SubSoinc.org down in Southwest United States
Postby Orbitrix » Tue Mar 01, 2011 5:15 pm
Just FYI www.subsonic.org and all URL forwarding service addresses are currently unreachable in the southwest United States. Direct connections to my IP address still work.
Please Advise.
Orbitrix
Postby cmar618 » Tue Mar 01, 2011 5:18 pm
I'm in CT and and having the same problem. I'm glad to hear it's not just me.
cmar618
Postby ofthecrutch » Tue Mar 01, 2011 5:24 pm
Over here in the Netherlands its down too :P
The whole subsonic.org domain is down by the way.
Is there anyone that knows how long this could take?
ofthecrutch
Postby bushman4 » Tue Mar 01, 2011 6:10 pm
It appears to be (after some REAL quick testing) one of the routers at Sindre's ISP is faulting. [208.109.113.174]
It seems to be only routing packets intermittently. A constant ping has seen 90% of packets dropped.
FYI...
Glenn
Postby beezy » Tue Mar 01, 2011 6:49 pm
Out here in Picksburgh too :?
beezy
Postby bushman4 » Tue Mar 01, 2011 6:54 pm
Don't forget that you can always connect via IP address even if the Subsonic domain is not working.
From the subsonic server, go to www.whatismyip.com. Make a note of your IP address listed there.
Then use http://IPAddress:SubsonicPort as your web destination (or server address on a remote app) and connect directly.
I have a second server called "Home Direct" on my droid set up similar to this (but because it is a Windows Home Server I can use http://name.HomeServer.com:PortNumber, because the chance that both Subsonic AND Microsoft's domains will be unreachable is remote).
HTH,
Glenn
Postby jaquense » Tue Mar 01, 2011 6:56 pm
out in New Jersey as well
Sindre, any word? I can reroute through my dyndns.org address but my users are not that, um...smart
jaquense
Postby madeintheuk » Tue Mar 01, 2011 7:16 pm
It's down here in Massachusetts. Thank god, I just got the registration code yesterday and i thought it waas me. :P
madeintheuk
Postby Jittery Jim » Tue Mar 01, 2011 7:39 pm
bushman4 wrote:Don't forget that you can always connect via IP address even if the Subsonic domain is not working.
HTH,
Glenn
Thanks for this, as subsonic.org is down in the Spokane, WA/Coeur d'Alene, ID area as well.
What I am having trouble with extends beyond subsonic.org; the IP route is not working for me either; it won't load on both my remote PC or iPhone, despite the fact that I can access the server it's self through a remote client just fine. Grrrr....
Jittery Jim
Postby beezy » Tue Mar 01, 2011 8:04 pm
HTH,
Glenn
Right on forgot about that. Works fine now.
beezy
Postby Orbitrix » Tue Mar 01, 2011 11:01 pm
bushman4 wrote:I have a second server called "Home Direct" on my droid set up similar to this (but because it is a Windows Home Server I can use http://name.HomeServer.com:PortNumber, because the chance that both Subsonic AND Microsoft's domains will be unreachable is remote).
HTH,
Glenn
I do this as well, but it is frustrating that the official android client still only allows you to store 3 connections. I have way more than 3 friends with SubSonic now, and would like to be able to store all of them, as well as the backup IP for my own connection.
Orbitrix
Postby donpearson » Tue Mar 01, 2011 11:35 pm
Your ip address is also in the image below :wink:
Facebook Group:
donpearson
Postby donpearson » Tue Mar 01, 2011 11:52 pm
All i get from my system is:
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL: http://www.subsonic.org/
The following error was encountered:
•Connection to 97.74.125.134 Failed
The system returned:
(110) Connection timed outThe remote host or network may be down. Please try the request again.
Your cache administrator is webmaster.
Generated Tue, 01 Mar 2011 23:39:29 GMT by smoothwall (squid/2.7.STABLE9)
Facebook Group:
donpearson
Postby oldsjunkie » Wed Mar 02, 2011 12:56 am
HTH,
Glenn
I see where this would be very helpful. Although wouldn't a dynamic IP cause an issue with this method? Because it's down in Indiana too, and I've been lost all day without it! :(
oldsjunkie
Postby donpearson » Wed Mar 02, 2011 1:04 am
oldsjunkie wrote:I see where this would be very helpful. Although wouldn't a dynamic IP cause an issue with this method? Because it's down in Indiana too, and I've been lost all day without it! :(
Yes it would but its just a quick fix while subsonic is down :wink:
Or you can always setup a free http://www.dyndns.com/ account and not use the subsonic system.
Facebook Group:
donpearson
Users browsing this forum: No registered users and 61 guests
