jwplayer issue: Loading library freezing up webplayer
Postby PowPowPow » Thu Jun 16, 2011 1:36 am
Problem Description: After downloading, donating and playing around with Subsonic 4.4 for a few days, the web player is no longer working on my machine. This began after I set up a Subsonic music folder on an external hard drive, then launched Subsonic without the external hard drive running. Now I am seeing this problem every time I launch the Subsonic web player. The page partially loads, Firefox reports at the bottom left "Read l.longtailvideo.com" as if attempting to access that web page, then stops loading. The library on the left side of the page remains blank. After the first few seconds of launching the web player, I am not able to access any Subsonic pages. After searching, I found this post:
http://forum.subsonic.org/forum/viewtopic.php?t=5109
But had no luck in tracking down a solution. Is there any way to reset my Subsonic settings outside of the web player? Can I start over with Subsonic on my machine?
Troubleshooting Steps: I have been able to get in and delete all music folders I had set up for my library. I have uninstalled and reinstalled 4.4, and had temporary success with downloading and launching 4.3, but eventually the same issue with the library and jwplayer popped up.
Playback Application and version: Web player
Subsonic Version: 4.4, 4.3
Server Version: jetty-6.1.x, java 1.6.0_24, Mac OS X (65.3 MB / 75.6 MB)
Hardware Platform: Mac OS X 10.6.7
Java Memory Limit: Can't access
Problem Filename: N/A
Output from ffmpeg -i: Can't access
Last ten log file lines: Can't access
PowPowPow
Postby PowPowPow » Sat Jun 18, 2011 12:11 am
Problem solved. I deleted the /Library/Application Support/Subsonic/ folder and reinstalled.
PowPowPow
Users browsing this forum: Google [Bot] and 15 guests
