Running subsonic standalone as daemon automatically on Linux
Tutorials, tips and tricks.
Postby jigsaw » Sun Mar 08, 2009 3:39 pm
Hi all
I realized shortly after completing this that wintermute already posted a bash-script for starting subsonic. However personally I prefer to have all services running as dedicated users to prevent any security breaches and such on my server. No offense to wintermute :)
Here's at least how Subsonic is handled by my system, free for anybody to use :)
Subsonic is started automatically by init at boot time on runlevels 3-5 run as the user subsonic
This is done without modifying the original subsonic.sh at all to avoid having to do updates after upgrading Subsonic
PS: However some changes to subsonic.sh could improve the init-script somewhat
init-script put in /etc/init.d/subsonic
#!/bin/sh
# chkconfig: 345 99 05
# /etc/init.d/subsonic
# Description: Linux startup-script for Subsonic standalone
[ ! -d /usr/bin ] && exit
# On RedHat AS 3 and above, use runuser rather than su
SU="su"
if [ -f "/etc/redhat-release" -a -x "/sbin/runuser" ]; then
    SU="runuser"
fi
if [ -f "/etc/redhat-release" ]; then
        LOCKFILE=/var/lock/subsys/subsonic
fi
PATH="$PATH:/bin:/usr/bin"
export PATH
SUBSONIC_USERNAME=subsonic
SERVICENAME="Subsonic Media Streamer"
SUBSONIC_HOME="/var/subsonic/"
# Source function library.
. /etc/rc.d/init.d/functions
# Functions for starting and stopping subsonic
start() {
        echo -n $"Starting $SERVICENAME: "
        # Start subsonic and pipe any output to syslog ( then there's no need to modify subsonic.sh at all )
        $SU - "$SUBSONIC_USERNAME" -s /bin/sh -c "$SUBSONIC_HOME/subsonic.sh" | logger -p daemon.info -t subsonic
        # Check if subsonic started since we are not getting RETVAL from subsonic.sh
        getpid
        if [ $PID ]; then
            success && RETVAL=0
        else
            failure && RETVAL=1
        fi
        echo
        [ $RETVAL = 0 ] && touch $LOCKFILE
        return $RETVAL
stop() {
        echo -n "Stopping $SERVICENAME: "
        kill $PID
        # Check if subsonic terminated since we are not getting RETVAL from kill ( killproc with pidfile would solve this )
        sleep 1
        getpid
        if [ $PID ]; then
            failure && RETVAL=1
        else
            success && RETVAL=0
        fi
        echo
        [ $RETVAL = 0 ] && rm -f $LOCKFILE
        return $RETVAL
status() {
        if [ $PID ]; then
             echo -n "$SERVICENAME is running.. Found PID $PID"
        else
             echo -n "$SERVICENAME is not running.."
        fi
        echo
getpid() {
      # Using a pidfile would be better, but would have to modify subsonic.sh to do that, so for now..
        PID=`ps -u $SUBSONIC_USERNAME -f | grep java | grep subsonic-booter-jar-with-dependencies.jar | awk '{print $2}' `
RETVAL=0
# See how we were called.
case "$1" in
  start)
   # Get the PID if Subsonic is running
   getpid
        if [ $PID ]; then
            status
        else
            start
        fi
  stop)
   getpid
        if [ $PID ]; then
            stop
        else
            status
        fi
  status)
   getpid
        status
  restart)
        stop
        start
        echo "Usage: subsonic {start|stop|status|restart}"
        exit 1
esac
exit $RETVAL
To setup the subsonic user and register the init-script
sudo adduser subsonic -c "Subsonic Media Streamer" -d /var/subsonic -M -s /sbin/nologin
sudo chown -R subsonic.subsonic /var/subsonic
sudo chmod og+x /etc/init.d/subsonic
sudo chkconfig --add subsonic
Example of usage
$ sudo service subsonic
$ sudo service subsonic status
Subsonic Media Streamer is not running..
