Cause of thumbs problem found, 2.9 final version
Postby Inge » Thu Nov 16, 2006 10:17 pm
Hi Sindre,
Sorry I didn't discover the source of my thumbnail issue before you released 2.9, but I discovered the issue was still there after I installed installed the final 2.9 version.
Still running on Fedora Core 6, Java 5 and Tomcat 6, btw.
The problem seems to be related to the DISPLAY variable, or more correct, to the lack of a DISPLAY/X Server.
I discovered (even on the beta) that when starting tomcat with the DISPLAY variable set, it failed. This was logged in catalina.out as:
X connection to localhost:11.0 broken (explicit kill or server shutdown)
My DISPLAY variable is automatically set when I access the server using SSH (X11 forwarding).
I was able to log in to Subsonic, but as soon as I tried to browse any albums, Tomcat shut down with the exception above.
I "fixed" this by adding
export DISPLAY=
to Tomcat's startup.sh
When my thumbnail issue was still there after upgrading to 2.9 final, I coupled those two findings, and started an X Server on my desktop computer (the one running the SSH client), set the DISPLAY variable and started Tomcat. Voila!, thumbnails are created and displayed (great performance increase, btw, caching the thumbs).
My guess is that the component you use for image scaling for some reason needs the presence of an X server? I would very much like to run my Fedora "server" without a graphical interface, as I did on previous versions. Do you know if the components you use for scaling make use of some X components?
Thanks again for a great product, please let me know if I can do anything to track down the root cause of this.
Inge.
Inge
Postby sindre_mehus » Fri Nov 17, 2006 8:51 am
Ah, interesting...
First of all, this is a different problem than the one that was fixed in 2.9 final. (Can you please verify that there are no empty thumb files in /var/subsonic/thumbs?)
To diagnostic the "headless" problem further (headless meaning there is no X server), please do the following:
1. Unset the DISPLAY variable (export DISPLAY=) and restart Tomcat.
2. Browse albums
3. Look for anything interesting in /var/subsonic/subsonic.log ("Failed to create thumbnail..."). Please post the details.
4. Set the JAVA_OPTS variable in startup.sh:
export JAVA_OPTS=-Djava.awt.headless=true
5. Restart, browse albums and report any errors in subsonic.log
For more background info, see http://java.sun.com/developer/technical ... /headless/
Postby Inge » Fri Nov 17, 2006 6:23 pm
First the result of the first test (no empty thumb files before starting). It's a rather long log, covering 2 examples of "Failed to create thumbnaili". They are slightly different, since the first one also includes a section following the "Can't connect to to X11".
I will go on testing the headless-setting in JAVA_OPTS now - see next post for results:
[2006-11-17 18:55:35,063] WARN CoverArtController - Failed to create thumbnail for /home/musikk/Band og Artister/Postgiroby
gget/Supertanker/folder.jpg
java.lang.InternalError: Can't connect to X11 window server using '' as the value of the DISPLAY variable.
at sun.awt.X11GraphicsEnvironment.initDisplay(Native Method)
at sun.awt.X11GraphicsEnvironment.access$000(X11GraphicsEnvironment.java:53)
at sun.awt.X11GraphicsEnvironment$1.run(X11GraphicsEnvironment.java:142)
at sun.awt.X11GraphicsEnvironment.<clinit>(X11GraphicsEnvironment.java:131)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:164)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:68)
at java.awt.image.BufferedImage.createGraphics(BufferedImage.java:1141)
at net.sourceforge.subsonic.controller.CoverArtController.scale(CoverArtController.java:165)
at net.sourceforge.subsonic.controller.CoverArtController.getCachedImage(CoverArtController.java:116)
at net.sourceforge.subsonic.controller.CoverArtController.handleRequest(CoverArtController.java:67)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:45
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:806)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:736)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:396)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:350)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:698)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilt
er.java:81)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:181)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:216)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:108)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:
195)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:90)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:228)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:212)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:818)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:624)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:445)
at java.lang.Thread.run(Thread.java:595)
[2006-11-17 18:55:58,874] WARN CoverArtController - Failed to create thumbnail for /home/musikk/Billboard/Billboard Top 100
of 1999/Folder.jpg
java.lang.NoClassDefFoundError
er.java:81)
195)
Inge
Postby Inge » Fri Nov 17, 2006 6:40 pm
Result of second test - JAVA_OPTS now set to:
Testresult - including the two first errors, there are several more...
[2006-11-17 19:31:20,044] INFO VersionService - Resolved latest Subsonic beta version to: 2.9.beta1
[2006-11-17 19:31:20,046] INFO VersionService - Resolved local Subsonic version to: 2.9
[2006-11-17 19:31:21,583] WARN CoverArtController - Failed to create thumbnail for /home/musikk/Band og Artister/Elton John
/Elton John - Goodbye yellow brick road/folder.jpg
er.java:81)
195)
[2006-11-17 19:31:42,320] WARN CoverArtController - Failed to create thumbnail for /home/musikk/Band og Artister/Pink Floyd
/Pink Floyd - 1972 - Obscured By Clouds/folder.jpg
er.java:81)
195)
Inge
