Donate for API use?
Donate for API use?
Postby gummbah » Wed Aug 04, 2010 4:02 pm
I am using iSub and since today I get the message that it looks like the trial period of use of the API is over. It says I should donate to the Subsonic project.
But I donated about two weeks ago in order to get myusername.subsonic.org working.
What should I do? Donate again? Or is something wrong?
gummbah
Postby sindre_mehus » Wed Aug 04, 2010 8:22 pm
You don't need to donate again. Please email me your ***.subsonic.org address so I can look into it. (sindre@activeobjects.no)
Postby moepen » Sat Sep 11, 2010 4:30 am
I have the same problem. I recently donated, and as of today iSub tells me: "It looks like the trial period for use of the API on this Subsonic server is over." And it asks me to donate.
Please help,
Thank you,
Max.
moepen
Postby moepen » Mon Sep 13, 2010 8:43 pm
Please help, I cannot use iSub anymore because of this issue.
It came out of the blue, I had made no changes to the server, nor to the settings in the app.
Max.
moepen
Postby moepen » Mon Sep 13, 2010 9:02 pm
Here's a workaround that was postedby baroquedub and has worked for me too:
"Okay found that simply clicking on 'Donate' and re-entering the key works fine"
I don't know how long this will hold, it shouldn't be necessary in the first place, but it works for now.
Max.
moepen
Postby bluetooth » Thu Sep 16, 2010 1:32 am
I (my friend) is having the same problem. She donated and subsonic shows the donation so that is all good.
However, iSub says subsonic needs a donation and the API is snookered. I should add I can access subsonic from a browser using http://hostname.subsonic.org so I know that's working.
paid Subsonic user
bluetooth
Postby occultus » Sat Oct 02, 2010 4:39 am
I'm having this same problem and when I go to the donate screen it says it is registered and does not even show a place to insert the license key. any help?
occultus
Postby triadmidas » Sat Oct 02, 2010 11:34 pm
Has this been fixed yet for anyone? I am experiencing a similar problem.
triadmidas
Postby wakajazz » Sun Oct 03, 2010 9:59 pm
Same problem here, but only on my iPod Touch when using iSub, my IPhone iSub app works fine??????
wakajazz
Users browsing this forum: No registered users and 48 guests
