Subsonic Pack version 4.4- 2172
Postby cyclopes » Mon Feb 21, 2011 8:12 am
SUBSONIC PACK = 2011 v 4.4
This is tested on
Works on : Windows, Linux Standalone , Ubuntu 9.10 Karmic , ArchLinux VM
Thanks to:
*jonathanroz
*3R3
* all users Wink
New Window for Uploading music to your Subsonic Windows install standalone version 4.4
Mod info:
+ Playlist - have now include buttons for dark and silver player
Playlist.jsp Silver
Playlist.jsp Dark
Mod info , Log new version 4.4:
# fixd bugs - some script error and more.jsp i have remove the other upload option.
# more.jsp - Changed create random playlist with 50 80 90 100 150 200 250 300 350. orginal is max 50 songs.'
# moree.jsp - script bugs fix - UPDATED 22/02-2011 thanks to 3R3 :)
and have now include the 3R3 script in upload, user name will now show in incoming folder ;)
# Upwin.jsp - No changes
# Home.jsp - Change the albums per page 10 15 20 30 40 50 80 90 100 150 200 250 300 350
# Main.jsp - move the rate star to the top of album picture
# Playlist.jsp - with buttons to dark and silver player
-- READ THE INSTALL FILE !!!
-- BACKUP --- -- BACKUP --- -- BACKUP ---
Download the file here.
http://www.ferietunet.no/subsonic/Subso ... .4_new.zip
Vote Confirmation ;)
cyclopes
Thank you!
Postby westhaking » Thu Feb 24, 2011 3:33 am
Thank you so much for your continued effort on this! It works perfectly. This is my favorite ss mod and while I do enjoy upgrading my ss versions I always dread losing this functionality. Thank you again for your quick work.
westhaking
Re: Thank you!
Postby precipitous » Thu Feb 24, 2011 4:39 pm
westhaking wrote:Thank you so much for your continued effort on this! It works perfectly. This is my favorite ss mod and while I do enjoy upgrading my ss versions I always dread losing this functionality. Thank you again for your quick work.
You couldn't have said it better... Count me in total agreement!
precipitous
Postby cyclopes » Fri Feb 25, 2011 3:29 am
Thanks ;)
cyclopes
Postby XaviorPenguin » Sat Feb 26, 2011 1:17 am
I must be doing something wrong.
To the best of my knowledge, I followed all the steps properly, made the changed in my subsonic folder at the root of C:, turned off the service manually, killed the subsonic agent, restarted the service manually, turned on the subsonic agent, relaunched my browser, went to my subsonic and I see no changes.
I manually edited the files per the instructions and still this is not working. Can you give me any ideas on where I went wrong? I did save after each edit to make sure that I didn't lose any data.
Files have been copied over as best as I know how.
I am using the Groove theme (not the Simple version of that). Do I need to be on the Default Subsonic theme?
Thank you for this MOD tho, I can't wait to get it up and running. :)
EDIT:
Ok, I see my Upload Icon and that window pops up just fine, tho I don't intend on using it. That one is ok, I am just concerned about everything else, especially the playlist, I like the way you have that laid out. Very nice indeed.
XaviorPenguin
Postby cyclopes » Sat Feb 26, 2011 2:05 am
Try this:
stop subsonic.
you have upload this files:
playlist.jsp --> Only open file in Notepad and save
home.jsp --> Only open file in Notepad and save
main.jsp --> Only open file in Notepad and save
more.jsp --> Only open file in Notepad and save
Regards
Cyclopes
XaviorPenguin wrote:I must be doing something wrong.
EDIT:
cyclopes
Postby XaviorPenguin » Sat Feb 26, 2011 2:16 am
I did it and now it works.
Why did that work? That makes no sense to me at all.
Thank you so very much! :)
XaviorPenguin
Postby donpearson » Sat Feb 26, 2011 2:16 am
Going to give this mod a go! :wink:
Facebook Group:
donpearson
Postby cyclopes » Sat Feb 26, 2011 2:18 am
XaviorPenguin wrote:I did it and now it works.
:D
cyclopes
Postby sanderd » Sun Feb 27, 2011 12:11 pm
hi cyclopes,
i would like to try your mod but am a bit confused which files i have to overwrite.
in my C:\subsonic\jetty\2172\jsp\org\apache\jsp\WEB_002dINF\jsp directory i see both home_jsp.class and home_jsp.java.
which do i have to overwrite your home.jsp ?
(same for your other files)
thanks,
Sander
/edit/
Oops... i guess it should be C:\subsonic\jetty\2172\webapp\WEB-INF\jsp
/edit/
/edit2/
Works!! Awesome!!
/edit2
sanderd
Postby cyclopes » Sun Feb 27, 2011 10:48 pm
That is right :)
sanderd wrote:hi cyclopes,
thanks,
Sander
/edit/
/edit/
/edit2/
Works!! Awesome!!
/edit2
cyclopes
Postby 3R3 » Tue Mar 01, 2011 8:08 am
It works, of course. Years of long SS pack experience were not for naught :)
Nice new player buttons, I like 'em. And I'm glad you put the player selection dropdown back into the pack, it was mildly confusing when it was gone. I was like "cool it works...no wait, wheres my players!"
EDIT:
Try these steps and see if it works/shows up afterwards first please: Mod testing / bug reporting 101
3R3
Postby sanderd » Wed Mar 02, 2011 10:29 pm
hi there,
small question:
when i use the jukebox player i don't see the prev. en next song buttons.
they do appear with webplayer.
is this as designed?
regards,
Sander
sanderd
Postby cyclopes » Thu Mar 03, 2011 3:47 pm
they are designed for webplayer ;)
sanderd wrote:hi there,
small question:
regards,
Sander
cyclopes
Postby sanderd » Thu Mar 03, 2011 7:29 pm
Hi cyclopes,
what is the issue with building prev. next buttons for the jukebox player?
(didn't show up in searching this forum)
i mainly use the webinterface with jukeboxplayer because my home server is connected to an usb DAC on my stereo.
with current webinterface both the size/location of the playlist and skipping through playlist is not very well designed. i rather have the playlist at the right column to see more songs without having to scroll.
thanks.
sanderd
