National characters in directories and filenames
Postby vaxmaster » Thu May 17, 2007 5:52 am
The directories (album or artist names) with national characters are not listed in subsonic and mp3 filenames are not listed in the tag editor. Why that?
vaxmaster
Re: National characters in directories and filenames
Postby spinalt » Wed Jun 27, 2007 4:39 pm
[quote="vaxmaster"]The directories (album or artist names) with national characters are not listed in subsonic and mp3 filenames are not listed in the tag editor. Why that?[/quote]
I have the same problem - is there allready a solution or a tip how to solve it? Maybe another encoding type or something like this...
spinalt
Found the solution, it's a encoding problem
Postby vaxmaster » Sun Aug 26, 2007 8:21 am
you must edit the web.xml and change the UTF-8 encoding param to ISO-8859-1.
All my songs are now found and subsonic diplay the french characters.
Now subsonic is fully functional in my environment (Sun Server E3500 with Solaris Express on 8 CPU's).
Thanks to the subsonic Team. :D
vaxmaster
Re: Found the solution, it's a encoding problem
Postby housekat » Sat May 31, 2008 5:16 pm
vaxmaster wrote:you must edit the web.xml and change the UTF-8 encoding param to ISO-8859-1.
Which of the xml tags in the web.conf did you change? "fileEncoding" ?
Thank you!
housekat
Postby pgawel » Wed Sep 17, 2008 2:30 pm
I've solved a similar problem on my system. Look here: http://forum.subsonic.org/forum/viewtop ... =2972#2972
pgawel
