bug? playlists skip files w/ grave accent chars when loading
Postby jsmallwood » Tue Jan 11, 2011 7:45 pm
Hopefully someone can confirm this for me.
My example of this issue is with the artist Michael Bublé. The foldername I have the songs in has that accent "e" on the end just like the spelling above.
To recreate the issue, I create a playlist with a song from that folder, then save the playlist. Whenever the playlist is loaded (via the More Actions--Playlist--Load dropdown), any songs from that folder are not displayed in the playlist.
Files from that artist will play just fine if I add them from the library, just won't load from a playlist.
If I open the actual m3u file, the correct files ARE in the list (i.e. Michael Bublé songs are in there and the filepath is correct). So the saving of the playlist appears to be correct. This appears to be an issue with loading m3u files.
I'm on Win7x64, 4.3.beta1 (build 2044)
jsmallwood
