Request: Switch parser to JAUDIOTAGGER
Postby flacflac » Tue Feb 23, 2010 10:15 am
Hi Sindre,
since the 'entagged' parser is abandonware with no new release for 2 years I think it's time to move on. The errors and problems arising from 'entagged' are massive, especially with larger collections and vorbis comment tags (FLAC files...).
I suggest a move towards jaudiotagger:
http://www.jthink.net/jaudiotagger/
Implementation should not be very difficult, as a forum user actually managed to use some of its functionality in Subsonic:
http://forum.subsonic.org/forum/viewtopic.php?t=1979&highlight=jaudiotagger
Thank you for considering this upgrade.
Best wishes,
ff :shock:
PS: As a side note: it would be perfect if the chat windows would detect hyperlinks and make them clickable right away. ;)
flacflac
Postby sindre_mehus » Tue Feb 23, 2010 11:08 am
Thanks for the suggestion, I'll take a look at the jaudiotagger library (and hyperlink detection).
Postby flacflac » Tue Feb 23, 2010 11:10 am
Awesome, thanks for considering this. :)
flacflac
Postby 3R3 » Mon Apr 05, 2010 11:12 pm
yup, entagged is no longer on a level with subsonic, it really gives too much false positives in the log and other redundant error messages. +1 for jaudiotagger
3R3
Postby adolgov » Tue Apr 06, 2010 12:24 am
One of my current main concerns with Subsonic is that many of my FLAC tags are not read in properly. I'm assuming that it's a limitation of the current tagging lib to recognize some tag formats. Unfortunately, it means that last.fm submissions fail for those files, among other side effects. Hopefully, moving to a more recent and feature-full tagging library will also solve these types of problems (a major issue for me, and I'm sure others as well.) Thanks for the consideration.
adolgov
Users browsing this forum: No registered users and 48 guests
