Subsonic Not Staying Up/Online
Postby billy bob thorton » Wed Oct 27, 2010 1:18 am
Hi all, I have an annoying situation. Since I have installed win 7, I haven't been able to keep a connection to the service for more than 4 or 5 days. After those 4-5 days or so, the tray icon turns red as opposed to the nice green! Still says the service is running however, it is not. I like to leave the server on 24/7 to access the music. I have tried to end the process and restart the process etc. however the only way to fix this is to reboot.
After the reboot the app service starts again and I am off to the races for another few days with a nice green tray icon until it goes down again. I am using the latest and greatest. It was the same situation with the previous version as well.
Is anyone else experiencing this issue?
I use NO IP as the DNS app so a dynamic IP isn't the issue. I also run another server on the same machine, different port, and it doesn't ever go down.
I am the only one who uses the machine and sometimes I am not on it for days, only to check on my server status!
P.S. when it is up and running, it runs great and I have no issues.
Any help would be appreciated. I searched the forums and didn't get a hit.
Thanks in advance.
BBT
billy bob thorton
Postby SteveyDevey » Wed Oct 27, 2010 9:53 am
I'm having the same (or at least a similar issue). I've found that I can open up the tray app, stop then start the server from there, and it'll work again for a few days.
SteveyDevey
Postby kermit22 » Wed Oct 27, 2010 3:22 pm
Does the subsonic log say anything when it goes down? I would also check to see if there is anything about Subsonic in the Applications section in your Event Viewer on your servers?
kermit22
Postby Flyby » Sat Oct 30, 2010 12:56 pm
I have the same problem on an Ubuntu 10.04 server.
Subsonic is up for a few days and then stops.
Flyby
Postby Flyby » Tue Nov 02, 2010 3:30 pm
After a reboot a few day´s ago, again unable to connect.
Subsonic seems to be running.
Here is a copy of the last days of the subsonic log:
[2010-10-31 17:32:47,849] DEBUG NetworkService - Completed PortForwardingTask
[2010-10-31 17:37:42,419] INFO PlaylistInputStream - rob listening to "Rapid transit/03 - Azymuth - Rapid transit - Missing doto.mp3"
[2010-10-31 18:32:47,849] DEBUG NetworkService - Starting PortForwardingTask
[2010-10-31 18:32:50,999] INFO NetworkService - Successfully forwarding port 4040.
[2010-10-31 18:32:50,999] DEBUG NetworkService - Completed PortForwardingTask
[2010-10-31 19:32:51,001] DEBUG NetworkService - Starting PortForwardingTask
[2010-10-31 19:32:54,192] INFO NetworkService - Successfully forwarding port 4040.
[2010-10-31 19:32:54,192] DEBUG NetworkService - Completed PortForwardingTask
[2010-10-31 20:32:54,193] DEBUG NetworkService - Starting PortForwardingTask
[2010-10-31 20:32:57,233] INFO NetworkService - Successfully forwarding port 4040.
[2010-10-31 20:32:57,233] DEBUG NetworkService - Completed PortForwardingTask
[2010-10-31 21:32:57,234] DEBUG NetworkService - Starting PortForwardingTask
[2010-10-31 21:33:00,394] INFO NetworkService - Successfully forwarding port 4040.
[2010-10-31 21:33:00,394] DEBUG NetworkService - Completed PortForwardingTask
[2010-10-31 22:33:00,394] DEBUG NetworkService - Starting PortForwardingTask
[2010-10-31 22:33:03,429] INFO NetworkService - Successfully forwarding port 4040.
[2010-10-31 22:33:03,430] DEBUG NetworkService - Completed PortForwardingTask
[2010-10-31 23:33:03,511] DEBUG NetworkService - Starting PortForwardingTask
[2010-10-31 23:33:06,545] INFO NetworkService - Successfully forwarding port 4040.
[2010-10-31 23:33:06,545] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 00:33:06,546] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 00:33:09,693] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 00:33:09,732] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 01:33:09,733] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 01:33:12,915] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 01:33:12,915] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 02:33:12,915] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 02:33:15,949] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 02:33:15,949] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 03:00:00,162] INFO SearchService - Starting to create search index.
[2010-11-01 03:00:01,457] INFO SearchService - Created search index with 1000 entries.
[2010-11-01 03:00:02,055] INFO SearchService - Created search index with 2000 entries.
[2010-11-01 03:00:02,482] INFO SearchService - Created search index with 3000 entries.
