Workaround to play internet radio on the jukebox player
Tutorials, tips and tricks.
Postby ccandreva » Wed Aug 25, 2010 11:42 pm
OK, this is a little -- involved. However, it works, at least for me on Linux (Fedora).
I save the URL of the station in a .m3u file, and use mplayer to to play the streams. However, since mplayer can't write directly to STDOUT, we'll need a shell script to do this. It creates a named pipe, writes to it, and `cat`s the pipe. I modified this from a script used for Asterisk. Save the following as a shell script called mpstream in /var/subsonic/transcode:
#!/bin/bash
PIPE="/tmp/subsonic-moh-pipe"
if [ -p $PIPE ]; then
  pkill mplayer
  rm $PIPE
fi
mknod $PIPE p
mplayer -quiet -really-quiet -ao pcm:file=$PIPE -playlist "$@" | cat $PIPE
rm $PIPE
Make sure mpstream is mode 755 (or at least executable by the user Subsonic runs as).
Under General settings, add .m3u to the Music Mask. Now add a transcoder for "m3u > wav" This just needs a single transcode step,
mpstream %s
And that's it. Load and play your .m3u file and you should hear your stream. The .m3u files need to be saved with your music (mp3, flac, etc) files, NOT with playlists.
ccandreva
Postby j3tblk » Wed Sep 15, 2010 8:29 am
thanks for the info. Any pointers for Windows?
j3tblk
Postby ccandreva » Wed Sep 15, 2010 11:04 am
Sorry, never touch the stuff. :-)
ccandreva
Postby soloport » Tue Sep 28, 2010 5:57 am
Everything works on the command line:
/srv/httpd/vhosts/subsonic/transcode/mpstream "/home/audio/Internet Radio/Some Station.m3u"
This produces lots of unicode all over the console (until Ctrl-C) as expected.
Entering the following at the command line also works (audio out):
mplayer -playlist "/home/audio/Internet Radio/Some Station.m3u"
However, subsonic freezes (and no audio):
$ ps -eww f
30259 pts/1    Sl     0:15 java -Xmx100m -Dsubsonic.home=/srv/httpd/vhosts/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=8888 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/home/audio -Dsubsonic.defaultPodcastFolder=/srv/httpd/vhosts/subsonic/podcast -Dsubsonic.defaultPlaylistFolder=/srv/httpd/vhosts/subsonic/playlists -jar subsonic-booter-jar-with-dependencies.jar
30331 pts/1    S      0:00  \_ /bin/bash /srv/httpd/vhosts/subsonic/transcode/mpstream /home/audio/Internet Radio/Some Station.m3u
30337 pts/1    S      0:00      \_ cat /tmp/subsonic-moh-pipe
Name     Convert from     Convert to     Step 1
m3u > wav      m3u      wav      mpstream %s
Anything else I should try?
Thanks.
soloport
Postby ccandreva » Tue Sep 28, 2010 11:09 am
It looks like mplayer isn't running, as it doesn't show in the 'ps' output.
Trying putting the full path to mplayer into the script, ie /usr/bin/mplayer -quiet .....
ccandreva
Postby soloport » Wed Sep 29, 2010 1:44 am
Thanks for the quick reply.
Fixed with:
echo "nolirc=yes" >> ~/.mplayer/config
Error messages "mplayer: could not connect to socket" persisted even after installing lirc, so, disabled.
soloport
Possible in OSX?
Postby bull » Sat Nov 13, 2010 7:19 am
Has anyone had any luck getting this to work with Subsonic on OSX? I've had to make a few modifications to the code (killall and mkfifo) as seen here:
#!/bin/bash
  killall mplayer
  rm $PIPE
fi
mkfifo $PIPE
/opt/local/bin/mplayer -quiet -really-quiet -ao pcm:file=$PIPE -playlist "$@" | cat $PIPE
rm $PIPE
If I try running this from the command line I can see a process of mplayer running and the temp pipe is created, but I get a heap of unicode characters spewing out similar to soloport...and when I try launching it from Subsonic the only thing logged is:
[11/13/10 8:06:59 PM NZDT]   INFO   JukeboxService   Starting jukebox player on behalf of bull
[11/13/10 8:06:59 PM NZDT]   INFO   PlaylistInputStream   bull listening to "_RADIO/SomaFM - Indie Pop Rocks.m3u"
[11/13/10 8:06:59 PM NZDT]   DEBUG   JukeboxService   stateUpdated : OPENING:-1:java.io.BufferedInputStream@1dab2ba7
[11/13/10 8:06:59 PM NZDT]   WARN   JukeboxService   Error in BasicPlayer.play()
Any ideas? Thanks!
bull
Re: Possible in OSX?
