pha9992001 wrote:I noticed subsonic had a documented API, so I decided to experiment with making an Adobe Air app for it. Here's a very early beta version...
http://nonpixel.com/subair/
bouteill wrote:Hi,
Just tried SubAir, it 's got amazing potential, congrats!
However, when clicking on 'Save Settings' to connect to the server, the clock starts ticking and never stops... And it never really connects to my server... Is this just me?
Cheers and thanks for your help and this great new app!
pha9992001 wrote:Thanks for all the positive feedback...
About the clock cursor/app never fully logging in. When entering the server address, be sure to use http and the proper port number (if you are using a port other than 80), such as:
http://www.servername.com:100
I've published an update, the next time the app is opened, there should be an update notification.
- added an error alert for incorrect server address
- added auto login, if server info is already saved.
pha9992001 wrote:Using an IP address should work. I have tested that and works for me. It might be a proxy issue or firewall issue.
bouteill wrote:pha9992001 wrote:what version of subsonic are you using?
I use Subsonic v3.7; should I upgrade to 3.8?