[2010-11-01 03:00:03,126] INFO SearchService - Created search index with 4000 entries.
[2010-11-01 03:00:03,840] INFO SearchService - Created search index with 5000 entries.
[2010-11-01 03:00:04,572] INFO SearchService - Created search index with 6000 entries.
[2010-11-01 03:00:05,355] INFO SearchService - Created search index with 7000 entries.
[2010-11-01 03:00:05,887] INFO SearchService - Created search index with 8000 entries.
[2010-11-01 03:00:05,969] INFO SearchService - Created search index with 9000 entries.
[2010-11-01 03:00:06,447] INFO SearchService - Created search index with 10000 entries.
[2010-11-01 03:00:06,841] INFO SearchService - Created search index with 11000 entries.
[2010-11-01 03:00:07,224] INFO SearchService - Created search index with 12000 entries.
[2010-11-01 03:00:07,601] INFO SearchService - Created search index with 13000 entries.
[2010-11-01 03:00:08,138] INFO SearchService - Created search index with 14000 entries.
[2010-11-01 03:00:08,327] INFO SearchService - Created search index with 15000 entries.
[2010-11-01 03:00:08,825] INFO SearchService - Created search index with 16000 entries.
[2010-11-01 03:00:09,321] INFO SearchService - Created search index with 17000 entries.
[2010-11-01 03:00:09,683] INFO SearchService - Created search index with 18000 entries.
[2010-11-01 03:00:10,086] INFO SearchService - Created search index with 19000 entries.
[2010-11-01 03:00:10,865] INFO SearchService - Created search index with 20000 entries.
[2010-11-01 03:00:11,499] INFO SearchService - Created search index with 21000 entries.
[2010-11-01 03:00:11,646] INFO SearchService - Created search index with 22000 entries.
[2010-11-01 03:00:11,974] INFO SearchService - Created search index with 23000 entries.
[2010-11-01 03:00:12,379] INFO SearchService - Created search index with 24000 entries.
[2010-11-01 03:00:12,917] INFO SearchService - Created search index with 25000 entries.
[2010-11-01 03:00:13,536] INFO SearchService - Created search index with 26000 entries.
[2010-11-01 03:00:13,922] INFO SearchService - Created search index with 27000 entries.
[2010-11-01 03:00:14,320] INFO SearchService - Created search index with 28000 entries.
[2010-11-01 03:00:14,453] INFO SearchService - Created search index with 29000 entries.
[2010-11-01 03:00:14,842] INFO SearchService - Created search index with 30000 entries.
[2010-11-01 03:00:15,559] INFO SearchService - Created search index with 31000 entries.
[2010-11-01 03:00:16,027] INFO SearchService - Created search index with 32000 entries.
[2010-11-01 03:00:16,714] INFO SearchService - Created search index with 33000 entries.
[2010-11-01 03:00:17,159] INFO SearchService - Created search index with 34000 entries.
[2010-11-01 03:00:17,509] INFO SearchService - Created search index with 35000 entries.
[2010-11-01 03:00:17,648] INFO SearchService - Created search index with 36000 entries.
[2010-11-01 03:00:17,998] INFO SearchService - Created search index with 37000 entries.
[2010-11-01 03:33:15,950] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 03:33:19,039] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 03:33:19,039] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 04:33:19,040] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 04:33:22,149] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 04:33:22,149] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 05:33:22,150] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 05:33:25,180] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 05:33:25,180] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 06:33:25,182] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 06:33:28,224] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 06:33:28,224] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 07:33:28,225] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 07:33:31,256] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 07:33:31,256] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 08:33:31,257] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 08:33:34,364] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 08:33:34,364] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 09:33:34,365] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 09:33:37,415] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 09:33:37,415] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 10:33:37,416] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 10:33:40,780] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 10:33:40,780] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 11:33:40,781] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 11:33:43,816] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 11:33:43,816] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 12:33:43,817] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 12:33:46,932] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 12:33:46,932] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 13:33:46,933] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 13:33:50,036] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 13:33:50,036] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 14:01:03,001] INFO PlaylistInputStream - rob listening to "Al Green - The Definitive Greatest Hits (Advance 2007) - Soul/01-al_green-lets_stay_together.mp3"
[2010-11-01 14:33:50,038] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 14:33:53,223] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 14:33:53,223] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 14:37:35,183] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-11-01 14:37:35,184] INFO PodcastService - Completed scheduled Podcast refresh.
