Android: ICS Style Widget
Postby jsr » Thu Feb 09, 2012 3:37 am
I modified the widget to fit in better with the visual style of ICS.
Please try it out and let me know what you think. You'll have to uninstall your existing Subsonic android installation to install this version since it is signed with a different key.
APK:
http://www.ragtop.org/upload/subsonic/subsonic-ics-widget.apk
Source Patches:
http://www.ragtop.org/upload/subsonic/subsonic-ics-widget.patch
http://www.ragtop.org/upload/subsonic/subsonic-ics-widget-res.zip
jsr
Re: Android: ICS Style Widget
Postby NLclothing » Fri Feb 10, 2012 10:00 pm
Really like the new widget look, currently running your build and all seems well!
NLclothing
Users browsing this forum: No registered users and 0 guests
