Ubuntu Server freezes up and needs to be restarted
Postby steez » Mon May 09, 2011 2:56 pm
Problem Description: About once a day, the server becomes in accessible.
Troubleshooting Steps: currently a
sudo service subsonic restart
will remedy the problem
Playback Application and version: when frozen I cannot access via Adroid app or web browser
Subsonic Version: 4.4 (build 2169) – February 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_20, Linux (73.0 MB / 81.8 MB)
Hardware Platform: Linux Ubuntu Server 10.10
When I restart, the log file gets erased. Next time this happens I will try to grab the log file before I restart.
Here are some lines of interest from current log file though.
[2011-05-09 06:47:41,948] WARN JaudiotaggerParser - Failed to find cover art tag in /media/Music/Compilations/Ninja Tune XX - Traxx Remixxes 1/01 Fools Rhythm.mp3
java.lang.OutOfMemoryError: Java heap space
   at org.jaudiotagger.tag.datatype.ByteArraySizeTerminated.readByteArray(ByteArraySizeTerminated.java:94)
   at org.jaudiotagger.tag.id3.framebody.AbstractID3v2FrameBody.read(AbstractID3v2FrameBody.java:181)
   at org.jaudiotagger.tag.id3.framebody.AbstractID3v2FrameBody.<init>(AbstractID3v2FrameBody.java:81)
   at org.jaudiotagger.tag.id3.framebody.FrameBodyAPIC.<init>(FrameBodyAPIC.java:149)
   at sun.reflect.GeneratedConstructorAccessor37.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
   at org.jaudiotagger.tag.id3.AbstractID3v2Frame.readBody(AbstractID3v2Frame.java:214)
   at org.jaudiotagger.tag.id3.ID3v23Frame.read(ID3v23Frame.java:422)
   at org.jaudiotagger.tag.id3.ID3v23Frame.<init>(ID3v23Frame.java:250)
   at org.jaudiotagger.tag.id3.ID3v23Tag.readFrames(ID3v23Tag.java:589)
   at org.jaudiotagger.tag.id3.ID3v23Tag.read(ID3v23Tag.java:556)
   at org.jaudiotagger.tag.id3.ID3v23Tag.<init>(ID3v23Tag.java:303)
   at org.jaudiotagger.audio.mp3.MP3File.readV2Tag(MP3File.java:219)
   at org.jaudiotagger.audio.mp3.MP3File.<init>(MP3File.java:391)
   at org.jaudiotagger.audio.mp3.MP3FileReader.read(MP3FileReader.java:39)
   at org.jaudiotagger.audio.AudioFileIO.readFile(AudioFileIO.java:285)
   at org.jaudiotagger.audio.AudioFileIO.read(AudioFileIO.java:148)
   at net.sourceforge.subsonic.service.metadata.JaudiotaggerParser.getArtwork(JaudiotaggerParser.java:274)
   at net.sourceforge.subsonic.service.metadata.JaudiotaggerParser.isImageAvailable(JaudiotaggerParser.java:251)
   at net.sourceforge.subsonic.service.MusicFileService.getBestCoverArt(MusicFileService.java:211)
   at net.sourceforge.subsonic.service.MusicFileService.listCoverArtRecursively(MusicFileService.java:191)
   at net.sourceforge.subsonic.service.MusicFileService.getCoverArt(MusicFileService.java:120)
   at net.sourceforge.subsonic.service.MusicFileService.getCoverArt(MusicFileService.java:92)
   at net.sourceforge.subsonic.controller.RESTController.getRandomSongs(RESTController.java:562)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:616)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
[2011-05-09 06:47:42,812] WARN JaudiotaggerParser - Error when parsing tags in /media/Music/Compilations/Ninja Tune XX - Traxx Remixxes 1/15 LA Nocturne.mp3
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
   at net.sourceforge.subsonic.service.metadata.JaudiotaggerParser.getRawMetaData(JaudiotaggerParser.java:71)
   at net.sourceforge.subsonic.service.metadata.MetaDataParser.getMetaData(MetaDataParser.java:43)
   at net.sourceforge.subsonic.domain.MusicFile.getMetaData(MusicFile.java:242)
   at net.sourceforge.subsonic.domain.MusicFile.getTitle(MusicFile.java:255)
   at net.sourceforge.subsonic.controller.RESTController.createAttributesForMusicFile(RESTController.java:622)
   at net.sourceforge.subsonic.controller.RESTController.getRandomSongs(RESTController.java:563)
[2011-05-09 06:48:45,389] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) fatal error: can't update LAME-tag frame!
steez
Ubuntu Freeze
Postby Aethies » Mon May 09, 2011 3:52 pm
You might try increasing the memory allocated for java. I am not sure what version of subsonic (war, standalone) you are using, but if you increase the default value of 100 to something higher, you might get this resolved fairly quickly.
[/quote]
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby steez » Mon May 09, 2011 5:11 pm
I think i am using a standalone.
Installed from command line in ubuntu. How do I increase the java memory?
Is it in a config file? or just a command I can run?
steez
Postby Aethies » Mon May 09, 2011 5:36 pm
steez wrote:I think i am using a standalone.
if you are using standalone, there should be a /var/subsonic/subsonic.sh file that you can edit. Just check the values at the top of that config file. They are pretty self-explanatory.
Let us know if that helps. Oh, and make sure to restart the subsonic server after editing this file.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
Postby steez » Mon May 09, 2011 6:06 pm
Thanks for your help
I do not have a /var/subsonic/subsonic.sh file
I have
/var/subsonic/subsonic.log
/var/subsonic/subsonic.properties
/var/subsonic/subsonic.sh.log
/var/subsonic/subsonic13.index
Since there is subsonic.sh.log in there, I have subsonic.sh somewhere right?
Where else would it be located?
steez
Postby achoo5000 » Mon May 09, 2011 7:02 pm
for debian (ubuntu), subsonic.sh is located at:
/usr/share/subsonic/subsonic.sh
But I think you edit the command arguments for the init service (including max memory) in this file:
/etc/default/subsonic
EDIT: I guess the difference is that editing subsonic.sh will change the default options whenever the subsonic command is executed from anywhere, while /etc/default/subsonic will change the command line arguments only for the service which is run on startup (or by the service starter).
achoo5000
Postby steez » Mon May 09, 2011 7:45 pm
Thank you, I edited both.
I will report back if this does help solve my problem.
steez
Postby Aethies » Tue May 10, 2011 2:01 pm
steez wrote:Thanks for your help
I have
I apologize, I was almost there. I have my subsonic.sh in /var/subsonic/standalone/
That is the only one I have.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
Aethies
