change default view to "newest"
Postby 3R3 » Sat Mar 12, 2011 8:42 pm
Inspiration by various posters in a feature request here: Set default view to NEWEST instead of random
to have the suggested mod (newest view instead of random view in main tab) not only show up when manually navigating to home.view or when first logging in, but also when staying there refreshing as often as the randow view to keep the newest view almost updated in real-time, follow below instructions acurately!
Backup, stop server, edit files, restart server, clear browser cache, login!
[OPTIONAL]
(to make "newest" appear leftmost in the main tab)
In home.jsp in subsonic/jetty/xxxx/webapp/WEB-INF/jsp find:
<c:forTokens items="random newest highest frequent recent users" delims=" " var="cat" varStatus="loopStatus">
replace with:
<c:forTokens items="newest highest frequent recent random users" delims=" " var="cat" varStatus="loopStatus">
save!
[NEEDED]
in index.jsp find:
<frame name="main" src="nowPlaying.view?" marginwidth="0" marginheight="0">
replace with:
<frame name="main" src="home.view?listSize=10&listType=newest" marginwidth="0" marginheight="0">
save!
in top.jsp find:
<td class="logo" style="padding-right:2em"><a href="home.view?" target="main"><img src="<spring:theme code="logoImage"/>" title="${help}" alt=""></a></td>
    <c:if test="${not model.musicFoldersExist}">
        <td style="padding-right:2em">
            <p class="warning"><fmt:message key="top.missing"/></p>
        </td>
    </c:if>
    <td>
        <table><tr align="center">
            <td style="min-width:4em;padding-right:1.5em">
                <a href="home.view?" target="main"><img src="<spring:theme code="homeImage"/>" title="${home}" alt="${home}"></a><br>
                <a href="home.view?" target="main">${home}</a>
replace with:
<td class="logo" style="padding-right:2em"><a href="home.view?listSize=10&listType=newest" target="main"><img src="<spring:theme code="logoImage"/>" title="${help}" alt=""></a></td>
        </td>
    </c:if>
    <td>
                <a href="home.view?listSize=10&listType=newest" target="main"><img src="<spring:theme code="homeImage"/>" title="${home}" alt="${home}"></a><br>
                <a href="home.view?listSize=10&listType=newest" target="main">${home}</a>
save!
DONE!
enjoy!
EDIT: works now! :-)
fixed error in code snipped
3R3
Postby benzubi » Tue Mar 15, 2011 8:09 pm
hey
I try to use this but I can't find the line
<frame name="main" src="home.view?" marginwidth="0" marginheight="0">
in my index.jsp
weird :shock:
benzubi
Postby 3R3 » Tue Mar 15, 2011 8:17 pm
benzubi wrote:hey
in my index.jsp
weird :shock:
That IS weird, as this file defines the main frameset and only contains some 27 lines. Have you tried looking by hand/eye? In my case its line 16, you should really be able to find it.
3R3
Postby benzubi » Tue Mar 15, 2011 9:49 pm
Take a look at my file :oops:
/var/subsonic/jetty/2169/webapp/WEB-INF/jsp/index.jsp
MOD: Removed pic link as no longer showing correct image
Am I blind or did I miss somthing?
benzubi
Postby 3R3 » Wed Mar 16, 2011 1:16 am
nope I'm sorry. I was stupid and forgot I had edited the "nowPlaying.view" to "main.view". Use that line and it should work just fine. The line with "name="main" src="nowPlaying.view" it is.
3R3
Postby benzubi » Wed Mar 16, 2011 8:58 am
ok :)
works fine indeed.
this feature should be in the next release, it's so nice to have new stuff as home page when using it with friends!
benzubi
Postby cyclopes » Tue Apr 19, 2011 12:32 am
Nice 8)
Vote Confirmation ;)
cyclopes
Postby Hellscream » Sun Jul 24, 2011 6:00 pm
Awesome work working fine +1 :D
Hellscream
Postby mudsharkymon » Tue Jul 26, 2011 10:27 pm
Does this tweak :
1) Differentiate NEW from MODIFIED? If I select New I do not want to see modified entries come up!
2) work on version 3.7?
Thx!
mudsharkymon
Postby Hellscream » Tue Jul 26, 2011 10:38 pm
If you modify files inside folders nothing will be registered, but if you change folder it will be shown as new in your library. About version 3.7 i think it will work fine just back up before u change anything.
Hellscream
Re: change default view to "newest"
Postby boognish43 » Wed Nov 30, 2011 5:00 am
does this still work? I cant find the code in the top.jsp
boognish43
Postby BKKKPewsey » Wed Nov 30, 2011 2:23 pm
boognish43 wrote:does this still work? I cant find the code in the top.jsp
Where does it say edit top.jsp :?
Postby boognish43 » Wed Nov 30, 2011 4:52 pm
3R3 wrote:Inspiration by various posters in a feature request here: Set default view to NEWEST instead of random
in top.jsp find:
        </td>
    </c:if>
    <td>
replace with:
        </td>
    </c:if>
    <td>
save!
DONE!
enjoy!
In the original post.. am I missing something?
boognish43
Postby BKKKPewsey » Wed Nov 30, 2011 5:05 pm
:P I think we both need new glasses 8)
Yes you are right but I just checked my top.jsp file (4.6beta2) and the code is there.
<td class="logo" style="padding-right:2em"><a href="help.view?" target="main"><img src="<spring:theme code="logoImage"/>" title="${help}" alt=""></a></td>
        </td>
    </c:if>
    <td>
            </td>
                <a href="nowPlaying.view?" target="main"><img src="<spring:theme code="nowPlayingImage"/>" title="${nowPlaying}" alt="${nowPlaying}"></a><br>
                <a href="nowPlaying.view?" target="main">${nowPlaying}</a>
            </td>
Postby inajar » Tue Dec 06, 2011 8:11 pm
Thanks a lot for this!
inajar