[2010-11-01 15:33:53,224] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 15:33:56,252] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 15:33:56,252] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 16:33:56,253] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 16:33:59,374] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 16:33:59,374] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 17:33:59,374] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 17:34:02,400] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 17:34:02,400] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 18:34:02,401] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 18:34:05,426] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 18:34:05,426] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 19:34:05,428] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 19:34:08,541] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 19:34:08,541] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 20:34:08,541] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 20:34:11,647] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 20:34:11,647] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 21:34:11,648] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 21:34:14,763] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 21:34:14,764] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 22:34:14,764] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 22:34:17,790] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 22:34:17,791] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-01 23:34:17,792] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-01 23:34:20,817] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-01 23:34:20,818] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 00:34:20,818] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 00:34:23,844] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 00:34:23,844] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 01:34:23,845] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 01:34:26,893] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 01:34:26,893] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 02:34:26,893] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 02:34:29,918] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 02:34:29,918] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 03:00:00,164] INFO SearchService - Starting to create search index.
[2010-11-02 03:00:01,324] INFO SearchService - Created search index with 1000 entries.
[2010-11-02 03:00:01,923] INFO SearchService - Created search index with 2000 entries.
[2010-11-02 03:00:02,180] INFO SearchService - Created search index with 3000 entries.
[2010-11-02 03:00:02,603] INFO SearchService - Created search index with 4000 entries.
[2010-11-02 03:00:03,082] INFO SearchService - Created search index with 5000 entries.
[2010-11-02 03:00:03,678] INFO SearchService - Created search index with 6000 entries.
[2010-11-02 03:00:04,128] INFO SearchService - Created search index with 7000 entries.
[2010-11-02 03:00:04,596] INFO SearchService - Created search index with 8000 entries.
[2010-11-02 03:00:04,940] INFO SearchService - Created search index with 9000 entries.
[2010-11-02 03:00:05,382] INFO SearchService - Created search index with 10000 entries.
[2010-11-02 03:00:05,847] INFO SearchService - Created search index with 11000 entries.
[2010-11-02 03:00:06,136] INFO SearchService - Created search index with 12000 entries.
[2010-11-02 03:00:06,704] INFO SearchService - Created search index with 13000 entries.
[2010-11-02 03:00:07,208] INFO SearchService - Created search index with 14000 entries.
[2010-11-02 03:00:07,634] INFO SearchService - Created search index with 15000 entries.
[2010-11-02 03:00:08,107] INFO SearchService - Created search index with 16000 entries.
[2010-11-02 03:00:08,623] INFO SearchService - Created search index with 17000 entries.
[2010-11-02 03:00:09,138] INFO SearchService - Created search index with 18000 entries.
[2010-11-02 03:00:09,530] INFO SearchService - Created search index with 19000 entries.
[2010-11-02 03:00:09,916] INFO SearchService - Created search index with 20000 entries.
[2010-11-02 03:00:10,540] INFO SearchService - Created search index with 21000 entries.
[2010-11-02 03:00:10,822] INFO SearchService - Created search index with 22000 entries.
[2010-11-02 03:00:11,316] INFO SearchService - Created search index with 23000 entries.
[2010-11-02 03:00:11,985] INFO SearchService - Created search index with 24000 entries.
[2010-11-02 03:00:12,453] INFO SearchService - Created search index with 25000 entries.
[2010-11-02 03:00:13,085] INFO SearchService - Created search index with 26000 entries.
[2010-11-02 03:00:13,557] INFO SearchService - Created search index with 27000 entries.
[2010-11-02 03:00:13,988] INFO SearchService - Created search index with 28000 entries.
[2010-11-02 03:00:14,419] INFO SearchService - Created search index with 29000 entries.
[2010-11-02 03:00:14,843] INFO SearchService - Created search index with 30000 entries.
[2010-11-02 03:00:15,168] INFO SearchService - Created search index with 31000 entries.
[2010-11-02 03:00:15,645] INFO SearchService - Created search index with 32000 entries.
[2010-11-02 03:00:16,407] INFO SearchService - Created search index with 33000 entries.
[2010-11-02 03:00:21,169] INFO SearchService - Created search index with 34000 entries.
[2010-11-02 03:00:45,554] INFO SearchService - Created search index with 35000 entries.
[2010-11-02 03:01:12,578] INFO SearchService - Created search index with 36000 entries.
[2010-11-02 03:01:25,790] INFO SearchService - Created search index with 37000 entries.
