CPU at 100% when updating the search list (SOLVED)
Postby berthiggins » Mon Jun 28, 2010 4:53 pm
Hi I have been using Subsonic for a while with collection of around 300GB
Recently I updated the collection to around 730 GB.
Now when it tries to update the search list the cpu goes to around 98% and stays there.
I have left it for a day without it coming to an end even if I stop subsonic and start it it goes to a high cpu immediately.
I have removed and re-installed Subsonic and all is well with the search function disabled.
This is a P3 1GHZ cpu with about 300MB of ram
it is running ubuntu server 8.10 .
I installed from the .deb file.
Do I need the more complex install type or is my server not "man" enough for the job with this collection?
Any ideas or hints appreciated.
:D
berthiggins
Postby berthiggins » Tue Jun 29, 2010 6:43 pm
Any Ideas anyone?
berthiggins
Postby mason » Thu Jul 01, 2010 12:23 pm
im running a equal large collection on a amd 2400 be with 2gb ram, and subsonic takes a lot of power from it. i guess your little p3 is at it limits, but you can try and enlarge the java space maybe this will help
edit the subsonic.sh script and mod the following line :
SUBSONIC_MAX_MEMORY=64
I think 64mb was the default value, just try to edit it to 128 or maybe 196
mason
Postby carbonrough » Thu Jul 01, 2010 6:33 pm
.... going by the size of your collection, I'd feed Subsonic ~250MB of RAM once you've fed your under nourished Ubuntu :shock: :lol:
Peace
CR.
carbonrough
Postby berthiggins » Thu Jul 01, 2010 9:24 pm
Thanks guys I will try that!
berthiggins
Postby delcypher » Sun Jul 04, 2010 11:44 am
If the high CPU usage is causing a problem then you can adjust subsonic's nice value (essentially adjusting the process's priority) to make your system more responsive.
My guess is that the problem will still persist until subsonic has finished building its search index.
See
http://www.linux.com/archive/feed/58638
delcypher
Postby berthiggins » Sat Jul 10, 2010 1:14 pm
Thanks everyone
I have increased memory on java to 256 MB ( found I had 512 rather than 300 )
I hver reniced subsonic to +12 we shall see!
berthiggins
Postby berthiggins » Sat Jul 10, 2010 2:46 pm
Thanks Guys that worked! I now have a search index.
I think the renice was the main thing as I watched the index built with a tail -f on the subsonic.log and monitored the system state with top .
the java memory usage was never very high but the cpu usage kept nice and low.
Thanks for your help!
berthiggins
