I forgot my password
Frequently asked questions.
Postby piscotikus » Thu Jul 22, 2010 10:52 am
What can I do if I forgot my password?
piscotikus
Postby mgrant » Thu Jul 22, 2010 6:33 pm
You subsonic password?
Look on the subsonic server in /var/subsonic/db (or c:\subsonic\db) for a file called subsonic.script. In this file you should find some text that looks like this:
INSERT INTO USER VALUES('your_username','enc:70617373776f7264',0,0,0,FALSE)
The values will differ from that above. The important part is the 'enc:70617373776f7264'. Take the part after the colon (represented here by '70617373776f7264') and plug it into the hex2asii converter at:
http://www.dolcevie.com/js/converter.html
It should decode the hex and print the ascii password. If you decode my example above it should be 'password'.
-mg
edit:
You can, of course, decode the string without the use of the website above (but why would you?):
0x70 = 'p'
0x61 = 'a'
0x73 = 's'
0x73 = 's'
0x77 = 'w'
0x6f = 'o'
0x72 = 'r'
0x64 = 'd'
mgrant
Postby sindre_mehus » Tue Feb 01, 2011 12:35 pm
On Mac the file in question is /Library/Application Support/Subsonic/db/subsonic.script
Return to FAQs
