Subsonic 3.7 released
Postby sindre_mehus » Tue Jun 23, 2009 11:44 am
Hi all,
Please notice that 3.7 has been released. There's a whole bunch of new stuff, but most importantly:
o New jukebox mode.
o New themes and languages.
o Improved search.
o Performance improvements.
o Bugfixes
Complete change log: http://subsonic.sourceforge.net/changelog.php
Download: http://subsonic.sourceforge.net/download.php
Please remember to vote for Subsonic in the SourceForge Community Awards (see signature below)!
Thanks for your attention,
When updating to v3.7, the "admin" user seems to l
Postby ok » Wed Jun 24, 2009 3:46 pm
First off, I will definitely vote for subsonic later today.
I just wanted to mention a bug listed in a non v3.7 specific topic that relates specifically to v3.7.
When updating to v3.7, the "admin" user seems to lose admin rights. I had already designated another user to be an admin, so I'm good to go. However, those people with only one admin user, may no longer have the ability to, for instance, change "settings".
Just an FYI,
Cheers
ok
ok
Postby SpritHansi » Wed Jun 24, 2009 8:36 pm
I didn't have that problem when I upgraded from v3.6 to v3.7.
Regards
SpritHansi
SpritHansi
Postby zeekay » Fri Jun 26, 2009 3:48 pm
Great release sindre! Thanks for your hard work :D
zeekay
Postby ok » Sat Jun 27, 2009 12:37 am
Hi again,
This is still a problem for me.
I installed v3.6 back again and saw settings for the admin user. Then I reinstalled v3.7 and settings was not available for the admin user.
I'm running Windows XP Pro.
Any ideas?
Scott
ok
Postby ok » Sat Jun 27, 2009 12:45 am
Also, here's the other post describing this admin user issue
http://forum.subsonic.org/forum/viewtop ... admin+user
ok
Postby ok » Sat Jun 27, 2009 12:46 am
P.S. I voted for Subsonic on SF.net
ok
Here's the fix
Postby ok » Sat Jun 27, 2009 7:44 am
I hunted blindly through the subsonic files and found a file called subsonic.script
I guessed that these were the available user roles:
INSERT INTO ROLE VALUES(1,'admin')
INSERT INTO ROLE VALUES(2,'download')
INSERT INTO ROLE VALUES(3,'upload')
INSERT INTO ROLE VALUES(4,'playlist')
INSERT INTO ROLE VALUES(5,'coverart')
INSERT INTO ROLE VALUES(6,'comment')
INSERT INTO ROLE VALUES(7,'podcast')
INSERT INTO ROLE VALUES(8,'stream')
INSERT INTO ROLE VALUES(9,'settings')
INSERT INTO ROLE VALUES(10,'jukebox')
But the admin user only had these eight roles
INSERT INTO USER_ROLE VALUES('admin',1)
INSERT INTO USER_ROLE VALUES('admin',2)
INSERT INTO USER_ROLE VALUES('admin',3)
INSERT INTO USER_ROLE VALUES('admin',4)
INSERT INTO USER_ROLE VALUES('admin',5)
INSERT INTO USER_ROLE VALUES('admin',6)
INSERT INTO USER_ROLE VALUES('admin',7)
INSERT INTO USER_ROLE VALUES('admin',8)
The fix I used
Caveat: this worked for me but you may want to get a second opinion from a Subsonic expert first before proceeding unless you're a daredevil like me.
1) Login to Subsonic as the admin user
2) Change the section of the URL listed as "index.view" to "db.view" (i.e. http://localhost/db.view)
3) Enter select * from user_role where username = 'admin' in the box and click the <OK> button.
4) If it shows only eight roles, Houston we have a problem for v3.7 as there now seem to be 10 roles
5) Enter INSERT INTO USER_ROLE VALUES('admin',9) in the box and click the <OK> button.
6) Note: not sure if this is necessary, but I also entered INSERT INTO USER_ROLE VALUES('admin',10) in the box and click the <OK> button.
7) Reenter select * from user_role where username = 'admin' in the box and click the <OK> button.
The admin user should now have 10 roles, or nine roles if you don't run step 6.
8) Go back to the index view (i.e. http://localhost/index.view)
At this point, I just refreshed my browser and I had access to settings for the admin user.
Cheers
ok
ok
Postby sindre_mehus » Sat Jun 27, 2009 9:47 am
I can confirm that the fix suggested above will work, well done!
I don't understand, however, how the database comes in this state in the first place. The 'settings' role is new in 3.7, but it's supposed to be assigned to all users during initialization.
For the technically minded, here's the code that's run during init:
        if (template.queryForInt("select count(*) from role where id = 9") == 0) {
            LOG.info("Role 'settings' not found in database. Creating it.");
            template.execute("insert into role values (9, 'settings')");
            template.execute("insert into user_role select distinct u.username, 9 from user u");
            LOG.info("Role 'settings' was created successfully.");
Can't figure out why this doesn't work in some cases.
Postby jigsaw » Sat Jun 27, 2009 11:56 am
sindre_mehus wrote:Can't figure out why this doesn't work in some cases.
Maybe it's an OS thing?
I can confirm that this worked fine after upgrading to 3.7 on linux standalone. No manual fix needed.
jigsaw
Postby ok » Sat Jun 27, 2009 4:54 pm
From v3.6, I upgraded to v3.7b1 a couple of months ago, then downgraded back to v3.6 because of issues I observed with the web player not starting as it previously had, then I upgraded to v3.7.
