Change Subsonic admin password ?
Postby ccandreva » Tue Jul 05, 2011 7:57 pm
I'm trying to help someone who got his Subsonic install working just as he wanted on his Windows machine, then forgot the admin password he set up in Subsonic. Whoops!
Is there a file he can edit to reset the admin password, without deleting all the settings he's done so far ?
ccandreva
Postby GJ51 » Tue Jul 05, 2011 8:31 pm
Subsonic stores user passwords in encrypted form in the program database, probably using salted BCrypt hashes, although the exact implementation has not been investigated in the context of this article. It is not technically feasible to decrypt these hashes and retrieve the original password strings.
However, current versions of Subsonic export the program settings to a text file each time the server is shut down, and they reimport this text file when it is started back up. This text file also includes the encrypted password hashes, and they can easily be replaced by substituting the corresponding line as follows:
Open the Subsonic control panel and stop the service
Open a Windows Explorer and navigate to C:\subsonic\db
(on Linux this may be under /var/subsonic/db or /usr/bin/subsonic/db)
Open the file subsonic.script in a text editor
Near the top of the file, find the following line: INSERT INTO USER VALUES('admin','enc:xxxxxxxxxx',0,0,0,FALSE)
Note that the xxxxxxxxxx value is a hexadecimal string that represents the encrypted hash of the user’s current password.
Replace the line above with the following: INSERT INTO USER VALUES('admin','enc:61646d696e',0,0,0,FALSE)
Note that the value 61646d696e is the hash for the password "admin"
Save the file
Restart the service in the Subsonic control panel.
It is now possible to log on with user name and password admin, which are also the default administrator credentials. Don’t forget to change the password to something else on the Settings screen right after logging on. Obviously, this technique works with any other user account as well.
EDIT: NOT my original work but copied from somewhere else in the forums. I just added someone elses work for my notes, but forgot to copy the link to give the author much deserved credit for his work. Mea culpa, mea culpa, mea maxima culpa. :oops:
EDIT: Found it. :)
http://blog.gerke-preussner.de/2010/12/ ... -streamer/
Postby ccandreva » Wed Jul 06, 2011 3:50 pm
Thanks ! I'll point him to this post.
ccandreva
Users browsing this forum: No registered users and 52 guests
