Port 4040 is blocked in my job network
Postby olathoen » Fri Feb 11, 2011 8:02 pm
Due to a radical security improvement(?) upgrade in my job network, port 4040 is blocked and I can not reach this service from my job computer. How can I come around this?
I am not very competent with network issues and use a Mac an an Apple wireless router.
olathoen
Postby kermit22 » Fri Feb 11, 2011 9:54 pm
try switching your subsonic server to port 80. A company would never block port 80. The downside with using port 80 is that occasionally your ISP will block it. It is probably your best bet though.
kermit22
Postby wizardai » Fri Feb 11, 2011 10:19 pm
Check out this thread:
http://forum.subsonic.org/forum/viewtop ... ght=tunnel
It explains step by step how to setup a tunnel so you can get to your server!
wizardai
Problem fixed
Postby olathoen » Fri Feb 18, 2011 8:26 am
Thank you for your help. I have Lighthouse (an app for port forwarding) installed on my Mac. Used it to forward port 80. This worked.
olathoen
