LDAP Error, unable to log on using domain user
Postby primary » Fri May 21, 2010 8:59 pm
Hi, hope some one can help me here.
I use a Ubuntu 10.04 server and subsonic 4.0.1 ( Thanks Sindre for this great app )
My domain controller is a Windows 2003 SBS R2, I have not done anything to my domain controller regarding LDAP. I've reed more than one place that LDAP is enabled on SBS2003R2 by default. But I guess I am missing something, and I dont know what it is.
LDAP URL:
ldap://servername.domain.local:389/CN=U ... n,DC=local
I do have a little problem, I dont know what CN is.
I've tried to change it to OU and ad a user to OU Users
But no luck.. Please help :) :) :)
I get the error in subsonic.log:
[2010-05-21 22:36:21,628] INFO SubsonicLdapBindAuthenticator - Failed to authenticate user 'subsonic' in LDAP.
org.acegisecurity.ldap.LdapDataAccessException: LdapCallback;[LDAP: error code 1 - 00000000: LdapErr: DSID-0C090627, comment: In order to perform this operation a successful bind must be completed on the con
nection., data 0, veceted on the connection., data 0, vece
at org.acegisecurity.ldap.LdapTemplate$LdapExceptionTranslator.translate(LdapTemplate.java:295)
at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:128)
at org.acegisecurity.ldap.LdapTemplate.searchForSingleEntry(LdapTemplate.java:246)
at org.acegisecurity.ldap.search.FilterBasedLdapUserSearch.searchForUser(FilterBasedLdapUserSearch.java:119)
at org.acegisecurity.providers.ldap.authenticator.BindAuthenticator.authenticate(BindAuthenticator.java:71)
at net.sourceforge.subsonic.ldap.SubsonicLdapBindAuthenticator.authenticate(SubsonicLdapBindAuthenticator.java:72)
at org.acegisecurity.providers.ldap.LdapAuthenticationProvider.retrieveUser(LdapAuthenticationProvider.java:233)
at org.acegisecurity.providers.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:119)
at org.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:195)
at org.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:45)
at org.acegisecurity.ui.webapp.AuthenticationProcessingFilter.attemptAuthentication(AuthenticationProcessingFilter.java:71)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:252)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
Caused by: javax.naming.NamingException: [LDAP: error code 1 - 00000000: LdapErr: DSID-0C090627, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, ve
ce
at com.sun.jndi.ldap.LdapCtx.mapErrorCode(LdapCtx.java:3072)
at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2978)
at com.sun.jndi.ldap.LdapCtx.processReturnCode(LdapCtx.java:2785)
at com.sun.jndi.ldap.LdapCtx.searchAux(LdapCtx.java:1839)
at com.sun.jndi.ldap.LdapCtx.c_search(LdapCtx.java:1762)
at com.sun.jndi.ldap.LdapCtx.c_search(LdapCtx.java:1779)
at com.sun.jndi.toolkit.ctx.ComponentDirContext.p_search(ComponentDirContext.java:412)
at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(PartialCompositeDirContext.java:394)
at com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.search(PartialCompositeDirContext.java:376)
at javax.naming.directory.InitialDirContext.search(InitialDirContext.java:284)
at org.acegisecurity.ldap.LdapTemplate$3.doInDirContext(LdapTemplate.java:249)
at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:126)
... 38 more
primary
Postby primary » Sat May 22, 2010 8:20 am
No one ??
primary
Postby primary » Wed May 26, 2010 12:47 pm
Come on people, some one must have some suggestions?
primary
Postby sliver4321 » Thu May 27, 2010 9:58 am
This probably means you have to pre-authenticate (log on) to the LDAP server before you authenticate users against the LDAP. See here:
http://groups.google.com/group/shibbole ... 0dad0a9557
Other links:
http://forums.sun.com/thread.jspa?threadID=791439
http://www.ldapbrowser.com/forum/viewto ... ?f=4&t=435
sliver4321
Hi Silver4321
Postby primary » Fri May 28, 2010 9:07 am
Thanks for replying.
Unfortunatly LDAP is not one of the things I know to much about. So muct admit that the links you sent does not tell me anything.
Anyone have any simpler steps for me to try out?
primary
Problem solved
Postby primary » Fri May 28, 2010 11:34 pm
As I indicated in this post. I had no Idea what the "path" for LDAP would be on my domain. The answer to find it out was easier than I first thought. But...
It did require me to download Softerra LDAP brower. Util is free. Just install, make a profile, connect to domain using domain\user password. And brows for your Users OU.. The path is displayed selecting properties for the OU selected.. And there you go.. LDAP Path..
primary
