DWREngine is undefined
Postby Inge » Sun Apr 16, 2006 4:46 pm
I get this Java error in the browser when adding a song to the current playlist.
The song is added to the list, but the browser shows the Java error either verbose or as the !-yellow-warningsign in the lower left corner of the browser window, dependent on the browser configuration.
Details:
Line: 22
Char: 10
Error: DWREngine is undefined
Code: 0
URL: http://myipaddress:8080/subsonic/playlist.jsp?add=%2F%Home.....
Running on Tomcat 5.0.28, Java SDK 1.5.0.06 on my RedHat 8.
Tested with IE 6 browser on XP Clients with Java JRE 1.5.0 and 1.4.2.
Seen this before?
Inge.
Inge
Postby sindre_mehus » Sun Apr 16, 2006 8:55 pm
Hm, the problem seems to be that a JavaScript library is not loaded.
Can you please try to open this link: http://myipaddress:8080/subsonic/dwr/engine.js
It should return something like this:
function DWREngine() { }
DWREngine.setErrorHandler = function(handler) {
DWREngine._errorHandler = handler;
Do you get the same error on other browsers (Opera, Firefox)?
Regards, Sindre
Postby Inge » Mon Apr 17, 2006 3:57 pm
I don't see the error using Opera 8.52, haven't tested with Firefox. I don't know if this is because Opera doesn't display script error by default, or not...
Whichever browser I use, the URL below throws an 500 Exception with the following text (+ a logner Root Cause):
exception
javax.servlet.ServletException: Servlet.init() for servlet dwr-invoker threw exception
   org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:118)
   org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:160)
   org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:799)
   org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:705)
   org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:577)
   org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:683)
   java.lang.Thread.run(Thread.java:595)
That's the same exception I get when trying a random url that doesn't exist, such as:
http://myipaddress:8080/subsonic/dwr/someotherpage.js
Inge.
Inge
Postby sindre_mehus » Mon Apr 17, 2006 6:14 pm
Does the root exception look similar to this?
javax.xml.transform.TransformerFactoryConfigurationError: Provider org.apache.xalan.processor.TransformerFactoryImpl not found
     javax.xml.transform.TransformerFactory.newInstance(Unknown Source)
     uk.ltd.getahead.dwr.convert.DOMConverter.<init>(DOMConverter.java:134)
If that's the case, then the problem is most likely some conflicting xml-parser libraries in Java 1.5 and Tomcat 5.0.
You can either upgrade to a later Tomcat version, or delete TOMCAT_HOME/common/endorsed/xml-apis.jar.
Here are some links with more info:
http://www.jivesoftware.com/jive/thread ... eID=107225
http://www.junlu.com/msg/166072.html
Thanks for letting me know! Please tell me how it goes.
Sindre :-)
Postby Inge » Mon Apr 17, 2006 9:24 pm
I removed xml-apis.jar for now, and the problem is gone. It also made adding songs to the current playlist a lot faster :)
I'll try to upgrade Tomcat later.
Thanks for your help, and for a great product!
regards,
Inge.
Inge
Postby nishanth » Mon Jun 18, 2007 12:02 pm
Hey sindre,
I was facing the same problem while using DWR for my application. Thanks a lot for ur suggestions. It saved me a lot of time. And the links were really helpful. Initially I had removed xmlParserAPIs.jar from common/endorsed. This also worked but the Tomcat is a shared one, so we were not allowed to remove jar files. Hence had to add xalan.jar to common/endorsed which also works perfectly. Thanks again :)
Regards
Nish
sindre_mehus wrote:Does the root exception look similar to this?
Sindre :-)
nishanth
Yep copy xalan-j2.jar to /var/lib/tomcat5/common/endorsed
Postby linuxman » Sun Nov 18, 2007 8:19 am
Copy that jar and then restart tomcat5 and your problems go away. I was running tomcat 5.5 on fc7 and apparently tomcat can't find a common library in the system somehow and it produces all the errors trying to write the tags. Soon as I got this in the system is much faster and the java errors in IE7 have disappeared and can write the tags.
linuxman
Users browsing this forum: No registered users and 72 guests
