Few suggestions for the next version
Postby kapz » Sat Sep 15, 2007 5:17 am
I use Subsonic all the time and just thought of a few small things to improve it. On the “Load Playlist” screen it far too easy to delete a playlist with out any confirmation. The “Load” and “Delete” link are too close. I personally don’t like message boxes on my WebPages so I thought you could put "load" on the left side of the playlist and keep the "delete" on the right. This make it a little harder to click the wrong link (I haven't done this, yet).
Have you given any thought to my suggestion about a checkbox to hide the "All Folders" category dropdown? I would fill the left bar with the first added music folder items initially.
-kapz
kapz
Postby sindre_mehus » Mon Sep 24, 2007 9:32 am
Hi kapz,
In 3.2.beta1 there is at least a confirmation dialog when deleting playlists.
Yes, I've thought about your checkbox suggestion, but I think it's too specific to be of general interest. If it still is a problem, you can work around it by deleting this line from left.jsp:
<option value="-1"><fmt:message key="left.allfolders"/></option>
Hope this helps :-)
Postby kapz » Tue Oct 09, 2007 3:22 am
After looking at the code I figured to remove that line, but the first time the list loads after logging in is like “All Folders”. After poking around I could not find the music folder scanning methods and gave up.
Maybe you might have a better idea about cutting down the number of folders in the left panel. I have put a few of my largest music collections in subfolders to reduce the number of artists listed, but that is a short term solution.
kapz
Postby sindre_mehus » Tue Oct 09, 2007 7:03 am
Hm, I guess you also have to change this line in index.jsp:
<frame name="left" src="left.view?" marginwidth="10" marginheight="10">
to
<frame name="left" src="left.view?musicFolderId=1" marginwidth="10" marginheight="10">
If musicFolderId=1 doesn't work, try with 2, 3, 4 etc.
Postby kapz » Tue Oct 09, 2007 3:20 pm
sindre,
Changing index.jsp worked after trying a few ID's. Thanks this will work for me.
kapz
