Subsonic Package for Synology NAS
Postby gigon » Thu Dec 01, 2011 1:07 am
Hi folks,
first of all I don't know if this is the right Forum, so please move this Topic to its right Forum if it is wrong here.
I made a Synology .spk Package for simple GUI installation of Subsonic.
It is running very well on my DS 211+ with patters' Java .spk package installed. link
It should be working with all Marvell ARM v5 powered Diskstations on DSM 3.1 or higher.
I still have to fix a few things but I think I can release a first Package tomorrow with further details and all the scripts.
now I've to get some sleep, it is 2 AM here in Germany...
Subsonic Package for Synology DiskStations http://eg-blog.de
gigon
Re: Subsonic Package for Synology NAS
Postby jake- » Tue Dec 06, 2011 9:42 am
Sorry for hijacking the thread ;)
I've been looking for Java for my DS410 for a while without success, Anybody got SS working on this strange cpu?
Thx jake-
jake-
Postby gigon » Wed Dec 07, 2011 8:17 pm
maybe you can install one of these
http://www.oracle.com/technetwork/java/ ... index.html
also have a look at http://pcloadletter.co.uk/2011/02/07/se ... h-arm-cpu/ i think there is some text about JamVM
gigon
Postby gigon » Wed Dec 07, 2011 8:35 pm
For complete guide, download and support visit:
www.eg-blog.de
good news, the subsonic spk is done =)
Everyone who is able to read german: Post im Synology Forum
All others:
Install this at your own risk!
Create a manual backup to secure your settings and database.
The installation path is /volumeX/@appstore/Subsonic -X is the number of the drive SS is installed to- it can bei accessed via ssh
Minimum System Requirements:
A Synology DiskStation with a mv6282 or mv6281 CPU. What does my NAS have? ->klick
DSM 3.1 or higher
SS Requires up to 150MB RAM on my DS211+ (with 40.000 mp3s) so I recommend not to install this on little "j" DiskStations
Java SE v6 or v7 installed klick
Installation/update guide:
1. download the .spk from here: subsonic4.6_spkv17.spk (see chagelog and update instructions in following posts)
2. login into DSM
3. start the package center (in main menu)
4. select the downloaded .spk and install it
5. choose your destination drive
6. start
The subsonic GUI can be accessed via http://your-NAS-IP:4040 or the icon in the DSM.
After successful install it should look like this:
for the package content and scripts look at my post in the german Synology Forum
If you want to modyfy something be sure you have read this how to from Synology Synology DiskStation Manager 3rd-Party Apps Developer Guide_V2.pdf
This package contains lame and ffmpeg encoder which are licensed under LGPL.
My thaks go out to patters I couldn't have done that without his scripts and tutorials.
Again: Although there is a Backup routine implemented in the upgrade scripts: to be 100% sure please backup your library and settings manually!
If you have any questions, feel free to ask
gigon
Postby gigon » Thu Dec 08, 2011 10:02 pm
comments on subsonic4.6_spkv17.spk
fresh install: as described in post above
update: Subsonic may crash after update and database may be lost, please do a manual backup before updating if you want to keep the db.
If SS crashed after update you have to deinstall an install it again.
Change log:
subsonic4.6_spkv17 or 4.6-17
o added this change log
o added LICENSE file
o added restarting Message after install/upgrade
o fixed broken link in DSM
o fixed crash on update when Subsonic is running
o fixed some troubles with Subsonic Logo in package center
o changed backup routine on update: all relevant files should be backed up now
o changed the version tag in INFO layout from "%subsonic version% syno_package_v%spk version%" to "%subsonic version%-%spk version%"
o contains Subsonic stable release version 4.6
gigon
Postby gigon » Sun Dec 11, 2011 7:30 pm
I've created a blog where the package is maintained from now.
http://www.eg-blog.de/
Further releases will be posted here.
If you got any questions, you can post them on my blog page without registration.
There is a new version of the package with minor changes, to be compatible to the "Community Package Hub".
If you've got spkv17 installed there is no need for an update the changes are just technical.
gigon
Postby jake- » Wed Dec 14, 2011 8:42 am
gigon wrote:maybe you can install one of these
This is very promising:
Power Architecture Linux - Headless
* e500v2 core
I will give it a try and report.
Thanks very much!
jake-
Postby gigon » Wed Dec 14, 2011 11:59 am
There is a new release (hopefully the last until a new Subsonic release is out)
I have also created a x86 version, but can't test this with my 211+, so if you have an Atom it would be kind to report whether transcoding works or not.
If you have already installed a Subsonic Package you don't have to update. Subsonic itself is completely the same.
Download and Infos www.eg-blog.de
gigon
Postby BKKKPewsey » Wed Dec 14, 2011 4:24 pm
Now we have package downloads available I am moving this thread to Announcements
Postby alsobob » Thu Dec 22, 2011 9:47 am
THANK YOU THANK YOU THANK YOU!!!! I LOVE THIS PACKAGE!! :D
It runs PERFECTLY on my DS 712+! I can't tell you how easy my life is now cuz of this. I had posted a few months ago asking if anyone had a package or something like that for a Synology machine. No one answered, but then a few months later, you put this up. I honestly can't thank you enough. Now I can retire my server and just use my DS 712+. It runs perfectly, and transcodes everything quickly. The Synology actually serves Subsonic faster than my Core 2 Duo 4GB RAM Ubuntu server did.. no lag, no dropped connections, no problems!
Subsonic blows away the Synology DS Audio app.. but I was so worried I wouldn't be able to use it on my Syno.. thanks to this package, I don't have to worry about that anymore! Thank you so much!
What a Merry Christmas for me and my family thanks to you.. now I can play Christmas music through my house straight from my DS 712+. Thanks again!
alsobob
Postby viand0x » Mon Jan 09, 2012 6:34 pm
Hi, thank you for this package, it's really great!!
I just install it on my ds211+ and all works fine except from my iphone with the app "substream". Each time I play a song, the cpu usage raise up to 100% and the player is lagging. The network is not in cause. Is there something to do in subsonic to improve this?
I have a "classic" adsl connection with 128kbits upload.
viand0x
Postby gigon » Mon Jan 16, 2012 4:35 pm
I have the same problems with my 211+, it is caused by its small (slow) CPU and can't be changed at this moment.
If you are at home (using fast Wifi) you can disable transcoding:
Settings -> Player -> select the Subsonic player -> set maximum Bitrate to "no limit" -> disable the transcoding checkboxes at the buttom -> save
In the iSub app:
Settings->Settings->Maximum audio bitrate: "None"
If you are using mobile networks you will have to figure out if your upload bandwidth is big enough, otherwise you will have to cache the songs you want to listen to. (swipe from left to right on a folder in the iSub App and select cache.)
btw.: I am working on a new package which will include the latest version of ffmpeg (0.9.1).
gigon
Postby viand0x » Tue Jan 17, 2012 11:24 am
ok thank you for the answer! You're doing a great job, keep going!
I'm using the substream app on my Iphone.
I don't have the problem when i'm using the browser interface, maybe it can help...
viand0x
Postby leong » Sun Jan 22, 2012 2:55 am
any ideas will this port to DSM 4.0 BETA, don't want to kill the current setup. loving it all the way.... :D :D :D :D
leong
Postby viand0x » Mon Jan 23, 2012 3:21 pm
I disabled transcoding in subsonic, but I don't have this option in substream. It changes nothing...
viand0x
Return to Announcements
