Request: Bigger chat, maybe Chatroom
Postby Mindfucker666 » Tue Jun 21, 2011 11:16 pm
i'm new to this forum and i'm loving Subsonic. A friend of mine set it up and we use it as a social platform between metalheads.
One feature that i'm missing a bigger chat. I would love to come home from work and see what everyone has talked about.
My understanding of programming is not that good but is it possible to make an add-on, maybe greasemonkey script to save the chatmessages in a log?
It would be more awesome if that log could be displayed in somekind of chatroom that opens in a new subsonic tab.
Thanks in advance
Mindfucker666
Postby Hellscream » Sun Jun 26, 2011 5:49 pm
Well i understandyour problem but i think u can try Ajax free chat easy to install and work fine with subsonic. Check it out at http://hellscream.subsonic.org
Hellscream
Postby deejay2302 » Tue Jun 28, 2011 4:18 pm
Ahm Hellscream you have Menu Buttons for Ajax Chat and Google etc. on the right side. How did you do that?
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby Hellscream » Tue Jun 28, 2011 8:04 pm
easy peasy u have codes below box for command line
for example {link:youtube|www.youtube.com} link will apear as youtube.
Cheers
Hellscream
Postby moisy » Thu Jun 30, 2011 12:36 am
Hey ya,
Couldn't log into your subs mate, just a quick tip.....in your settings - General - login message stick this in
Or Click {link:HERE |http://hellscream.subsonic.org/login.view?user=guest&password=guest}to login as a guest.
All the best to ya
Mark
moisy
Postby moisy » Thu Jun 30, 2011 12:38 am
How did you you get the equalizer on the player, that looks WICKED!!!!!
Mark
moisy
Postby Hellscream » Thu Jun 30, 2011 12:46 pm
Hm login working fine maybe u try to log on when i test something.
BTW check this link for EQ
http://forum.subsonic.org/forum/viewtopic.php?t=4825
Hellscream
Postby moisy » Thu Jun 30, 2011 1:37 pm
That's brilliant, thank you very much for the link.
I managed to log in straight after, think it timed out because of somethikng on my end.
Thanks again
Mark
moisy