[2010-11-02 03:34:29,919] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 03:34:32,975] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 03:34:32,975] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 04:34:32,976] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 04:34:36,003] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 04:34:36,004] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 05:34:36,005] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 05:34:39,116] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 05:34:39,116] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 06:34:39,117] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 06:34:42,234] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 06:34:42,234] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 07:34:42,235] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 07:34:45,341] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 07:34:45,341] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 08:34:45,342] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 08:34:48,447] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 08:34:48,447] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 09:34:48,448] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 09:34:51,477] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 09:34:51,477] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 10:34:51,478] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 10:34:54,630] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 10:34:54,630] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 11:34:54,631] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 11:34:57,657] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 11:34:57,657] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 12:34:57,658] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 12:35:00,682] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 12:35:00,682] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 13:35:00,683] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 13:35:03,707] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 13:35:03,707] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 14:35:03,709] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 14:35:06,733] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 14:35:06,733] DEBUG NetworkService - Completed PortForwardingTask
[2010-11-02 14:37:35,149] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-11-02 14:37:35,149] INFO PodcastService - Completed scheduled Podcast refresh.
[2010-11-02 15:35:06,734] DEBUG NetworkService - Starting PortForwardingTask
[2010-11-02 15:35:09,758] INFO NetworkService - Successfully forwarding port 4040.
[2010-11-02 15:35:09,758] DEBUG NetworkService - Completed PortForwardingTask
Please help.
Flyby
Postby kermit22 » Tue Nov 02, 2010 4:54 pm
Flyboy it looks like something is wrong with your UPnP setup. I would try to manually forward your ports on your router to see if that fixes it. Let me know if you need a hand with that.
kermit22
Postby alphawave7 » Tue Nov 02, 2010 5:01 pm
kermit22 wrote:Flyboy it looks like something is wrong with your UPnP setup. I would try to manually forward your ports on your router to see if that fixes it. Let me know if you need a hand with that.
Hmmm..why would forwarding need a refresh every hour? Could the router have a time-out setting on that, and if so would it report that to SS, or is SS itself simply refreshing automagically? I agree, manually porting could fix it. :)
Router details (maker/model/version/firmware revision) would be helpful.
Postby Flyby » Tue Nov 02, 2010 7:28 pm
Hey Kermit22 and alphawave 7,
port is forwarded manually.
I´am also unable to connect via my internal network.
There was no problem until the last update of Subsonic.
Flyby
Postby kermit22 » Tue Nov 02, 2010 7:36 pm
Flyby wrote:Hey Kermit22 and alphawave 7,
If that is the case make sure that the "Automatically configure your router...." checkbox is unchecked in Settings>Network.
kermit22
Postby Flyby » Tue Nov 02, 2010 8:26 pm
that could be the trick.
It´s now disabled.
Flyby
Postby kermit22 » Tue Nov 02, 2010 9:00 pm
Cool. If you have any more problems let us know.
kermit22
Postby Flyby » Tue Nov 16, 2010 10:59 am
Unfortunately for the third time this month I lost connection to Subsonic.
It was up 11 hours ago but now I cannot connect anymore.
I cannot check the log file because I´m away for a couple of days.
Was there anything changed since the previous version of Subsonic that could affect the network connection?
Flyby
Postby Smorgie » Tue Nov 16, 2010 12:36 pm
This has also been happening to me. Sometimes it runs for a few days before stopping, sometime for only a few hours.
This started for me when I upgraded to 'subsonic-4.2.beta1-setup.' I had been running v3 for several months on WHS without incident. The only change was the update of the program itself. I even uninstalled and reinstalled the newest version without any more success.
Nothing else on my server has changed. No ports, no IP addressing, the program just stops. and I have to manually restart it (again and again)
I really love this program, I just hate having to remote into my server to restart the application. I may reinstall v3 and see if is works correctly again.
Smorgie
Postby Flyby » Fri Nov 19, 2010 11:57 am
This is the part of my log file after my last connection to Subsonic:
[2010-11-15 03:00:00,622] INFO SearchService - Starting to create search index.
[2010-11-15 03:00:03,133] INFO SearchService - Created search index with 1000 entries.
[2010-11-15 03:00:04,168] INFO SearchService - Created search index with 2000 entries.
[2010-11-15 03:00:04,720] INFO SearchService - Created search index with 3000 entries.
[2010-11-15 03:00:05,236] INFO SearchService - Created search index with 4000 entries.
[2010-11-15 03:00:06,286] INFO SearchService - Created search index with 5000 entries.