Postby soloport » Sat Jan 01, 2011 4:46 am
bull wrote:Any ideas? Thanks!
Did you give the above fix a try? Here again,
The problem is mplayer expects lirc, so it needs to be disabled.
soloport
Re: Workaround to play internet radio on the jukebox player
Postby phartl » Fri Sep 13, 2013 9:13 am
Hi
Can you tell me where I have to put this code to ?
My subsonic does not play the inet stream (m3u)
regards
Patrick
phartl
Postby boxjellyfish » Sat Jan 11, 2014 10:49 am
Hi guys,
For windows i've used the following trick:
- put 2 php files on the subsonic server with the following code
One to start the radio:
//php file to start the radio on the server
$argument=$_GET["radio"];
echo "<pre>".shell_exec("psexec \\\\<lokal user> cmd.exe /C 123456 & start.bat $argument")."</pre>";
One to stop the radio:
//php file to stop the radio on the server
echo "<pre>".shell_exec("psexec \\\\<lokal user> cmd.exe /C 123456 & stop.bat")."</pre>";
- add 2 batch files which startup vlc with radiostream. The radiostream is selected by the given argument.
example of the start.bat file
echo off
echo starting %1
rem first kill all vlc instances.
taskkill /f /im vlc.exe
ping -n 3 127.0.0.1 > NUL
rem Add radio stations. radio.php?radio=[radio]
rem will be used to switch between radiostartion
SET STREAM=http://8623.live.streamtheworld.com:80/SKYRADIO_SC
GOTO CASE_%1
:CASE_SKY
    GOTO END_SWITCH
:CASE_CAZ
    SET STREAM=http://81.23.249.10/caz_audio_01
    GOTO END_SWITCH
:CASE_ARROW
    SET STREAM=http://81.23.249.10/ArrowAudio02
    GOTO END_SWITCH
:CASE_CANDLELIGHT
    SET STREAM=http://ice1.streamzilla.jet-stream.nl:8000/ilsemedia=ice7
    GOTO END_SWITCH
:CASE_80S
    SET STREAM=http://7639.live.streamtheworld.com:80/977_80_SC
    GOTO END_SWITCH
:CASE_70S
    SET STREAM=http://stream-45.shoutcast.com:80/all_hit_70s_skyfm_mp3_96kbps
    GOTO END_SWITCH
:CASE_DANCEWITHME
    SET STREAM=http://stream.radioextra-bg.net:8000/dancewithme
    GOTO END_SWITCH
:CASE_FRESHFM
    SET STREAM=http://stream12.freshfmonline.com/
    GOTO END_SWITCH
:CASE_MNM
    SET STREAM=http://mp3.streampower.be/mnm-high.mp3?rand=134
    GOTO END_SWITCH
:CASE_QMUSIC
    SET STREAM=http://vip1.str.reasonnet.com/qmusic.wma.96
    GOTO END_SWITCH
:CASE_RADIO1
    SET STREAM=http://icecast.omroep.nl/radio1-bb-mp3
    GOTO END_SWITCH
:CASE_RADIO2
    SET STREAM=http://icecast.omroep.nl/radio2-bb-mp3
    GOTO END_SWITCH
:CASE_TOP2000
    SET STREAM=http://icecast.omroep.nl/radio2-top2000-mp3
    GOTO END_SWITCH
:CASE_RADIO3
    SET STREAM=http://icecast.omroep.nl/3fm-bb-mp3
    GOTO END_SWITCH
:CASE_FUNX
    SET STREAM=http://icecast.omroep.nl/funx-bb-mp3
    GOTO END_SWITCH
:CASE_FUNXHIPHOP
    SET STREAM=http://icecast.omroep.nl/funx-hiphop-bb-mp3
    GOTO END_SWITCH
:CASE_REGGEA101
    SET STREAM=http://eu4.101.ru/c5_5_128?st=&amp;t=
    GOTO END_SWITCH
:CASE_ROOTSREGGEA
    SET STREAM=http://stream-102.shoutcast.com:80/rootsreggae_skyfm_mp3_96kbps
    GOTO END_SWITCH
:CASE_SKY80S
    SET STREAM=http://stream-39.shoutcast.com:80/the80s_skyfm_mp3_96kbps
    GOTO END_SWITCH
:CASE_BRUSSEL
    SET STREAM=http://mp3.streampower.be/stubru-high
    GOTO END_SWITCH
:CASE_TOPHITS
