Help For Stupid Mac Users!
Postby macboy » Mon Jan 15, 2007 1:21 pm
Hi
I have been trying for hours to get Subsonic to work!!! I am running a Mac G5 with OS 10.4.8. I have Java and Tomcat installed. I can access the Tomcat Web Application Manager on http://127.0.0.1:8080/. I created a manager in the tomcat-users.xml and can login. I can upload subsonic.war but when I try and start it I get the following error
FAIL - Application at context path /subsonic could not be started
This is my catalina.log
Jan 15, 2007 10:40:06 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: .:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
Jan 15, 2007 10:40:07 AM org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Jan 15, 2007 10:40:07 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1766 ms
Jan 15, 2007 10:40:07 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Jan 15, 2007 10:40:07 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.20
Jan 15, 2007 10:40:07 AM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
Jan 15, 2007 10:40:09 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive subsonic.war
Jan 15, 2007 10:40:13 AM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/subsonic] startup failed due to previous errors
Jan 15, 2007 10:40:16 AM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Jan 15, 2007 10:40:16 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Jan 15, 2007 10:40:16 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/150 config=null
Jan 15, 2007 10:40:17 AM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
Jan 15, 2007 10:40:17 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 10279 ms
Jan 15, 2007 10:47:06 AM org.apache.catalina.startup.HostConfig checkResources
INFO: Undeploying context [/subsonic]
Jan 15, 2007 10:49:07 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 10:49:10 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 10:50:10 AM org.apache.catalina.startup.HostConfig checkResources
Jan 15, 2007 11:04:59 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 11:04:59 AM org.apache.coyote.http11.Http11BaseProtocol init
SEVERE: Error initializing endpoint
java.net.BindException: Address already in use:8080
at org.apache.tomcat.util.net.PoolTcpEndpoint.initEndpoint(PoolTcpEndpoint.java:297)
at org.apache.coyote.http11.Http11BaseProtocol.init(Http11BaseProtocol.java:138)
at org.apache.catalina.connector.Connector.initialize(Connector.java:1016)
at org.apache.catalina.core.StandardService.initialize(StandardService.java:580)
at org.apache.catalina.core.StandardServer.initialize(StandardServer.java:791)
at org.apache.catalina.startup.Catalina.load(Catalina.java:503)
at org.apache.catalina.startup.Catalina.load(Catalina.java:523)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:266)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:431)
Jan 15, 2007 11:04:59 AM org.apache.catalina.startup.Catalina load
SEVERE: Catalina.start
LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use:8080
at org.apache.catalina.connector.Connector.initialize(Connector.java:1018)
INFO: Initialization processed in 1462 ms
Jan 15, 2007 11:05:00 AM org.apache.catalina.core.StandardService start
Jan 15, 2007 11:05:00 AM org.apache.catalina.core.StandardEngine start
Jan 15, 2007 11:05:00 AM org.apache.catalina.core.StandardHost start
Jan 15, 2007 11:05:01 AM org.apache.coyote.http11.Http11BaseProtocol start
SEVERE: Error starting endpoint
at org.apache.tomcat.util.net.PoolTcpEndpoint.startEndpoint(PoolTcpEndpoint.java:312)
at org.apache.coyote.http11.Http11BaseProtocol.start(Http11BaseProtocol.java:150)
at org.apache.coyote.http11.Http11Protocol.start(Http11Protocol.java:75)
at org.apache.catalina.connector.Connector.start(Connector.java:1089)
at org.apache.catalina.core.StandardService.start(StandardService.java:459)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:432)
Jan 15, 2007 11:05:01 AM org.apache.catalina.startup.Catalina start
SEVERE: Catalina.start:
LifecycleException: service.getName(): "Catalina"; Protocol handler start failed: java.net.BindException: Address already in use:8080
at org.apache.catalina.connector.Connector.start(Connector.java:1096)
INFO: Server startup in 1898 ms
Jan 15, 2007 11:05:01 AM org.apache.catalina.core.StandardServer await
SEVERE: StandardServer.await: create[8005]:
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:359)
at java.net.ServerSocket.bind(ServerSocket.java:319)
at java.net.ServerSocket.<init>(ServerSocket.java:185)
at org.apache.catalina.core.StandardServer.await(StandardServer.java:372)
at org.apache.catalina.startup.Catalina.await(Catalina.java:615)
at org.apache.catalina.startup.Catalina.start(Catalina.java:575)