$ sudo service subsonic start
Starting Subsonic Media Streamer:                          [  OK  ]
Subsonic Media Streamer is running.. Found PID 31136
$ sudo service subsonic stop
Stopping Subsonic Media Streamer:                          [  OK  ]
jigsaw
Postby sindre_mehus » Mon Mar 09, 2009 12:51 pm
Very nice, jigsaw, thank you!
Feel free to suggest modifications to subsonic.sh to make it easier to integrate with scripts like this.
Postby jigsaw » Mon Mar 09, 2009 11:16 pm
sindre_mehus wrote:Feel free to suggest modifications to subsonic.sh to make it easier to integrate with scripts like this.
Well, certainly :)
By adding this code-block in the end of subsonic.sh the init-script could be simpler and more like the standards ( at least as far as I can tell from init scripts delivered along with apps like Apache, Tomcat etc )
case $1 in
            --pidfile=?*)
                  PIDFILE=${1#--pidfile=}
esac
# Write pid to pidfile if it is defined, if PIDFILE is not defined, we ignore this part
if [ $! -a $PIDFILE ]; then
    echo $! > ${PIDFILE}
elif [ ! $! ]; then
    echo
    echo "Did not get PID from startup.. Check logs for error.."
    exit 1
fi
PS: I also removed the echo-lines from subsonic.sh, as the init-script provides sufficient feedback at startup and shutdown.
The init-script would then need to be like this
#!/bin/sh
SU="su"
    SU="runuser"
fi
fi
export PATH
USER=subsonic
PIDFILE="$SUBSONIC_HOME/subsonic.pid"
PROG="$SUBSONIC_HOME/subsonic.sh"
OPTIONS="--pidfile=${PIDFILE}"
start() {
        echo -n "Starting $SERVICENAME: "
        # Start subsonic
        daemon --pidfile=$PIDFILE --user=$USER $PROG $OPTIONS
   RETVAL=$?
        echo
        return $RETVAL
stop() {
        killproc -p $PIDFILE
   RETVAL=$?
        echo
        return $RETVAL
status() {
        if [ -s $PIDFILE ]; then
             echo -n "$SERVICENAME is running.."
        else
        fi
        echo
RETVAL=0
case "$1" in
  start)
            status
        else
            start
        fi
  stop)
            stop
        else
            status
        fi
  status)
        status
  restart)
        stop
        start
        exit 1
esac
exit $RETVAL
The last thing I'm not too happy with is the fact that I had to create 5-6 variables in the init-script. This could seem a bit messy as some of the init-variables are in subsonic.sh and then some are in the init-script. I guess one option would be to have all the variables in the subsonic.properties file ( or maybe a subsonic.env file? ) Then both subsonic.sh and the init-script could source that file.
jigsaw
Postby Pathduck » Thu Mar 19, 2009 2:16 pm
This is great, good job - maybe Sindre can include this in the standard Subsonic once its "perfected" - I have a couple of issues with it though :D
- You seem to assume Redhat, but this wont work on Ubuntu for instance:
LOCKFILE=/var/lock/subsys/subsonic.
Better to have the user set the full path to dir himself, or:
LOCKFILE=$SUBSONIC_HOME/subsonic.lck
This part didnt seem to work:
success && RETVAL=0
It just output something like "106: success: not found"
I changed it to just return the value so you can check on that.
Also:
This just puts out: "$Starting Subsonic..." with the "$".
Should the $ be there at all before the string?
This is in bash on ubuntu 8.10. I have a little experience with such scripts but I might have misunderstood something?
Pathduck
Postby jigsaw » Thu Mar 19, 2009 10:44 pm
Pathduck wrote:This is great, good job - maybe Sindre can include this in the standard Subsonic once its "perfected"
Thank you :)
Pathduck wrote:- You seem to assume Redhat, but this wont work on Ubuntu for instance:
You are quite correct, I am assuming Redhat, which may be too specific. However using SUBSONIC_HOME defies the purpose, on Redhat at least.
