Add Fullscreen Screensaver/Visual Effects?
Postby adhesiv » Sun Apr 25, 2010 8:44 am
With the ability to use JWPLayer in fullscreen i feel like we need some visual effects/screensaver to enable. this could be cool when connected to your TV. If you can link it up to a remote app on a mobile phone device you'll have a full on media jukebox fit for the big screen.
adhesiv
Postby squipple » Sun May 09, 2010 11:50 pm
I second this, we need a visualizer for subsonic! :)
squipple
Postby eli2k » Wed May 12, 2010 8:07 am
JW does have a visualizer plugin
http://www.longtailvideo.com/addons/plugins/42/Revolt?q=
I couldn't figure out how to add it without breaking subsonic...
eli2k
Postby lunged » Wed Nov 10, 2010 12:15 am
A visualizer would be awesome.
I just saw this online: http://music.zackhemsey.com/track/mind-heist
It looks like bandcamp has some awesome visualizers (try flower - it is great). I would love to see something like this in Subsonic.
lunged
Revolt works!!
Postby danobegood » Mon Nov 29, 2010 3:45 pm
Hi All,
I got the revolt plugin to work. Resizing the player allows you to incorporate the revolt plugin into the main interface. Fullscreen works as well. I'll post some inrtuctions on how to do it shortly.
DanoImage
danobegood
Postby danobegood » Mon Nov 29, 2010 3:50 pm
Actually it turns out to be fairly straightforward. You'll need to modify the subsonic/jetty/1944/webapp/WEB-INF/jsp/playlist.jsp page. I added the line in bold and changed the player size from what it was to 48, which I've also highlighted in bold
function createPlayer() {
var flashvars = {
backcolor:"090a09",
frontcolor:"d2f1d5",
plugins:"revolt.swf",
var params = {
allowfullscreen:"true",
allowscriptaccess:"always",
var attributes = {
swfobject.embedSWF("/flash/jw-player-5.0.swf", "placeholder", "340", "48", "9.0.0", false, flashvars, params, attributes);
danobegood
Postby stozher » Mon Nov 29, 2010 5:28 pm
Thanks danobegood!
New version of Revolt is available. Change
to
plugins:"revolt-1.swf",
stozher
Postby danobegood » Tue Nov 30, 2010 4:31 am
also noticed another location in the playlist.jsp page where the player height should be updated. As well, 48 pixels seems to be too high as the playlist has disappeared, so here's my proposal. In addition to the section I listed previously in the thread modify the following section toward the bottom of the page
<c:if test="${model.player.web}">
<td style="width:340px; height:34px;padding-left:10px;padding-right:10px"><div id="placeholder">
<a href="http://www.adobe.com/go/getflashplayer" target="_blank"><fmt:message key="playlist.getflash"/></a>
</div></td>
</c:if>
Again I've bolded the change. Be sure to change what I listed previously in this thread from 48 to 34. This way you'll keep the playlist in view. Most of all this seems very reliable. One other thing to note is that if you bring the page into Dreamweaver or similar you can change the table vertical alignment so that it looks correct. Below is my version of the final formatted page which you can use in place of the original.