[2010-11-15 03:00:06,596] INFO SearchService - Created search index with 6000 entries.
[2010-11-15 03:00:06,990] INFO SearchService - Created search index with 7000 entries.
[2010-11-15 03:00:07,425] INFO SearchService - Created search index with 8000 entries.
[2010-11-15 03:00:07,705] INFO SearchService - Created search index with 9000 entries.
[2010-11-15 03:00:08,091] INFO SearchService - Created search index with 10000 entries.
[2010-11-15 03:00:08,434] INFO SearchService - Created search index with 11000 entries.
[2010-11-15 03:00:08,607] INFO SearchService - Created search index with 12000 entries.
[2010-11-15 03:00:09,122] INFO SearchService - Created search index with 13000 entries.
[2010-11-15 03:00:09,569] INFO SearchService - Created search index with 14000 entries.
[2010-11-15 03:00:09,928] INFO SearchService - Created search index with 15000 entries.
[2010-11-15 03:00:10,260] INFO SearchService - Created search index with 16000 entries.
[2010-11-15 03:00:10,708] INFO SearchService - Created search index with 17000 entries.
[2010-11-15 03:00:11,100] INFO SearchService - Created search index with 18000 entries.
[2010-11-15 03:00:11,693] INFO SearchService - Created search index with 19000 entries.
[2010-11-15 03:00:11,921] INFO SearchService - Created search index with 20000 entries.
[2010-11-15 03:00:12,559] INFO SearchService - Created search index with 21000 entries.
[2010-11-15 03:00:13,014] INFO SearchService - Created search index with 22000 entries.
[2010-11-15 03:00:13,625] INFO SearchService - Created search index with 23000 entries.
[2010-11-15 03:00:14,184] INFO SearchService - Created search index with 24000 entries.
[2010-11-15 03:00:14,579] INFO SearchService - Created search index with 25000 entries.
[2010-11-15 03:00:15,112] INFO SearchService - Created search index with 26000 entries.
[2010-11-15 03:00:15,512] INFO SearchService - Created search index with 27000 entries.
[2010-11-15 03:00:15,994] INFO SearchService - Created search index with 28000 entries.
[2010-11-15 03:00:16,377] INFO SearchService - Created search index with 29000 entries.
[2010-11-15 03:00:16,560] INFO SearchService - Created search index with 30000 entries.
[2010-11-15 03:00:16,932] INFO SearchService - Created search index with 31000 entries.
[2010-11-15 03:00:17,363] INFO SearchService - Created search index with 32000 entries.
[2010-11-15 03:00:17,918] INFO SearchService - Created search index with 33000 entries.
[2010-11-15 03:00:22,114] INFO SearchService - Created search index with 34000 entries.
[2010-11-15 03:00:48,720] INFO SearchService - Created search index with 35000 entries.
[2010-11-15 03:01:14,417] INFO SearchService - Created search index with 36000 entries.
[2010-11-15 03:01:27,077] INFO SearchService - Created search index with 37000 entries.
[2010-11-15 19:12:05,147] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-11-15 19:12:05,149] INFO PodcastService - Completed scheduled Podcast refresh.
[2010-11-16 03:00:00,623] INFO SearchService - Starting to create search index.
[2010-11-16 03:00:00,807] INFO SearchService - Created search index with 1000 entries.
[2010-11-16 03:00:01,656] INFO SearchService - Created search index with 2000 entries.
[2010-11-16 03:00:02,698] INFO SearchService - Created search index with 3000 entries.
[2010-11-16 03:00:03,533] INFO SearchService - Created search index with 4000 entries.
[2010-11-16 03:00:04,552] INFO SearchService - Created search index with 5000 entries.
[2010-11-16 03:00:04,964] INFO SearchService - Created search index with 6000 entries.
[2010-11-16 03:00:05,415] INFO SearchService - Created search index with 7000 entries.
[2010-11-16 03:00:05,958] INFO SearchService - Created search index with 8000 entries.
[2010-11-16 03:00:06,272] INFO SearchService - Created search index with 9000 entries.
[2010-11-16 03:00:06,676] INFO SearchService - Created search index with 10000 entries.
[2010-11-16 03:00:07,204] INFO SearchService - Created search index with 11000 entries.
[2010-11-16 03:00:07,718] INFO SearchService - Created search index with 12000 entries.
[2010-11-16 03:00:08,164] INFO SearchService - Created search index with 13000 entries.
[2010-11-16 03:00:08,616] INFO SearchService - Created search index with 14000 entries.