Jan 15, 2007 11:06:01 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 11:06:04 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:06:12 AM org.apache.coyote.http11.Http11BaseProtocol pause
INFO: Pausing Coyote HTTP/1.1 on http-8080
Jan 15, 2007 11:06:13 AM org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
Jan 15, 2007 11:06:13 AM org.apache.coyote.http11.Http11BaseProtocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8080
Jan 15, 2007 11:06:14 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: Failed shutdown of Apache Portable Runtime
Jan 15, 2007 11:06:23 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 11:06:23 AM org.apache.coyote.http11.Http11BaseProtocol init
Jan 15, 2007 11:06:23 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1381 ms
Jan 15, 2007 11:06:23 AM org.apache.catalina.core.StandardService start
Jan 15, 2007 11:06:23 AM org.apache.catalina.core.StandardEngine start
Jan 15, 2007 11:06:24 AM org.apache.catalina.core.StandardHost start
Jan 15, 2007 11:06:25 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 11:06:27 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:06:28 AM org.apache.coyote.http11.Http11BaseProtocol start
Jan 15, 2007 11:06:28 AM org.apache.jk.common.ChannelSocket init
Jan 15, 2007 11:06:28 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/61 config=null
Jan 15, 2007 11:06:28 AM org.apache.catalina.storeconfig.StoreLoader load
Jan 15, 2007 11:06:28 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 5102 ms
Jan 15, 2007 11:17:29 AM org.apache.catalina.startup.HostConfig checkResources
INFO: Undeploying context [/untitled folder]
Jan 15, 2007 11:17:29 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 11:17:33 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:18:33 AM org.apache.catalina.startup.HostConfig checkResources
INFO: Undeploying context [/var]
Jan 15, 2007 11:24:11 AM org.apache.coyote.http11.Http11BaseProtocol pause
Jan 15, 2007 11:24:12 AM org.apache.catalina.core.StandardService stop
Jan 15, 2007 11:24:13 AM org.apache.coyote.http11.Http11BaseProtocol destroy
Jan 15, 2007 11:24:13 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 11:24:20 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 11:24:20 AM org.apache.coyote.http11.Http11BaseProtocol init
Jan 15, 2007 11:24:20 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1380 ms
Jan 15, 2007 11:24:20 AM org.apache.catalina.core.StandardService start
Jan 15, 2007 11:24:20 AM org.apache.catalina.core.StandardEngine start
Jan 15, 2007 11:24:20 AM org.apache.catalina.core.StandardHost start
Jan 15, 2007 11:24:21 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 11:24:23 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:24:25 AM org.apache.coyote.http11.Http11BaseProtocol start
Jan 15, 2007 11:24:25 AM org.apache.jk.common.ChannelSocket init
Jan 15, 2007 11:24:25 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/98 config=null
Jan 15, 2007 11:24:25 AM org.apache.catalina.storeconfig.StoreLoader load
Jan 15, 2007 11:24:25 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 5214 ms
Jan 15, 2007 11:26:13 AM org.apache.coyote.http11.Http11BaseProtocol pause
Jan 15, 2007 11:26:14 AM org.apache.catalina.core.StandardService stop
Jan 15, 2007 11:26:14 AM org.apache.coyote.http11.Http11BaseProtocol destroy
Jan 15, 2007 11:26:14 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 11:26:22 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 11:26:22 AM org.apache.coyote.http11.Http11BaseProtocol init
Jan 15, 2007 11:26:22 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1491 ms
Jan 15, 2007 11:26:22 AM org.apache.catalina.core.StandardService start
Jan 15, 2007 11:26:22 AM org.apache.catalina.core.StandardEngine start
Jan 15, 2007 11:26:22 AM org.apache.catalina.core.StandardHost start
Jan 15, 2007 11:26:23 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 11:26:26 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:26:28 AM org.apache.coyote.http11.Http11BaseProtocol start
Jan 15, 2007 11:26:28 AM org.apache.jk.common.ChannelSocket init
Jan 15, 2007 11:26:28 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=1/150 config=null
Jan 15, 2007 11:26:29 AM org.apache.catalina.storeconfig.StoreLoader load
Jan 15, 2007 11:26:29 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 7058 ms
Jan 15, 2007 11:33:34 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:35:13 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:35:59 AM org.apache.catalina.startup.HostConfig checkResources
Jan 15, 2007 11:36:07 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 11:36:10 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:36:23 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:36:37 AM org.apache.coyote.http11.Http11BaseProtocol pause
