepid)
Postby jeremyh » Thu Feb 05, 2009 3:30 pm
Ok, I had trouble setting some of these up under Ubuntu 8.10 (Intrepid), so I thought I would post my settings. I only included the ones I tested with our music library:
  • wav > mp3
    - Step 1: lame -b %b -S %s -
  • ogg > mp3
    - Step 1: oggdec -Q %s -o -
    - Step 2: lame -b %b - -
  • wma > mp3*
    - Step 1: wma2mp3 %s %b
  • flac > mp3
    - Step 1: flac -c -s -d %s
  • m4a > mp3
    - Step 1: faad -q -w -f 2 %s
    - Step 2: lame -r -b %b - -
  • mpc > mp3**
    - Step 1: mppdec --wav --silent %s -
* Setting up wma>mp3 required creating the wma2mp3 script and loading the libavcodec-unstripped via synaptic.
Here are the contents of wma2mp3.sh (Thanks Ikyo):
#!/bin/bash
song=$1
bitrate=$2
ffmpeg -i "$song" -f mp3 -ab $bitrate - 2>/dev/null
** Had to manually load mppdec from http://www.musepack.net/index.php?pg=lin (used version 1.95z2)
Thanks Sindre for a great product! It works wonderfully and I appreciate your efforts!
FYI we are running Ubuntu 8.10 64-bit version, using Subsonic 3.6.
jeremyh
Postby RXWatcher » Fri Feb 06, 2009 5:28 pm
Are you using the subsonic 3.6 release or a beta? if using the release how did you install the lame into the subsonic transcoding dir? Just make a symbolic link?
-Jim
RXWatcher
Postby RXWatcher » Fri Feb 06, 2009 5:37 pm
nevermind..creating the symbolic link worked.
RXWatcher
Postby jeremyh » Fri Feb 06, 2009 9:22 pm
You already answered, but yes, just symbolic links to get it working and I edited the original message to show that we are using 3.6 (full release from 1 Feb 2009).
I also put the wma2mp3 script in the /var/subsonic/transcode directory because nothing else on the machine needs it.
jeremyh