[2010-11-16 03:00:08,743] INFO SearchService - Created search index with 15000 entries.
[2010-11-16 03:00:09,148] INFO SearchService - Created search index with 16000 entries.
[2010-11-16 03:00:09,639] INFO SearchService - Created search index with 17000 entries.
[2010-11-16 03:00:10,028] INFO SearchService - Created search index with 18000 entries.
[2010-11-16 03:00:10,540] INFO SearchService - Created search index with 19000 entries.
[2010-11-16 03:00:10,963] INFO SearchService - Created search index with 20000 entries.
[2010-11-16 03:00:11,168] INFO SearchService - Created search index with 21000 entries.
[2010-11-16 03:00:11,531] INFO SearchService - Created search index with 22000 entries.
[2010-11-16 03:00:11,904] INFO SearchService - Created search index with 23000 entries.
[2010-11-16 03:00:12,299] INFO SearchService - Created search index with 24000 entries.
[2010-11-16 03:00:12,663] INFO SearchService - Created search index with 25000 entries.
[2010-11-16 03:00:13,075] INFO SearchService - Created search index with 26000 entries.
[2010-11-16 03:00:13,459] INFO SearchService - Created search index with 27000 entries.
[2010-11-16 03:00:13,569] INFO SearchService - Created search index with 28000 entries.
[2010-11-16 03:00:13,933] INFO SearchService - Created search index with 29000 entries.
[2010-11-16 03:00:14,331] INFO SearchService - Created search index with 30000 entries.
[2010-11-16 03:00:14,839] INFO SearchService - Created search index with 31000 entries.
[2010-11-16 03:00:15,241] INFO SearchService - Created search index with 32000 entries.
[2010-11-16 03:00:15,957] INFO SearchService - Created search index with 33000 entries.
[2010-11-16 03:00:16,463] INFO SearchService - Created search index with 34000 entries.
[2010-11-16 03:00:16,567] INFO SearchService - Created search index with 35000 entries.
[2010-11-16 03:00:18,274] INFO SearchService - Created search index with 36000 entries.
[2010-11-16 03:00:25,860] INFO SearchService - Created search index with 37000 entries.
[2010-11-16 19:12:05,148] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-11-16 19:12:05,150] INFO PodcastService - Completed scheduled Podcast refresh.
[2010-11-17 03:00:00,624] INFO SearchService - Starting to create search index.
[2010-11-17 03:00:01,309] INFO SearchService - Created search index with 1000 entries.
[2010-11-17 03:00:02,133] INFO SearchService - Created search index with 2000 entries.
[2010-11-17 03:00:02,481] INFO SearchService - Created search index with 3000 entries.
[2010-11-17 03:00:02,802] INFO SearchService - Created search index with 4000 entries.
[2010-11-17 03:00:03,621] INFO SearchService - Created search index with 5000 entries.
[2010-11-17 03:00:04,411] INFO SearchService - Created search index with 6000 entries.
[2010-11-17 03:00:04,782] INFO SearchService - Created search index with 7000 entries.
[2010-11-17 03:00:05,182] INFO SearchService - Created search index with 8000 entries.
[2010-11-17 03:00:05,457] INFO SearchService - Created search index with 9000 entries.
[2010-11-17 03:00:05,840] INFO SearchService - Created search index with 10000 entries.
[2010-11-17 03:00:06,532] INFO SearchService - Created search index with 11000 entries.
[2010-11-17 03:00:06,645] INFO SearchService - Created search index with 12000 entries.
[2010-11-17 03:00:06,982] INFO SearchService - Created search index with 13000 entries.
[2010-11-17 03:00:07,376] INFO SearchService - Created search index with 14000 entries.
[2010-11-17 03:00:07,705] INFO SearchService - Created search index with 15000 entries.
[2010-11-17 03:00:08,059] INFO SearchService - Created search index with 16000 entries.
[2010-11-17 03:00:08,487] INFO SearchService - Created search index with 17000 entries.
[2010-11-17 03:00:08,896] INFO SearchService - Created search index with 18000 entries.
[2010-11-17 03:00:09,221] INFO SearchService - Created search index with 19000 entries.
[2010-11-17 03:00:09,474] INFO SearchService - Created search index with 20000 entries.
[2010-11-17 03:00:09,861] INFO SearchService - Created search index with 21000 entries.
[2010-11-17 03:00:10,432] INFO SearchService - Created search index with 22000 entries.
