Java errors
Java errors
Postby Clockwork » Fri Jan 29, 2010 2:40 am
Had a couple of complaints about errors.
Took a look at the log, and...
[2010-01-27 18:22:59,326] WARN CoverArtController - Failed to create thumbnail for /mnt/raid/music/D/****$
java.lang.OutOfMemoryError: Java heap space
I have a log filled with these, and i can't find out the problem, the server has 1.5 GB of ram, it should be more than enough.
Any help with these would be much appreciated.
Clockwork
Clockwork
Postby Poffa » Fri Jan 29, 2010 7:12 am
You probably need to assign Subsonic more memory. Check SUBSONIC_MAX_MEMORY in the subsonic.sh file.
Also see under "More" in the Subsonic interface if it's using all memory assigned.
Poffa
Re: Java Heap Error
Postby drydeniv » Wed Mar 31, 2010 12:13 pm
Hello, I'm a Mac user (10.6.3), and I am having this error. I can't locate the subsonic.sh file, perhaps that's a linux thing or an older version of the mac app? It has made my UI come to a crawl, and I'm very much in need of updating the memory.
Can someone please tell me where this memory setting is located? I'm using ver. 3.9, from the Mac installer.
Edit: I'm sorry, I didn't see the entry in the <key>VMOptions</key> in Subsonic.app/Contents/Info.plist
drydeniv