<%@ page language="java" contentType="text/html; charset=utf-8" pageEncoding="iso-8859-1"%>
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html><head>
<%@ include file="head.jsp" %>
<script type="text/javascript" src="<c:url value="/dwr/interface/nowPlayingService.js"/>"></script>
<script type="text/javascript" src="<c:url value="/dwr/interface/playlistService.js"/>"></script>
<script type="text/javascript" src="<c:url value="/dwr/engine.js"/>"></script>
<script type="text/javascript" src="<c:url value="/dwr/util.js"/>"></script>
<script type="text/javascript" src="<c:url value="/script/prototype.js"/>"></script>
<script type="text/javascript" src="<c:url value="/script/scripts.js"/>"></script>
<script type="text/javascript" src="<c:url value="/script/swfobject.js"/>"></script>
<script type="text/javascript" src="<c:url value="/script/webfx/range.js"/>"></script>
<script type="text/javascript" src="<c:url value="/script/webfx/timer.js"/>"></script>
<script type="text/javascript" src="<c:url value="/script/webfx/slider.js"/>"></script>
<link type="text/css" rel="stylesheet" href="<c:url value="/script/webfx/luna.css"/>">
</head>
<body class="bgcolor2 playlistframe" onload="init()">
<script type="text/javascript" language="javascript">
var player = null;
var songs = null;
var currentAlbumUrl = null;
var currentStreamUrl = null;
var startPlayer = false;
var repeatEnabled = false;
var slider = null;
function init() {
dwr.engine.setErrorHandler(null);
startTimer();
<c:choose>
<c:when test="${model.player.web}">
createPlayer();
</c:when>
<c:otherwise>
getPlaylist();
</c:otherwise>
</c:choose>
function startTimer() {
<!-- Periodically check if the current song has changed. -->
nowPlayingService.getNowPlayingForCurrentPlayer(nowPlayingCallback);
setTimeout("startTimer()", 10000);
function nowPlayingCallback(nowPlayingInfo) {
if (nowPlayingInfo != null && nowPlayingInfo.streamUrl != currentStreamUrl) {
getPlaylist();
if (currentAlbumUrl != nowPlayingInfo.albumUrl && top.main.updateNowPlaying) {
top.main.location.replace("nowPlaying.view?");
currentAlbumUrl = nowPlayingInfo.albumUrl;
<c:if test="${not model.player.web}">
currentStreamUrl = nowPlayingInfo.streamUrl;
updateCurrentImage();
</c:if>
var flashvars = {
backcolor:"<spring:theme code="backgroundColor"/>",
frontcolor:"<spring:theme code="textColor"/>",
var params = {
'revolt.position' : "bottom"
var attributes = {
swfobject.embedSWF("<c:url value="/flash/jw-player-5.0.swf"/>", "placeholder", "340", "34", "9.0.0", false, flashvars, params, attributes);
function playerReady(thePlayer) {
player = $("player1");
player.addModelListener("STATE", "stateListener");
getPlaylist();
function stateListener(obj) { // IDLE, BUFFERING, PLAYING, PAUSED, COMPLETED
if (obj.newstate == "COMPLETED") {
onNext(repeatEnabled);
function getPlaylist() {
playlistService.getPlaylist(playlistCallback);
function onClear() {
var ok = true;
<c:if test="${model.partyMode}">
ok = confirm("<fmt:message key="playlist.confirmclear"/>");
</c:if>
if (ok) {
playlistService.clear(playlistCallback);
function onStart() {
playlistService.start(playlistCallback);
function onStop() {
playlistService.stop(playlistCallback);
function onGain(gain) {
playlistService.setGain(gain);
function onSkip(index) {
<c:choose>
skip(index);
</c:when>
<c:otherwise>
currentStreamUrl = songs[index].streamUrl;
playlistService.skip(index, playlistCallback);
</c:otherwise>
</c:choose>
function onNext(wrap) {
var index = parseInt(getCurrentSongIndex()) + 1;
if (wrap) {
index = index % songs.length;
skip(index);
function onPrevious() {
skip(parseInt(getCurrentSongIndex()) - 1);
function onPlay(path) {
startPlayer = true;
playlistService.play(path, playlistCallback);
function onPlayRandom(path, count) {
startPlayer = true;
playlistService.playRandom(path, count, playlistCallback);
function onAdd(path) {
playlistService.add(path, playlistCallback);
function onShuffle() {
playlistService.shuffle(playlistCallback);
function onRemove(index) {
playlistService.remove(index, playlistCallback);
function onRemoveSelected() {
var indexes = new Array();
var counter = 0;
for (var i = 0; i < songs.length; i++) {
var index = i + 1;
if ($("songIndex" + index).checked) {
indexes[counter++] = i;