You could read about it here
A short excerpt of why:
This method of shutting down is ordered such that processes are killed as gracefully as possible. During a shutdown, the script /etc/rc.d/init.d/killall checks the /var/lock/subsys/ directory to see if any subsystems are still locked. If a service's subsystem is locked after all other services have been stopped (i.e. step 1 above has completed), the killall script uses the subsystem filename to call service <initscript> stop. This attempts to stop the service gracefully before handing off to steps 2 through 4, which forcefully terminate the process itself.
Pathduck wrote:This part didnt seem to work:
success && RETVAL=0
Also:
I think the main issue is that you are comparing Ubuntu, which is based on Debian, with Redhat. There are some subtle differences ( and probably quite a few huge ones :P )
Maybe you could use my first version and ubuntify it?
If you'd check out this link you could create a debian version which also could be included in the package? The link is for another application, but I think it shows quite nicely the differences between the two version.
I'd be happy to do it myself, but seeing as I do not have a Ubuntu system at my immediate disposal it would probably be far quicker for you to do it?
jigsaw
Postby Pathduck » Wed Mar 25, 2009 4:56 pm
Well, I dont really know how important the lockfile is, won't the OS do the stop() routine when shutting down? At least it does on RHEL5 (at work)...
Anyway, here's the script I'm using now, it works well on Ubuntu, only minor adjustments to the original:
#!/bin/sh
SU="su"
    SU="runuser"
fi
export PATH="$PATH:/bin:/usr/bin"
SUBSONIC_USERNAME=root
LOCKFILE=/var/subsonic/subsonic.lock
#. /etc/rc.d/init.d/functions
start() {
        getpid
        if [ $PID ]; then
            RETVAL=0
        else
            RETVAL=1
        fi
        echo
        return $RETVAL
stop() {
        kill $PID
        sleep 1
        getpid
        if [ $PID ]; then
            RETVAL=1
        else
            RETVAL=0
        fi
        echo
        return $RETVAL
status() {
        if [ $PID ]; then
        else
        fi
        echo
getpid() {
RETVAL=0
case "$1" in
  start)
   getpid
        if [ $PID ]; then
            status
        else
            start
        fi
  stop)
   getpid
        if [ $PID ]; then
            stop
        else
            status
        fi
  status)
   getpid
        status
  restart)
        stop
        start
        exit 1
esac
exit $RETVAL
Pathduck
Postby wintermute » Thu Apr 02, 2009 8:18 pm
No offense to wintermute Smile
None taken :)
Your script is nice. I appreciate if it (or a variant of it) will ship with Subsonic :)
wintermute
Postby sindre_mehus » Fri Apr 03, 2009 6:12 am
Thanks for you effort!
I'll definitely try to incorporate it in Subsonic once I get around to it.
Postby jigsaw » Fri Apr 10, 2009 1:15 pm
One more change to the subsonic.sh
Change the ">" to a ">>" so that the subsonic.log doesn't get overwritten with every restart of the service.
I just had a thumbnail issue which I was investigating and in an effort to solve it I restarted the service, resulting in loosing the entire log..
${JAVA} -Xmx${MAX_MEMORY}m  -Dsubsonic.home=${SUBSONIC_HOME} -Dsubsonic.port=${SUBSONIC_PORT} \
-Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} -jar subsonic-booter-jar-with-dependencies.jar > ${LOG} 2>&1 &
To:
-Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} -jar subsonic-booter-jar-with-dependencies.jar >> ${LOG} 2>&1 &
jigsaw
Postby sindre_mehus » Mon Apr 13, 2009 11:54 am
I've updated subsonic.sh so that it takes the following command line arguments:
Usage: subsonic.sh [options]
  --help               This small usage guide.
  --home=DIR           The directory where Subsonic will create files.
                       Make sure it is writable. Default: /var/subsonic
  --port=PORT          The port on which Subsonic will listen for
                       incoming HTTP traffic. Default: 8080
  --context-path=PATH  The context path, i.e., the last part of the Subsonic
                       URL. Typically '/' or '/subsonic'. Default '/'
  --max-memory=MB      The memory limit (max Java heap size) in megabytes.
