Request my own source code?
Postby SparkyRih » Wed Jul 06, 2011 7:35 pm
I had a very, very bad server crash lately, and I lost all my source code....
I do still have my registration code, but I lost my subsonic nowplaying script completley... I can rebuild it, but if some-one has the source code saved on their computer it would be really helpfull!
Edit: It seems that the cause of my crash is because of veriosn 4.5 Beta1 of Subsonic... I never rebooted my server ever since installing this new version....
So my server crashed, I re-installed the whole server, everything fine, reboot, fine, installed subsonic 4.5, crash!!!
VMWare ESXi 5.5 > Ubuntu 16.04 > Subsonic 6.0 (Modded with PHP based registration feature)
SparkyRih
Re: Request my own source code?
Postby Aethies » Thu Jul 07, 2011 2:34 pm
SparkyRih wrote:I had a very, very bad server crash lately, and I lost all my source code....
I have been running Ubuntu Server 10.04 since it came out. I have been running subsonic on ubuntu server since 8.04. I have never had subsonic crash my server, beta version or otherwise. I am currently running the latest beta and still running ubuntu 10.04. No issues whatsoever. The two differences I can see first off is 1) you are running it in a virtual environment and 2) you are running 11.04.
I run ubuntu 10.10 as my work desktop and used to run it on my home until I upgraded from 10.10 to 11.04. My whole system crashed. I now have since built gentoo on my home system and refuse to update any of my ubuntu servers to anything higher than 10.10.
I am not blaming ubuntu for your issue, but I know there are still quite a few horrible bugs with 11.04.
I would be interested to know if you could spin up a new vm using 10.10 or earlier, install subsonic 4.4 and then install the beta. If it still crashes, then it has to be something in your VM environment. If it is stable, then I would look at Ubuntu 11.04 as the culprit.
Hope this helps.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby SparkyRih » Fri Jul 08, 2011 9:37 am
I guess I can try putting up another virtual, but downgrading that server is going to cost a lot of time...
SparkyRih
Postby bytethdgroove » Fri Jul 08, 2011 10:42 am
i think i have that script on my home pc...will check when I get off work later today
peace
byte
ps...never did get it working since I dont have Curl support... anyway of modifying it to not need that?
"I'm as honest as the day is long, the longer the daylight the less I do wrong!"
bytethdgroove
Postby SparkyRih » Fri Jul 08, 2011 11:36 am
bytethdgroove wrote:i think i have that script on my home pc...will check when I get off work later today
peace
byte
It would be very, very nice if you still have it!
About the cURL support... I use that to get the coverart.... dropping that part won't require the cURL... But you were the one who really wanted that support... I can't promise that I can get cURL replaced by some other code, but I'll try as soon as I have my code back :)
And my backup system does work correctly now, it makes a backup to 3 different (physical) machines every night, so this won't happen again!
SparkyRih
Postby bytethdgroove » Fri Jul 08, 2011 12:47 pm
turns out i had it on my webserver all long, donwloading and zipping as we speak...any special address to send to?
peace
byte
yea I would love album art support, but unfortunately my webhost doesnt support Curl, and I couldnt get it working on my home server where subsonic is hosted (WHS machine)
bytethdgroove
Postby SparkyRih » Fri Jul 08, 2011 2:15 pm
bytethdgroove wrote:turns out i had it on my webserver all long, donwloading and zipping as we speak...any special address to send to?
peace
byte
You can send it to my nickname + @live.nl (I do it this way to avoid spam ;) )
You know what, as a thank you, I can host your siggy if you want? But I'll still look for a way to drop the cURL stuff...
Let me know...
SparkyRih
Postby bytethdgroove » Fri Jul 08, 2011 5:23 pm
email sent
peace
byte
bytethdgroove
Postby SparkyRih » Fri Jul 08, 2011 7:00 pm
bytethdgroove wrote:email sent
peace
byte
And once again thank you!
I've send you a mail back...
This topic is done now ;)
SparkyRih
Users browsing this forum: No registered users and 0 guests