playlistService.removeMany(indexes, playlistCallback);
function onUp(index) {
playlistService.up(index, playlistCallback);
function onDown(index) {
playlistService.down(index, playlistCallback);
function onToggleRepeat() {
playlistService.toggleRepeat(playlistCallback);
function onUndo() {
playlistService.undo(playlistCallback);
function onSortByTrack() {
playlistService.sortByTrack(playlistCallback);
function onSortByArtist() {
playlistService.sortByArtist(playlistCallback);
function onSortByAlbum() {
playlistService.sortByAlbum(playlistCallback);
function playlistCallback(playlist) {
songs = playlist.entries;
repeatEnabled = playlist.repeatEnabled;
if ($("start")) {
if (playlist.stopEnabled) {
$("start").hide();
$("stop").show();
} else {
$("start").show();
$("stop").hide();
if ($("toggleRepeat")) {
var text = repeatEnabled ? "<fmt:message key="playlist.repeat_on"/>" : "<fmt:message key="playlist.repeat_off"/>";
dwr.util.setValue("toggleRepeat", text);
if (songs.length == 0) {
$("empty").show();
} else {
$("empty").hide();
// Delete all the rows except for the "pattern" row
dwr.util.removeAllRows("playlistBody", { filter:function(tr) {
return (tr.id != "pattern");
// Create a new set cloned from the pattern row
var song = songs[i];
var id = i + 1;
dwr.util.cloneNode("pattern", { idSuffix:id });
if ($("trackNumber" + id)) {
dwr.util.setValue("trackNumber" + id, song.trackNumber);
if ($("currentImage" + id) && song.streamUrl == currentStreamUrl) {
$("currentImage" + id).show();
if ($("title" + id)) {
dwr.util.setValue("title" + id, truncate(song.title));
$("title" + id).title = song.title;
if ($("titleUrl" + id)) {
dwr.util.setValue("titleUrl" + id, truncate(song.title));
$("titleUrl" + id).title = song.title;
$("titleUrl" + id).onclick = function () {onSkip(this.id.substring(8) - 1)};
if ($("album" + id)) {
dwr.util.setValue("album" + id, truncate(song.album));
$("album" + id).title = song.album;
$("albumUrl" + id).href = song.albumUrl;
if ($("artist" + id)) {
dwr.util.setValue("artist" + id, truncate(song.artist));
$("artist" + id).title = song.artist;
if ($("genre" + id)) {
dwr.util.setValue("genre" + id, song.genre);
if ($("year" + id)) {
dwr.util.setValue("year" + id, song.year);
if ($("bitRate" + id)) {
dwr.util.setValue("bitRate" + id, song.bitRate);
if ($("duration" + id)) {
dwr.util.setValue("duration" + id, song.durationAsString);
if ($("format" + id)) {
dwr.util.setValue("format" + id, song.format);
if ($("fileSize" + id)) {
dwr.util.setValue("fileSize" + id, song.fileSize);
$("pattern" + id).show();
$("pattern" + id).className = (i % 2 == 0) ? "bgcolor1" : "bgcolor2";
if (playlist.sendM3U) {
parent.frames.main.location.href="play.m3u?";
if (slider) {
slider.setValue(playlist.gain * 100);
triggerPlayer();
</c:if>
function triggerPlayer() {
if (startPlayer) {
if (songs.length > 0) {
skip(0);
player.sendEvent("LOAD", new Array());
player.sendEvent("STOP");
function skip(index) {
if (index < 0 || index >= songs.length) {
return;
var song = songs[index];
currentStreamUrl = song.streamUrl;
var list = new Array();
list[0] = {
file:song.streamUrl,
title:song.title,
provider:"sound"
if (song.duration != null) {
list[0].duration = song.duration;
if(song.format=="mpg" || song.format=="mpeg" || song.format=="avi" || song.format=="mp4" || song.format=="mkv" || song.format=="ogm" || song.format=="flv" || song.format == "aac" || song.format == "m4a"){
list[0]["type"]="video";
player.sendEvent("LOAD", list);
player.sendEvent("PLAY");
function updateCurrentImage() {
var id = i + 1;
var image = $("currentImage" + id);
if (image) {
if (song.streamUrl == currentStreamUrl) {
image.show();
} else {
image.hide();
function getCurrentSongIndex() {
if (songs[i].streamUrl == currentStreamUrl) {
return i;
return -1;
function truncate(s) {
var cutoff = ${model.visibility.captionCutoff};
if (s.length > cutoff) {
return s.substring(0, cutoff) + "...";
return s;
<!-- actionSelected() is invoked when the users selects from the "More actions..." combo box. -->
function actionSelected(id) {
if (id == "top") {
return;
} else if (id == "loadPlaylist") {
parent.frames.main.location.href = "loadPlaylist.view?";
} else if (id == "savePlaylist") {
parent.frames.main.location.href = "savePlaylist.view?";
} else if (id == "downloadPlaylist") {
