Android client with repeat
Postby nibato » Thu Feb 24, 2011 6:46 am
Got annoyed with the lack of a repeat in the android version of the subsonic so I added it myself. It seemed to work fine, though admittedly I havn't thoroughly tested it yet. It's based off of the subsonic-android 2.6 release.
Download link
Source code patch
For those of you who are unfamiliar with how to install APK files on your android phone, you should be able to with apps like "apps installer" or "astro file manager" after placing subsonic-repeat.apk on your sd card.
Update: I was browsing through the SVN earlier and just noticed that sindre just implemented an even better repeat feature then mine for the next subsonic android release. Thanks sindre! I'll remove my links when 2.7 is eventually released to avoid problems.
nibato
Postby gamezonline » Thu Feb 24, 2011 8:57 pm
oh god thank you!, was so wondering why that wasn't already part of the app
gamezonline
Postby Arkady.es » Mon Mar 21, 2011 7:34 am
Would you try to do add a feature to your player?? The possibility to export/import playlist to the standard Android player.
Would be great!!!
Arkady.es
Postby drdrewdown » Mon May 23, 2011 4:46 pm
bump for loving a repeat option. with 2.7 i wish repeat was on by DEFAULT.
8)
drdrewdown
