View photos
View photos
Postby indecline » Thu Jan 13, 2011 12:04 pm
I saw that i can include my photo folders by including jpg in my settings
so by searching of hours in scripting and for a solution for a photo album to display a pictures
So lets see :
jw flash can read images
http://www.longtailvideo.com/support/jw-player-setup-wizard?example=203
i need to find out how to replace photo links to
http://192.168.000.1:4040/coverArt.view?size=600&path=/IMG_7119.JPG
i found a little solution
Add .jpg and .JPG to audio extensions in settings
in playlist.jsp
find
function createPlayer() {
        var flashvars = {
add after
skin:"<c:url value="/flash/whotube.zip"/>",
find
if (song.format == "aac" || song.format == "m4a") {
            list[0].provider = "video";
add after
  if (song.format == "jpg" || song.format == "JPG") {
            list[0].provider = "image";
This works only for 4.3 stable
indecline
Postby stueyboy » Thu Jan 13, 2011 12:40 pm
Seems to work OK for me. I'm at the office so the bandwidth is restricting playback a bit but still working. Thanks!!
stueyboy
Postby indecline » Thu Jan 13, 2011 2:28 pm
If someone wants to see a photos instantly
You must apply the size of a player
This part is explained in this mod.
http://forum.subsonic.org/forum/viewtopic.php?p=15120
Open “C:/subsonic/jetty/1802/webapp/WEB-INF/jsp/playlist.jsp” using a text editor like notepad or wordpad.
Search for:
"340" and that's the line you're looking for. Replace the "24" after it with a larger number, 255 gives you a nice player size with a 4:3 aspect ratio. You can tweak the player size to your liking.
Open C:/subsonic/jetty/1130/webapp/WEB-INF/jsp/index.jsp. Change
frameset rows="70%,30%"
to
frameset rows="50%,50%"
50/50 can be replaced with whatever looks best to you.
if some one can implement this to video player and not audio would be cool
indecline
Re: View photos
Postby Riffy » Mon Feb 04, 2013 1:12 pm
Is there anyway to set it up to view images on the android app
Riffy
Re: View photos
Postby siGh » Mon Mar 04, 2013 8:44 pm
I added a new button to the 'top' and use sv builder pro for my galleries. It's very quick to load, VERY easy to configure, and can be customized to match virtually any style you can think of. Ok, you guys are coders, and I am not. But ... it works for me 8)
siGh
Re: View photos
Postby vintendo » Fri Dec 06, 2013 11:28 pm
Not to bring One up from the dead lol
but I have been messing with this for a while and I can't seem to get the photos To display in JWplayer
I get the error that the file can't be found..
are you able to get the pictures to show up ?
not sure what you mean about how you were trying to get the last part in that link >>
I can see my pictures coming Up but I can not display them in the player
vintendo