location.href = "download.view?player=${model.player.id}";
} else if (id == "sortByTrack") {
onSortByTrack();
} else if (id == "sortByArtist") {
onSortByArtist();
} else if (id == "sortByAlbum") {
onSortByAlbum();
} else if (id == "selectAll") {
selectAll(true);
} else if (id == "selectNone") {
selectAll(false);
} else if (id == "removeSelected") {
onRemoveSelected();
} else if (id == "download") {
location.href = "download.view?player=${model.player.id}&indexes=" + getSelectedIndexes();
} else if (id == "appendPlaylist") {
parent.frames.main.location.href = "appendPlaylist.view?indexes=" + getSelectedIndexes();
$("moreActions").selectedIndex = 0;
function getSelectedIndexes() {
var result = "";
if ($("songIndex" + (i + 1)).checked) {
result += (i + " ");
return result;
function selectAll(b) {
$("songIndex" + (i + 1)).checked = b;
</script>
<div class="bgcolor2" style="position:fixed; top:0; width:100%;padding-top:0.5em">
<table style="white-space:nowrap;">
<tr style="white-space:nowrap;">
<c:if test="${model.user.settingsRole}">
<td valign="bottom"><select name="player" onchange="location='playlist.view?player=' + options[selectedIndex].value;">
<c:forEach items="${model.players}" var="player">
<option ${player.id eq model.player.id ? "selected" : ""} value="${player.id}">${player.shortDescription}</option>
</c:forEach>
</select></td>
</c:if>
</div></td>
</c:if>
<c:if test="${model.user.streamRole and not model.player.web}">
<td style="white-space:nowrap;" id="stop"><b><a href="javascript:noop()" onclick="onStop()"><fmt:message key="playlist.stop"/></a></b> | </td>
<td style="white-space:nowrap;" id="start"><b><a href="javascript:noop()" onclick="onStart()"><fmt:message key="playlist.start"/></a></b> | </td>
</c:if>
<c:if test="${model.player.jukebox}">
<td style="white-space:nowrap;">
<img src="<spring:theme code="volumeImage"/>" alt="">
</td>
<div class="slider bgcolor2" id="slider-1" style="width:90px">
<input class="slider-input" id="slider-input-1" name="slider-input-1">
</div>
<script type="text/javascript">
var updateGainTimeoutId = 0;
slider = new Slider(document.getElementById("slider-1"), document.getElementById("slider-input-1"));
slider.onchange = function () {
clearTimeout(updateGainTimeoutId);
updateGainTimeoutId = setTimeout("updateGain()", 250);
function updateGain() {
var gain = slider.getValue() / 100.0;
onGain(gain);
</script>
</td>
</c:if>
<td style="white-space:nowrap;"><a href="javascript:noop()" onclick="onPrevious()"><b>&laquo;</b></a></td>
<td style="white-space:nowrap;"><a href="javascript:noop()" onclick="onNext(false)"><b>&raquo;</b></a> |</td>
</c:if>
<td style="white-space:nowrap;"><a href="javascript:noop()" onclick="onClear()"><fmt:message key="playlist.clear"/></a> |</td>
<td style="white-space:nowrap;"><a href="javascript:noop()" onclick="onShuffle()"><fmt:message key="playlist.shuffle"/></a> |</td>
<c:if test="${model.player.web or model.player.jukebox or model.player.external}">
<td style="white-space:nowrap;"><a href="javascript:noop()" onclick="onToggleRepeat()"><span id="toggleRepeat"><fmt:message key="playlist.repeat_on"/></span></a> |</td>
</c:if>
<td style="white-space:nowrap;"><a href="javascript:noop()" onclick="onUndo()"><fmt:message key="playlist.undo"/></a> |</td>
<td style="white-space:nowrap;"><a href="playerSettings.view?id=${model.player.id}" target="main"><fmt:message key="playlist.settings"/></a> |</td>
</c:if>
<td style="white-space:nowrap;"><select id="moreActions" onchange="actionSelected(this.options[selectedIndex].id)">
<option id="top" selected="selected"><fmt:message key="playlist.more"/></option>
<option style="color:blue;"><fmt:message key="playlist.more.playlist"/></option>
<option id="loadPlaylist">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.load"/></option>
<c:if test="${model.user.playlistRole}">
<option id="savePlaylist">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.save"/></option>
</c:if>
<c:if test="${model.user.downloadRole}">
<option id="downloadPlaylist">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="common.download"/></option>
</c:if>
<option id="sortByTrack">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.more.sortbytrack"/></option>
