Transcode FLAC to OGG with Replaygain applied
Postby guptaas » Sat Aug 03, 2019 3:39 pm
I've been using iSub for a very long time and have always been annoyed by sudden volume shifts from track to track. I'm very happy to have found this one step solution. oggenc2.exe can do the entire job. It does not need any other file to work even though the help file suggests you need flac.exe in the path.
"oggenc2 -Q -q 7 --FLAC-scale 1 %s -o -" This utilizes track gain
"oggenc2 -Q -q 7 --FLAC-scale 2 %s -o -" will apply album gain.
There is no way to apply Smart Gain in iSub, so go with your usual listening habits.
There may be some technical reason why this is not a perfect application of replaygain. All I can tell you is that the sudden shifts in volume are gone.
You can find various versions here:
http://www.rarewares.org/index.php
I am using Oggenc2.88 using aoTuVb6.03 (Lancer Builds) for x64 in Subsonic 6.1.5
guptaas
Re: Transcode FLAC to OGG with Replaygain applied
Postby grant420 » Fri Nov 29, 2019 4:00 pm
Hi there,
Can you tell me how to do this in more detail? Do I simply add the x64 .exe file to my transcode directory and then change some transcoding settings within the subsonic server's web console?
Here's what my transcode page looks like (mine is not so simple as perhaps most users so I wonder if that will make this difficult):
https://www.dropbox.com/s/tnz6flpl84mt8 ... s.PNG?dl=0
Grant
grant420