Is it possible that downgrading from v3.7b1 back to v3.6 put the database in this state?
Also, in my case, the 'settings' role was assigned to all users except for the admin user. Since your code snippet seems targeted at all users, I'm not sure why it didn't work for the admin user in my case.
Cheers
ok
ok
Postby sindre_mehus » Sun Jun 28, 2009 10:47 am
ok wrote:Is it possible that downgrading from v3.7b1 back to v3.6 put the database in this state?
Ah, yes that's very likely the reason. Do you remember if you modified the admin user (e.g., changed password) after rolling back to 3.6?
Postby deriksen » Tue Jun 30, 2009 6:43 am
Don't know if this has been mentioned or if it's even just a 3.7 bug, or if it was there in previous versions as well.
Giving a user admin rights (in my case at least) results in mini Now Playing graphics showing the admin user as playing the tracks and not the logged in user (with admin rights).
The log shows the correct user beeing parsed in the StreamController, but if I'm not mistaken, the user statistics gets messed up as well.
deriksen
Postby ok » Wed Jul 01, 2009 3:49 am
No Sindre. I didn't change anything else (I'm 99% sure) after reverting to v3.6
ok
Bug report regarding Jukebox mode
Postby flacflac » Sat Jul 04, 2009 8:57 pm
Great new release Sindre, I went ahead and became registered! :)
There is a bug in your Jukebox mode regarding the setting "Repeat is off" - it's not off!
I am reading "Repeat is off" above the player controls yet it loops a single track I started playing via Jukebox. Log reads as follows:
[7/4/09 10:43:38 PM CEST] INFO JukeboxService Starting jukebox player on behalf of admin
[7/4/09 10:43:38 PM CEST] DEBUG JukeboxService stateUpdated : OPENING:-1:net.sourceforge.subsonic.io.PlaylistInputStream@39f9d3f0
[7/4/09 10:43:38 PM CEST] INFO PlaylistInputStream Opening new song Album\Trackname.flac
[7/4/09 10:43:38 PM CEST] INFO MusicFileInfoDao Created music file info for X:\music\Soundtracks\Album\
[7/4/09 10:43:38 PM CEST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\flac] [-c] [-s] [-d] [X:\music\Soundtracks\Album\Trackname.flac]
[7/4/09 10:43:38 PM CEST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-v] [-V] [0] [-] [-]
[7/4/09 10:43:38 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[7/4/09 10:43:38 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE, SSE2
[7/4/09 10:43:38 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 19383 Hz - 19916 Hz
[7/4/09 10:43:38 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Encoding to
[7/4/09 10:43:38 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Encoding as 44.1 kHz VBR(q=0) j-stereo MPEG-1 Layer III (ca. 5.7x) qval=3
[7/4/09 10:43:38 PM CEST] DEBUG JukeboxService opened : {vbr=false, mp3.crc=false, mp3.copyright=false, mp3.padding=false, mp3.channels=2, mp3.version.mpeg=1, audio.framerate.fps=38.28125, audio.channels=2, mp3.framerate.fps=38.28125, mp3.framesize.bytes=727, mp3.version.layer=3, mp3.frequency.hz=44100, mp3.header.pos=0, mp3.bitrate.nominal.bps=224000, mp3.vbr.scale=0, mp3.version.encoding=MPEG1L3, basicplayer.sourcedataline=com.sun.media.sound.MixerSourceLine@44c42ce4, bitrate=224000, audio.type=MP3, mp3.mode=1, mp3.vbr=false, audio.samplerate.hz=44100.0, mp3.original=true}
[7/4/09 10:43:38 PM CEST] DEBUG JukeboxService stateUpdated : OPENED:-1
[7/4/09 10:43:39 PM CEST] DEBUG JukeboxService stateUpdated : PLAYING:-1
[7/4/09 10:43:39 PM CEST] DEBUG JukeboxService stateUpdated : GAIN:0.5099999904632568
[7/4/09 10:43:41 PM CEST] DEBUG JukeboxService stateUpdated : GAIN:0.6100000143051147
[7/4/09 10:43:42 PM CEST] DEBUG JukeboxService stateUpdated : GAIN:0.7099999785423279
[7/4/09 10:43:43 PM CEST] DEBUG JukeboxService stateUpdated : GAIN:0.8100000023841858
[7/4/09 10:43:43 PM CEST] DEBUG JukeboxService stateUpdated : GAIN:0.9100000262260437
[7/4/09 10:43:46 PM CEST] DEBUG JukeboxService stateUpdated : GAIN:0.8399999737739563
[7/4/09 10:47:36 PM CEST] INFO PlaylistInputStream Opening new song Album\Trackname.flac
[7/4/09 10:47:36 PM CEST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\flac] [-c] [-s] [-d] [X:\music\Soundtracks\Album\Trackname.flac]
[7/4/09 10:47:36 PM CEST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-v] [-V] [0] [-] [-]
[7/4/09 10:47:36 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[7/4/09 10:47:36 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE, SSE2
[7/4/09 10:47:36 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 19383 Hz - 19916 Hz
[7/4/09 10:47:36 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Encoding to
[7/4/09 10:47:36 PM CEST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Encoding as 44.1 kHz VBR(q=0) j-stereo MPEG-1 Layer III (ca. 5.7x) qval=3
...and it keeps on going. Nothing major, just a little bug. (oh and setting it to "Repeat is ON" does not stop repeating either)
Best wishes,
ff
flacflac
Return to Announcements