<option id="sortByAlbum">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.more.sortbyalbum"/></option>
<option id="sortByArtist">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.more.sortbyartist"/></option>
<option style="color:blue;"><fmt:message key="playlist.more.selection"/></option>
<option id="selectAll">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.more.selectall"/></option>
<option id="selectNone">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.more.selectnone"/></option>
<option id="removeSelected">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.remove"/></option>
<option id="download">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="common.download"/></option>
</c:if>
<option id="appendPlaylist">&nbsp;&nbsp;&nbsp;&nbsp;<fmt:message key="playlist.append"/></option>
</c:if>
</select>
</td>
</tr></table>
</div>
<div style="height:3.2em"></div>
<p id="empty"><em><fmt:message key="playlist.empty"/></em></p>
<table style="border-collapse:collapse;white-space:nowrap;">
<tbody id="playlistBody">
<tr valign="bottom" id="pattern" style="display:none;margin:0;padding:0;border:0">
<td class="bgcolor2"><a href="javascript:noop()">
<img id="removeSong" onclick="onRemove(this.id.substring(10) - 1)" src="<spring:theme code="removeImage"/>"
alt="<fmt:message key="playlist.remove"/>" title="<fmt:message key="playlist.remove"/>"></a></td>
<img id="up" onclick="onUp(this.id.substring(2) - 1)" src="<spring:theme code="upImage"/>"
alt="<fmt:message key="playlist.up"/>" title="<fmt:message key="playlist.up"/>"></a></td>
<img id="down" onclick="onDown(this.id.substring(4) - 1)" src="<spring:theme code="downImage"/>"
alt="<fmt:message key="playlist.down"/>" title="<fmt:message key="playlist.down"/>"></a></td>
<td class="bgcolor2" style="padding-left: 0.1em"><input type="checkbox" class="checkbox" id="songIndex"></td>
<td style="padding-right:0.25em"></td>
<c:if test="${model.visibility.trackNumberVisible}">
<td style="padding-right:0.5em;text-align:right"><span class="detail" id="trackNumber">1</span></td>
</c:if>
<td style="padding-right:1.25em">
<img id="currentImage" src="<spring:theme code="currentImage"/>" alt="" style="display:none">
<c:choose>
<c:when test="${model.player.externalWithPlaylist}">
<span id="title">Title</span>
</c:when>
<c:otherwise>
<a id="titleUrl" href="javascript:noop()">Title</a>
</c:otherwise>
</c:choose>
</td>
<c:if test="${model.visibility.albumVisible}">
<td style="padding-right:1.25em"><a id="albumUrl" target="main"><span id="album" class="detail">Album</span></a></td>
</c:if>
<c:if test="${model.visibility.artistVisible}">
<td style="padding-right:1.25em"><span id="artist" class="detail">Artist</span></td>
</c:if>
<c:if test="${model.visibility.genreVisible}">
<td style="padding-right:1.25em"><span id="genre" class="detail">Genre</span></td>
</c:if>
<c:if test="${model.visibility.yearVisible}">
<td style="padding-right:1.25em"><span id="year" class="detail">Year</span></td>
</c:if>
<c:if test="${model.visibility.formatVisible}">
<td style="padding-right:1.25em"><span id="format" class="detail">Format</span></td>
</c:if>
<c:if test="${model.visibility.fileSizeVisible}">
<td style="padding-right:1.25em;text-align:right;"><span id="fileSize" class="detail">Format</span></td>
</c:if>
<c:if test="${model.visibility.durationVisible}">
<td style="padding-right:1.25em;text-align:right;"><span id="duration" class="detail">Duration</span></td>
</c:if>
<c:if test="${model.visibility.bitRateVisible}">
<td style="padding-right:0.25em"><span id="bitRate" class="detail">Bit Rate</span></td>
</c:if>
</tr>
</tbody>
</table>
</body></html>
danobegood
Postby seanpkeown » Tue Nov 30, 2010 5:22 am
This is awesome. I got this feature to work on Firefox but it looks as if my Google chrome player is having troubles. I'm guessing its because of the flash version that Google has embedded into the browser. Is anyone else able to test this for me?
I'm Running Chome Ver 7.0.517.44
Sean K
seanpkeown
Postby danobegood » Tue Nov 30, 2010 2:15 pm
It works for me in Chrome 7.0.517.44
danobegood
Postby seanpkeown » Wed Dec 01, 2010 12:41 am
danobegood wrote:It works for me in Chrome 7.0.517.44
Yup it works on my brothers computer too... well i'll delete my cookies and try again.
Sean K
seanpkeown