                       Default: 64
  --pidfile=PIDFILE    Write PID to this file. Default not created.
Please find it here: http://subsonic.svn.sourceforge.net/vie ... xt%2Fplain
Comments are welcome.[/code]
Postby jigsaw » Wed Apr 15, 2009 10:30 pm
That works nicely :)
Except that I still add the extra '>' to the startup-line to avoid having the log overwritten every time.
I've modified my init-script to be compatible with the new subsonic.sh
Feel free to use it.
PS: I fixed it up a bit after I realized two bugs in the script following a power outage on my server.
The chkconfig now starts subsonic before Apache and stops it after Apache, this allows any proxy set up in Apache to work on boot.
I removed the lockfile-things as it cluttered it up and didn't provide anything for Subsonic after all.
It's still Red Hat / Fedora specific as it uses init-functions
#!/bin/sh
# chkconfig: 345 80 10
export PATH
USER=subsonic
start() {
        if [ $RETVAL = 1 ]; then
            echo "Will cleanup and try to start.."
            rm -f $PIDFILE
        fi
        echo -n "Starting $SERVICENAME "
        # Start subsonic
        daemon --pidfile=$PIDFILE --user=$USER $PROG "--pidfile=$PIDFILE --home=$SUBSONIC_HOME"
   RETVAL=$?
        echo
        return $RETVAL
stop() {
        echo -n "Stopping $SERVICENAME "
   RETVAL=$?
        echo
        return $RETVAL
status() {
        if [ -r $PIDFILE ]; then
            check_pid
            if [ $RETVAL = 0 ]; then
                echo -n "$SERVICENAME is running"
            else
                echo -n "Pidfile found, but subsys is dead"
            fi
        else
            echo -n "$SERVICENAME is not running"
        fi
        echo
        return $RETVAL
check_pid() {
        RETVAL=0
            PID=`cat $PIDFILE`
            PS_PID=`ps -u $USER -f | grep $PID | grep subsonic-booter-jar-with-dependencies.jar | awk '{print $2 }'`
            [ ! $PS_PID ] && RETVAL=1
        fi
        return $RETVAL
RETVAL=0
case "$1" in
  start)
            status
            [ $RETVAL = 1 ] && start
        else
            start
        fi
  stop)
            stop
        else
            status
        fi
  status)
        status
  restart)
        stop
        start
        exit 1
esac
exit $RETVAL
jigsaw
Postby tgeorge73 » Wed Jul 01, 2009 2:54 pm
Thanks for all the great information... However I ran into one snag that I thought I'd share in case others get it too... Prior to finding this I had run subsonic by manually executing the shell script whenever I rebooted my machine... Then, after applying the above changes to make it work as a service, whenever I started the service and tried to access the site I got an HTTP 503 error... (stopping the service and starting subsonic manually via the shell script worked fine). I eventually tracked it down to permissions. In addition to changing the owner of the /var/subsonic folder structure, I also had to change the owner of the /tmp/subsonic folder from my user account to the subsonic account since it already had been created by earlier manual startups before finding this thread. When reviewing the subsonic log files I saw the java exceptions about access denied to the musicFolderCache files...
tgeorge73
Postby twent4 » Sat Jul 25, 2009 3:47 am
hey guys, pardon the newbie talk, but did anyone figure out a way to modify this to work with deb/ubuntu? thanks.
twent4
Postby binoculars » Sat Aug 01, 2009 12:44 pm
Hello, I found this nice wiki:
http://oaktechnologies.net/jamwiki/en/Subsonic
Thought that main.jsp part could be handy for someone else... Enjoy :D
binoculars
Postby Pathduck » Fri Sep 04, 2009 7:23 pm
binoculars wrote:Hello, I found this nice wiki:
OR you could pay some money (choose what you want!) to support a great product and get rid of the ads that way!
... :roll:
Pathduck
Return to Tutorials
Users browsing this forum: No registered users and 0 guests