    SET STREAM=http://stream-20.shoutcast.com:80/tophits_skyfm_mp3_96kbps
    GOTO END_SWITCH
:CASE_538DD
    SET STREAM=http://82.201.100.10:8000/RD01_538_Dancedepartment
    GOTO END_SWITCH
:CASE_538HITZONE
    SET STREAM=http://82.201.100.10:8000/WEB11
    GOTO END_SWITCH
:CASE_JUIZE
    SET STREAM=http://82.201.100.9:8000/juizefm
    GOTO END_SWITCH
:CASE_PARTY
    SET STREAM=http://82.201.100.10:8000/WEB16
    GOTO END_SWITCH
:CASE_538
    SET STREAM=http://82.201.100.9:8000/radio538
    GOTO END_SWITCH
:CASE_53L8
    SET STREAM=http://82.201.100.10:8000/WEB21
    GOTO END_SWITCH
:CASE_SKYLOVESONGS
    SET STREAM=http://8623.live.streamtheworld.com:80/SKYLOVEAAC_SC
    GOTO END_SWITCH
:CASE_SKYSEASON
    SET STREAM=http://8593.live.streamtheworld.com:80/SEASONALAAC_SC
    GOTO END_SWITCH
:CASE_OMROEPBRABANT
    SET STREAM=mms://wm.media53.kpnstreaming.nl/kpn=OmroepBrabantL=OmroepBrabantHq
    GOTO END_SWITCH
rem *************************************************
rem    reggea
:CASE_BIGUP
    SET STREAM=http://radio.bigupradio.com.:8000/listen.pls
    GOTO END_SWITCH
:CASE_REGGEAKINGS
    SET STREAM=http://www.raggakings.net/listen.m3u
    GOTO END_SWITCH
:CASE_JAMAICAN
    SET STREAM=http://www.jamaicanradio.info/live.m3u
    GOTO END_SWITCH
:CASE_BIGVIBES
    SET STREAM=http://streams.bigvibez.com:7000/listen.pls
    GOTO END_SWITCH
:CASE_REGGEAME
    SET STREAM=http://streamingpulse.tv/sc10/tunein.php/reggaeme/playlist.pls
    GOTO END_SWITCH
:CASE_M2REGGEA
    SET STREAM=http://www.m2radio.fr/pls/m2sunshine_winamp.m3u
    GOTO END_SWITCH
:END_SWITCH
rem change this location if VLC is located in another directory
set VLC_LOC="\Program Files (x86)\VideoLAN\VLC"
c:
cd %VLC_LOC%
vlc.exe %STREAM%
Example of the stop.bat file
rem try to kill vlc.
rem and try again to be sure it stopped
Now you can add internet radio to your subsonic configuration with URL's like this:
http://<host of subsonic server>:<port>/<subdir>/radio.php?radio=JUIZE
After pressing the link vlc will be opened with the radio stream you choose. You can make different links for server side radio and client side radio.
To control the radio with a mobile device you can use the app "Remote Launcher" and startup the batch files.
This trick works for several month flauwless..
boxjellyfish
Postby votti » Sun Jan 25, 2015 6:34 pm
Hi guys,
Does this still work for the current subsonic?
I run subsonic on debian and I get an Java error when trying to play something:
Error in jukebox: java.io.EOFException
Any idea what could be the cause for this one?
Cheers an thanks!
votti
Postby henrikp » Wed Jan 20, 2016 5:12 pm
The only logical course is to awaken this thread once more. Everything else works but it seems to me that the transcoding settings are hardcoded for jukebox mode, atleast in the current releases. The m3u file is Always executed by ffmpeg in jukebox mode but once I change it back to the web player mpstream executes mplayer and starts playing on the server. But since there is no redirection in that mode, the sound is sent to the void.
TL;DR - Are the transcoding settings for the jukebox mode set in stone or can I change them as well?
henrikp
Return to Tutorials