[2010-11-17 03:00:11,013] INFO SearchService - Created search index with 23000 entries.
[2010-11-17 03:00:11,491] INFO SearchService - Created search index with 24000 entries.
[2010-11-17 03:00:11,924] INFO SearchService - Created search index with 25000 entries.
[2010-11-17 03:00:12,487] INFO SearchService - Created search index with 26000 entries.
[2010-11-17 03:00:12,855] INFO SearchService - Created search index with 27000 entries.
[2010-11-17 03:00:13,220] INFO SearchService - Created search index with 28000 entries.
[2010-11-17 03:00:13,657] INFO SearchService - Created search index with 29000 entries.
[2010-11-17 03:00:13,811] INFO SearchService - Created search index with 30000 entries.
[2010-11-17 03:00:14,146] INFO SearchService - Created search index with 31000 entries.
[2010-11-17 03:00:14,498] INFO SearchService - Created search index with 32000 entries.
[2010-11-17 03:00:14,840] INFO SearchService - Created search index with 33000 entries.
[2010-11-17 03:00:21,775] INFO SearchService - Created search index with 34000 entries.
[2010-11-17 03:00:28,726] INFO SearchService - Created search index with 35000 entries.
[2010-11-17 03:00:35,939] INFO SearchService - Created search index with 36000 entries.
[2010-11-17 03:01:23,812] INFO SearchService - Created search index with 37000 entries.
[2010-11-17 19:12:05,148] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-11-17 19:12:05,150] INFO PodcastService - Completed scheduled Podcast refresh.
[2010-11-18 03:00:00,624] INFO SearchService - Starting to create search index.
[2010-11-18 03:00:01,308] INFO SearchService - Created search index with 1000 entries.
[2010-11-18 03:00:02,124] INFO SearchService - Created search index with 2000 entries.
[2010-11-18 03:00:02,954] INFO SearchService - Created search index with 3000 entries.
[2010-11-18 03:00:03,289] INFO SearchService - Created search index with 4000 entries.
[2010-11-18 03:00:03,657] INFO SearchService - Created search index with 5000 entries.
[2010-11-18 03:00:04,023] INFO SearchService - Created search index with 6000 entries.
[2010-11-18 03:00:04,366] INFO SearchService - Created search index with 7000 entries.
[2010-11-18 03:00:05,216] INFO SearchService - Created search index with 8000 entries.
[2010-11-18 03:00:05,260] INFO SearchService - Created search index with 9000 entries.
[2010-11-18 03:00:05,604] INFO SearchService - Created search index with 10000 entries.
[2010-11-18 03:00:06,755] INFO SearchService - Created search index with 11000 entries.
[2010-11-18 03:00:07,099] INFO SearchService - Created search index with 12000 entries.
[2010-11-18 03:00:07,457] INFO SearchService - Created search index with 13000 entries.
[2010-11-18 03:00:08,165] INFO SearchService - Created search index with 14000 entries.
[2010-11-18 03:00:08,267] INFO SearchService - Created search index with 15000 entries.
[2010-11-18 03:00:08,661] INFO SearchService - Created search index with 16000 entries.
[2010-11-18 03:00:09,094] INFO SearchService - Created search index with 17000 entries.
[2010-11-18 03:00:09,438] INFO SearchService - Created search index with 18000 entries.
[2010-11-18 03:00:09,814] INFO SearchService - Created search index with 19000 entries.
[2010-11-18 03:00:10,178] INFO SearchService - Created search index with 20000 entries.
[2010-11-18 03:00:10,662] INFO SearchService - Created search index with 21000 entries.
[2010-11-18 03:00:10,764] INFO SearchService - Created search index with 22000 entries.
[2010-11-18 03:00:11,293] INFO SearchService - Created search index with 23000 entries.
[2010-11-18 03:00:11,683] INFO SearchService - Created search index with 24000 entries.
[2010-11-18 03:00:12,049] INFO SearchService - Created search index with 25000 entries.
[2010-11-18 03:00:12,402] INFO SearchService - Created search index with 26000 entries.
[2010-11-18 03:00:12,732] INFO SearchService - Created search index with 27000 entries.
[2010-11-18 03:00:12,846] INFO SearchService - Created search index with 28000 entries.
[2010-11-18 03:00:13,211] INFO SearchService - Created search index with 29000 entries.
[2010-11-18 03:00:13,604] INFO SearchService - Created search index with 30000 entries.
[2010-11-18 03:00:13,968] INFO SearchService - Created search index with 31000 entries.
