becurious wrote:Hello and thx for the update!!!
Got a problem since the upgrade I can't change the covers anymore :
java.lang.Exception: Permission denied: /xxx/xxxx/music/xxxx/xxxx - xxxx/cover.jpg
linuxman wrote:I didn't get a chance to post on the beta1 because I just noticed that my links in any of the folders to go to the letter section and to return to the top have quit working even in 4.0 release.
Ok found the issue is in the groove skin as other skins are working correctly. Can you take a look at that skin and see what the issue is?
Ok further checking and groove, groove simple, simplify, denim, pink panther all have the same issue with the links for the alphabet and return to top not working.
rwagter wrote:Can't seem to use the android app anymore. When playing a file an exception is thrown:
error downloading "song" /sdcard/subsonic/music/x/x/x/x/x.mp3.partial(FileNotFoundException)
I can write to the card and did a reinstall already.
Ralph
Adam B. wrote:rwagter wrote:Can't seem to use the android app anymore. When playing a file an exception is thrown:
Ralph
ambulanceonfire wrote:Hey guys. First and foremost, THANK YOU. This program is excellent.
Now on to problem town. I was running the previous stable release without any issues. I updated to 4.0 and now i cant trans-code via the built in player.
I'm able to play with the outside player without problems. Ive tried reinstalling, different browsers, different setting, and gone through the trans-code troubleshooting. Where should i go from here?
sindre_mehus wrote:I just released 4.0.1, with the following bug fixes:
o Fixed broken cover art download.
o Fixed broken m4a transcoding.
o Fixed broken quick links in artist frame for some new themes.
Please upgrade & sorry for the inconvenience!
Note to self: Don't do last minute changes before releasing, especially after a glass or three of wine