Jan 15, 2007 11:36:38 AM org.apache.catalina.core.StandardService stop
Jan 15, 2007 11:36:39 AM org.apache.coyote.http11.Http11BaseProtocol destroy
Jan 15, 2007 11:36:39 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 11:54:46 AM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 11:54:46 AM org.apache.coyote.http11.Http11BaseProtocol init
Jan 15, 2007 11:54:46 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1624 ms
Jan 15, 2007 11:54:46 AM org.apache.catalina.core.StandardService start
Jan 15, 2007 11:54:46 AM org.apache.catalina.core.StandardEngine start
Jan 15, 2007 11:54:46 AM org.apache.catalina.core.StandardHost start
Jan 15, 2007 11:54:48 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 11:54:50 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:54:52 AM org.apache.coyote.http11.Http11BaseProtocol start
Jan 15, 2007 11:54:52 AM org.apache.jk.common.ChannelSocket init
Jan 15, 2007 11:54:53 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/420 config=null
Jan 15, 2007 11:54:53 AM org.apache.catalina.storeconfig.StoreLoader load
Jan 15, 2007 11:54:53 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 7305 ms
Jan 15, 2007 11:54:55 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:54:59 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:55:22 AM org.apache.catalina.startup.HostConfig checkResources
Jan 15, 2007 11:55:53 AM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 11:55:57 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:56:06 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 11:57:00 AM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:02:50 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:03:00 PM org.apache.catalina.core.StandardContext stop
INFO: Container org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/subsonic] has not been started
Jan 15, 2007 12:03:01 PM org.apache.catalina.startup.HostConfig checkResources
Jan 15, 2007 12:03:10 PM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 12:03:13 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:04:10 PM org.apache.coyote.http11.Http11BaseProtocol pause
Jan 15, 2007 12:04:11 PM org.apache.catalina.core.StandardService stop
Jan 15, 2007 12:04:11 PM org.apache.coyote.http11.Http11BaseProtocol destroy
Jan 15, 2007 12:04:11 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 12:04:22 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
Jan 15, 2007 12:04:22 PM org.apache.coyote.http11.Http11BaseProtocol init
Jan 15, 2007 12:04:22 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1632 ms
Jan 15, 2007 12:04:22 PM org.apache.catalina.core.StandardService start
Jan 15, 2007 12:04:22 PM org.apache.catalina.core.StandardEngine start
Jan 15, 2007 12:04:22 PM org.apache.catalina.core.StandardHost start
Jan 15, 2007 12:04:24 PM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 12:04:26 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:04:27 PM org.apache.coyote.http11.Http11BaseProtocol start
Jan 15, 2007 12:04:28 PM org.apache.jk.common.ChannelSocket init
Jan 15, 2007 12:04:28 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/118 config=null
Jan 15, 2007 12:04:28 PM org.apache.catalina.storeconfig.StoreLoader load
Jan 15, 2007 12:04:29 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 6573 ms
Jan 15, 2007 12:04:42 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:05:03 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:05:38 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:06:00 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:08:02 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:14:41 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:19:28 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:59:30 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 12:59:50 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 1:02:34 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 1:03:32 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 1:05:12 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 1:05:19 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 1:06:00 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 1:11:10 PM org.apache.catalina.startup.HostConfig checkResources
Jan 15, 2007 1:11:34 PM org.apache.catalina.startup.HostConfig deployWAR
Jan 15, 2007 1:11:38 PM org.apache.catalina.core.StandardContext start
Jan 15, 2007 1:11:46 PM org.apache.catalina.core.StandardContext start
When I upload subsonic.war a subsonic directory is created within webapps. Im stumped though. I do not have a subsonic.log file to send you because I cannot find it. I think I might have to create a subsonic folder but in all the forums everyone is saying /var/subsonic. Where is /var/subsonic on a Mac? Or where do I create it?
Thanks in advance.