[2010-11-18 03:00:14,331] INFO SearchService - Created search index with 32000 entries.
[2010-11-18 03:00:14,735] INFO SearchService - Created search index with 33000 entries.
[2010-11-18 03:00:15,120] INFO SearchService - Created search index with 34000 entries.
[2010-11-18 03:00:15,241] INFO SearchService - Created search index with 35000 entries.
[2010-11-18 03:00:17,279] INFO SearchService - Created search index with 36000 entries.
[2010-11-18 03:00:24,296] INFO SearchService - Created search index with 37000 entries.
[2010-11-18 19:12:05,148] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-11-18 19:12:05,150] INFO PodcastService - Completed scheduled Podcast refresh.
[2010-11-19 03:00:00,625] INFO SearchService - Starting to create search index.
[2010-11-19 03:00:00,840] INFO SearchService - Created search index with 1000 entries.
[2010-11-19 03:00:01,182] INFO SearchService - Created search index with 2000 entries.
[2010-11-19 03:00:01,503] INFO SearchService - Created search index with 3000 entries.
[2010-11-19 03:00:01,848] INFO SearchService - Created search index with 4000 entries.
[2010-11-19 03:00:02,224] INFO SearchService - Created search index with 5000 entries.
[2010-11-19 03:00:02,576] INFO SearchService - Created search index with 6000 entries.
[2010-11-19 03:00:02,940] INFO SearchService - Created search index with 7000 entries.
[2010-11-19 03:00:03,782] INFO SearchService - Created search index with 8000 entries.
[2010-11-19 03:00:04,055] INFO SearchService - Created search index with 9000 entries.
[2010-11-19 03:00:04,382] INFO SearchService - Created search index with 10000 entries.
[2010-11-19 03:00:04,711] INFO SearchService - Created search index with 11000 entries.
[2010-11-19 03:00:04,802] INFO SearchService - Created search index with 12000 entries.
[2010-11-19 03:00:05,127] INFO SearchService - Created search index with 13000 entries.
[2010-11-19 03:00:05,478] INFO SearchService - Created search index with 14000 entries.
[2010-11-19 03:00:06,166] INFO SearchService - Created search index with 15000 entries.
[2010-11-19 03:00:06,496] INFO SearchService - Created search index with 16000 entries.
[2010-11-19 03:00:06,851] INFO SearchService - Created search index with 17000 entries.
[2010-11-19 03:00:07,185] INFO SearchService - Created search index with 18000 entries.
[2010-11-19 03:00:07,527] INFO SearchService - Created search index with 19000 entries.
[2010-11-19 03:00:07,632] INFO SearchService - Created search index with 20000 entries.
[2010-11-19 03:00:07,996] INFO SearchService - Created search index with 21000 entries.
[2010-11-19 03:00:08,358] INFO SearchService - Created search index with 22000 entries.
[2010-11-19 03:00:08,866] INFO SearchService - Created search index with 23000 entries.
[2010-11-19 03:00:09,207] INFO SearchService - Created search index with 24000 entries.
[2010-11-19 03:00:09,529] INFO SearchService - Created search index with 25000 entries.
[2010-11-19 03:00:09,868] INFO SearchService - Created search index with 26000 entries.
[2010-11-19 03:00:10,201] INFO SearchService - Created search index with 27000 entries.
[2010-11-19 03:00:10,539] INFO SearchService - Created search index with 28000 entries.
[2010-11-19 03:00:10,863] INFO SearchService - Created search index with 29000 entries.
[2010-11-19 03:00:10,965] INFO SearchService - Created search index with 30000 entries.
[2010-11-19 03:00:11,305] INFO SearchService - Created search index with 31000 entries.
[2010-11-19 03:00:11,757] INFO SearchService - Created search index with 32000 entries.
[2010-11-19 03:00:12,189] INFO SearchService - Created search index with 33000 entries.
[2010-11-19 03:00:14,611] INFO SearchService - Created search index with 34000 entries.
[2010-11-19 03:00:19,632] INFO SearchService - Created search index with 35000 entries.
[2010-11-19 03:00:26,545] INFO SearchService - Created search index with 36000 entries.
[2010-11-19 03:00:36,139] INFO SearchService - Created search index with 37000 entries.
It seems ss remains in a search loop.
Flyby
Postby Exrace » Sat Nov 20, 2010 2:24 pm
That is the schedule scan at 03:00 AM (default) and normal.
How many files you have in your collection?
Exrace