Paul
macboy
Postby sindre_mehus » Tue Jan 16, 2007 11:52 am
Hi Paul,
I haven't tried Subsonic on Mac yet, but maybe someone else on the forum can help?
/var/subsonic is /var/subsonic also on Mac. Please try to create it manually, and make sure Tomcat has write access to it.
Cheers,
Head Scratching
Postby macboy » Tue Jan 16, 2007 2:37 pm
Thanks for the reply. The thing is I'm not sure where to create the var/subsonic folder.
I have put my apache-tomcat-5.5.20 folder in my home folder. I can goto the terminal and startup and shutdown tomcat. I can logon to tomcat via Safari so I'm assuming that tomcat is working fine. In my apache-tomcat-5.5.20 folder I have the webapps folder and in this I have subsonic.war and a subsonic folder that gets created when I upload and deploy the sobsonic.war file.
Paul
macboy
Postby sindre_mehus » Wed Feb 17, 2010 9:09 pm
Please notice that a Mac installer for Subsonic is now available.
Read more here: http://forum.subsonic.org/forum/viewtopic.php?p=8999
A bit bummed
Postby nrinzema » Mon Apr 05, 2010 7:00 am
Its nice there is an installer, but is says it requires mac os 10.5 to install :(
I am working around this by trying to install leopard on this old out of date G4 quicksilver machine, but I have to hack up the os installer so that it ignores the awfully low specs of this machine.
It would be very considerate to list os version requirements and system spec requirements for running subsonic. I thought this would be a walk in the park install but then things started to fall apart.
Does subsonic actually require os 10.5 or does the installer system you're using require 10.5?
still worth a donation to you, but that extra spec of detail would really help people getting ready to dive in.
Cheers!
nrinzema
Postby sindre_mehus » Wed Apr 07, 2010 6:24 am
I'm sorry for not specifying the Mac OS requirements, I will add that to the web pages. Thanks for pointing it out!
I'll also try to lower the OS requirement in the next version. I'm a Mac newbie so I have to figure it out. However, the lowest version supported by PackageMaker which I use to build the installer is Mac OS 10.3 - so it won't be lower than that.
Appreciate the Response!
Postby nrinzema » Wed Apr 07, 2010 6:46 am
Thankyou so much for the response!
nrinzema
Postby steven444 » Wed May 19, 2010 11:03 am
Great post seen here! Wonderful matter. I really found it helpful. Posts like this one are really providing help to the scholars over net but unfortunately i am also getting an error and its not going even after the restart what should i do i m bizy in toefl
preparation from last ssatarday so dint get enough time to do practicals on it
steven444
Postby dobson » Fri May 21, 2010 9:45 pm
for what it's worth to mac users out there. I've been running the standalone version of subsonic for a couple years (and many versions) now with no problem on my 10.4.9 server. the new mac installer is great, but if you don't have a server with 10.5 or higher, just go for the standalone version.
create the /var/subsonic/standalone directory and drop the four files from the standalone installation into it. start it up by typing
sudo /var/subsonic/standalone/subsonic.sh
in the terminal.
the newest version (4.0) has given me a little bit of trouble in starting up subsonic... but I was able to fix that problem with a small change to the subsonic.sh startup script as documented here. (although i'm not sure why it works... so buyer beware!)
dobson
Mac Music Folder location?
Postby waynenm » Sun May 23, 2010 2:57 pm
I used to think I was pretty good at this stuff, but after trying various strings pointing at my music folder on my iMac, I can't get Subsonic to find it. Any Mac users out there who have succeeded?
Thanks.
Wayne
waynenm
Never Mind
Postby waynenm » Sun May 23, 2010 3:32 pm
I found it. Look in iTunes Preferences under Advanced.
You'll see where your music folder is...
waynenm
Postby zippy75 » Thu Jun 17, 2010 9:29 pm
[quote="sindre_mehus"]I'm sorry for not specifying the Mac OS requirements, I will add that to the web pages. Thanks for pointing it out!
Sindre[/quote]
This would be very helpful to the mac users looking to find something to replace simplify. Considering that there a a very high number of posts griping about how difficult it is to get things installed, this little bit of essential info would really help make the decision easier. I run OS 10.4.11 and I'd like to know if it will even WORK before I spend hours of frustration trying.
zippy75
Users browsing this forum: No registered users and 79 guests
